Author Topic: Mutazu MD-100 Trunk installed  (Read 3726 times)
Offline X-UFO
  • Just Ride
  • COG#: 11101
« on: June 14, 2013, 03:14:49 pm »
I installed the Matazu MD-100 Trunk last night (and into the wee hours of the morning).  First, this is my first post outside of the intro, so forgive me if I am repeating this or doing some new member typical forum error.
Anyway the box look good for $125 including the mounting hardware.  The bad news it the holes in the mounting plate does not match the holes in the rack.  I made two new holes (in the rack) about 8 1/2 inches apart to line up with the rack towards the seat and made the two rear holes in the plate a little wider  by making a second hole right next to the existing holes at the rear of the plate.
I attached the plate with screws that I had that are a little shorter than the ones provided with the box.  I could have Cut the screws if I did not have others.  I also used large washers in place of the lower mounting bracket provided because the brake light made it impossible to mount it. (plus it would be ugly).
Now that the plate is securely mounted to the rack I attached the box.  It was not as tight as I wanted.  It had some play in it (for $125 that's what you get)  I attached a home made "Shim with 3M tape to the plate that took care of that issue.
The trunk also came with a LED light.  Once I found the AUX power lead under the seat latch the hookup was easy, just plug it in and connect the ground.  I did not hook it up to the break light because I want to add a 12 volt outlet in the trunk to charge stuff when riding.  An easy splice in to the wire going to the lights inside the box.
I will try to add some photos when I take them and figure how to do it in the Forum.
I hope this is useful to others on the forum, as this forum has been useful to me.  Its great to be part of the group :beerchug:
2012 black Concours with two brothers Carbin black series slip on, LED Kit, Garnin GPS... And 1994 Honda CBR 1000F since New, Long Gone: 1984 Honda VFR 750 Intercepter, and yamaha DT-360 (two-stroke)  on/off.
Offline Larry
  • COG#: 9359
Re: Mutazu MD-100 Trunk installed
« Reply #1 on: June 14, 2013, 06:48:24 pm »
Larry, never heard of that rear trunk before but yes, please post pictures when you can.  It's not to difficult.
10 Kawi Concours 14 ABS
Offline TJ
« Reply #2 on: June 14, 2013, 07:51:04 pm »
« Last Edit: June 14, 2013, 07:55:32 pm by TJ »
Offline PaleRider
« Reply #3 on: June 14, 2013, 09:15:26 pm »
Same as the bestem,  I have had one on my ST1300 for 5 years with no issues.
Have Owned 2004 Honda VFR, 2004 Honda ST1300, 2000 Triumph Sprint ST.
Now 2012 ZG1400 in Pearl Arabian Red
Offline X-UFO
  • Just Ride
  • COG#: 11101
« Reply #4 on: June 15, 2013, 01:56:09 am »
On the Box  "MD_100"
The photos  larger than the forum will take.  How do I send photos?
Larry
Offline X-UFO
  • Just Ride
  • COG#: 11101
« Reply #5 on: June 15, 2013, 02:33:36 am »
Direct
Offline TJ
« Reply #6 on: June 15, 2013, 01:33:19 pm »
Same box?  Look fwd to pics. You have to resize them prior to attaching
Offline X-UFO
  • Just Ride
  • COG#: 11101
« Reply #7 on: June 16, 2013, 10:52:09 pm »
This another try to upload a photo from Photo bucket.  If this works I will post more photos.  Sorry about the slow learning curve.
The box for the MD-100.  Not DM-100.  I could be a typo on the web page or another trunk.
Offline X-UFO
  • Just Ride
  • COG#: 11101
« Reply #8 on: June 16, 2013, 11:01:36 pm »
Photos of the trunk and mounting plate (modified)
You can see the shim I made for a tighter fit.
This one shows the LED lights that are included.
Offline TJ
« Reply #9 on: June 17, 2013, 12:31:20 am »
Looks nice on the bike, definitely same trunk.  Must be a type error on their site.
Offline X-UFO
  • Just Ride
  • COG#: 11101
« Reply #10 on: June 17, 2013, 02:25:57 am »
I also think its an error on the site. Thanks, I think it looks good also.
Next thing for the trunk is to splice a quick disconnect to the wires going to the LED's inside the trunk.  I will be able to add different power outlets inside the trunk with ease.
Now the hard part will be not to overload it.  The Rack is only rated for about 22lbs.  And that includes the trunk and hardware.  hmm... about 10 lbs. Max plus about of 50 lbs. if the engineers under rated the rack.  lol
On that note, how heavy can a trunk be and still safe to ride?  (Before the front wheel starts to wobble or the rack falls off).  I always try to load the heaviest stuff as low as I can.  I want to use my trunk for helmets and riding gear when I get off the bike most of the time.  But I may pack it for longer rides.
Offline David
  • COG#: 10605
« Reply #11 on: June 18, 2013, 09:13:32 pm »
Very nice application.
"Speed is fine but accuracy is final"
1976 BMW R90 RS
1992 BMW K100 RS
2000 BMW K1200 RS
2011 Kawasaki C 14
Offline X-UFO
  • Just Ride
  • COG#: 11101
« Reply #12 on: June 19, 2013, 12:55:53 am »
Thank You
 :beerchug:
