Author Topic: new calsci shield  (Read 1966 times)
Offline 3greens
  • COG#: 9178
new calsci shield
« on: January 14, 2012, 03:50:50 pm »
just recd my calsci  shield for my 09 1400  looks great one  problem  when  i installed it the two center screws 5mm   with washer will not tighten down,  the screw bottoms out  the fit looks good only  thing  thought  the  material is thinner but seems the same as my kawi  shield ,put on my  kawi shield its tightens down  ok,  any help  would be app   thank yu
Offline 3greens
  • COG#: 9178
Re: new calsci shield
« Reply #1 on: January 14, 2012, 05:24:22 pm »
think i have found the problem  they drilled center holes to big  the screw  just  falls thru it so it will not support  the shield even with washer in place  be on the phone to  calsci monday
Offline 3greens
  • COG#: 9178
« Reply #2 on: January 14, 2012, 06:08:28 pm »
for your info folks  the center hole on the kawi screen  is .530  on calsci its .575  its to big  to hold the shield in place    anyone had the same issue??? ty
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #3 on: January 14, 2012, 06:15:16 pm »
Same. Just used a bigger washer.
Offline Timbo
« Reply #4 on: January 14, 2012, 10:15:19 pm »
The only thing that grabs the shield is the plastic washers. Mine is the same. Just tighten them to 4ft lbs. then put on the brackets and tighten to 4ft lbs also, and ready to go.
Offline ZG
  • COG#: 9735
« Reply #5 on: January 14, 2012, 10:39:45 pm »
+1... same here, just picked up a couple bigger nylon washers at the local hardware store, fixed.
« Reply #6 on: January 14, 2012, 10:51:08 pm »
I have bolted three different CalSci windshields on my C14. I used the factory plastic washers without any trouble. Although the holes were a little large. But I think it allowed for easier fitting on the bike.
Offline Timbo
« Reply #7 on: January 15, 2012, 12:37:33 am »
Yes, stock plastic washers work fine.
Offline wally_games
« Reply #8 on: January 15, 2012, 06:20:42 am »
Interesting that it's 4 ft./lbs. for the bolts holding the windshield onto its frame, but only 13 in./lbs. for the header bolts.
Offline 3greens
  • COG#: 9178
« Reply #9 on: January 17, 2012, 08:36:04 pm »
talked to mark yesterday  re my calsci ws  its appears  that  the kaw is .210 thick his is about .187  so with this difference in fact the screw will not tighten down with factory washer he also stated that  the thickeness is un unusual with  the kaw  shield and has found them thinner,at times in the area of .157 he then said  perhaps needs to send new washers with the  zg1400 shields
