Author Topic: New Hwy peg set up for C14 2010-2016 with Canyon Cages  (Read 14823 times)
Offline n3nman
  • COG#: 12142
« on: December 06, 2015, 11:57:46 pm »
Have a 2012 C14 with Canyon Cages. Was looking at my options to attach Hwy pegs to give my legs a break. Did not love the idea of attaching something to the bars. Did not look that clean and was also concerned about those types of clamps rotating if tipped over. Came up with an idea that I think fits the bill.
I am 5'10" tall with a 30" inseam. The location is perfect for me (slight bend at the knees). If you have longer legs and want your legs straight then you can rest the back of your boots on them as well. They take about 60 seconds per side to install. If you do not like the way they look you can just put them on for your longer trips. I am using the Rivco black vibration isolating pegs on my hardware. The other thing I like about them is they will not touch during a "normal" tip over but with more momentum I believe they will stop the bike from rotating a lot more and getting your rear view mirrors.
Was really just making a pair for myself to solve a problem but others might have interest as well. They will only fit 2010-2016 C14 with this style of Canyon Cages.
If you have some Rivco Black pegs already then the cost for the hardware (comes in black or black) is $40 plus $6.95 shipping in the CONUS.
If you want or need the pegs, the entire set (Rivco pegs and Hardware to mount them) would be $95 plus $9.95 shipping in the CONUS.
Lifetime replacement on the hardware (my lifetime not yours). if you have a problem, return the hardware to me first, and I'll replace it.
If there is a fair amount of interest it will be a couple of weeks before the first set ships. After that they will be ready to go.
PayPal is the preferred method of payment. PM me if you have questions or anything else. Thanks.
Offline ron203
  • COG#: 9847
Re: New Hwy peg set up for C14 2010-2016 with Canyon Cages
« Reply #1 on: December 07, 2015, 12:17:30 am »
Nicely done. When I get my CC I'll g.et back to you
2014 C-14
2008 Goldwing
Offline SilverConnieRider
  • COG#: 11953
« Reply #2 on: December 07, 2015, 12:46:37 am »
Do they come in a Chrome version?
Offline n3nman
  • COG#: 12142
« Reply #3 on: December 07, 2015, 12:50:13 am »
I think the pegs do. The attach hardware does not, but there is such a small amount that you can see you can just paint it silver. There is maybe 1/3 of a inch visible between peg and Canyon Cage.
Offline ron203
  • COG#: 9847
« Reply #4 on: December 07, 2015, 01:38:29 am »
Do those bolt in? Hard to see in the picture.
2014 C-14
2008 Goldwing
Offline n3nman
  • COG#: 12142
« Reply #5 on: December 07, 2015, 02:02:12 am »
Remove bolt that came with Canyon Cage. Install new bolt/stud. That is it. It is as clean as it gets.
Offline Sailor_chic
« Reply #6 on: December 07, 2015, 12:26:16 pm »
Looks nice, but the problem that I foresee is when you drop your bike, the peg is going to take all the impact, possibly snapping or bending the bolt and making removal of damaged peg very difficult.
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline n3nman
  • COG#: 12142
« Reply #7 on: December 07, 2015, 02:06:10 pm »
I originally thought that might be a problem. So after I installed them i put the bike down with help on some cardboard. The end of the pegs clear the ground by 1 1/2" . Contact is made with the bottom of the bar as CC intended. But I think in a a higher momentum drop (aka crash) it might contact them. To me that is good because on those higher rate drops the mirrors usually contact (more expensive). In any case the stud part is 3/8 grade 5 bolt and even if it got slightly bent you can just put a vise grip on it and turn it out. You have a 1.25" long stud. It is solid and do not think it can get stuck unless you destroy the bars at the same time, and that's a whole other story.
Offline Debs
  • 2016 Metallic Slate Blue
  • Debs
« Reply #8 on: December 07, 2015, 10:45:39 pm »
I did something similar to you.. I made some brackets but where did you get the studs from? I would prefer mine to look like yours instead of being on a bracket..
