Author Topic: Switched/battery powered leads at front?  (Read 728 times)
« on: June 26, 2019, 01:24:20 am »
Are there any Non switched/battery powered leads at the front of the bike?
I