I Can Only Please One Person A Day..
Today Is Not Your Day.
Tomorrow Doesn't Look Good Either.
Offline n3nman
  • COG#: 12142
« Reply #9 on: December 07, 2015, 11:58:57 pm »
Made the bolt/stud. Does your set up rotate at all?
Offline Debs
  • Debs
« Reply #10 on: December 08, 2015, 12:07:22 am »
No they don't rotate..
I know the thread on the MCE bolts are different to the thread on the Rivco Pegs
Offline Sailor_chic
« Reply #11 on: December 08, 2015, 12:14:31 am »
Debs, I LOVE the flowers!!
2013 C14 Black
2006 Vmax
IBA # 60267
Offline Sailor_chic
« Reply #12 on: December 08, 2015, 12:17:54 am »
Here is how I installed my pegs:
2013 C14 Black
2006 Vmax
IBA # 60267
  • COG#: 11953
« Reply #13 on: December 08, 2015, 01:51:34 pm »
Nicole - did you weld that bracket to the cages?
Offline Flat-spot
  • COG#: 11111
« Reply #14 on: December 08, 2015, 02:34:08 pm »
Nicole, That's SLICK!   Recessed, I like it a lot.  I hope you don't mind if I steal that idea.   :great: :beerchug:
'08 C14
Offline Debs
  • Debs
« Reply #15 on: December 08, 2015, 06:48:17 pm »
Thank You  :)
Offline Sailor_chic
« Reply #16 on: December 08, 2015, 07:41:19 pm »
Yes it is welded.
Flat-spot, by all means, please do so. I am glad that you liked it.  By the way, I hope you dont have a difficult time remembering your COG member number .
« Last Edit: December 08, 2015, 11:45:21 pm by Sailor_chic »
2013 C14 Black
2006 Vmax
IBA # 60267
Offline konehead
  • COG#: 9065
« Reply #17 on: December 08, 2015, 11:42:32 pm »
Dam thats a fantastic idea......love the bracket.....did you make the bracket or find it somewhere, and/or modify it to the application?  let the secret out....!!!
Offline Early
  • COG#: Forum subscr
« Reply #18 on: January 03, 2016, 05:09:28 pm »
Sailor Chic,
That looks great.  Is the bracket custom or did you purchase it.
Can anyone confirm the info below is the correct peg for doing this?
Anti-Vibration Pegs – Black Powder Coated (pair)
Product Code: PEGSBK
Offline Landon
« Reply #19 on: January 03, 2016, 05:27:26 pm »
I'm interested. I would like to see just a picture of the mounts that I would be buying though. I like to know exactly what I am getting.
Landon
2012 C14 Arabian Red
Offline n3nman
  • COG#: 12142
« Reply #20 on: January 14, 2016, 12:50:10 am »
Couple of close ups of the Bolts that make up the attach hardware. Bolts are undercut at a 30 deg angle and then welded together. Used them the other day and they work great. A note about the other attach methods in this thread. If the Hwy bars are mounted any further inboard it becomes difficult to get your feet on them without your legs being hard up against the fairings.
Offline Landon
« Reply #21 on: January 14, 2016, 01:17:55 am »
Are the bolts stainless to prevent them from rusting?
Landon
Offline n3nman
  • COG#: 12142
« Reply #22 on: January 14, 2016, 01:46:01 am »
Not stainless. Painted black. Even if I used stainless the welding would ruin the properties of stainless. After installation I just use a little flat black on it.
Offline Sailor_chic
« Reply #23 on: January 14, 2016, 12:20:39 pm »
Doesnt welding also ruin the hardness properties of the bolt?
2013 C14 Black
2006 Vmax
IBA # 60267
Offline Gumby
  • Black 2011
  • COG#: 10640
« Reply #24 on: January 14, 2016, 12:58:54 pm »
I like the ideas here...  :great:
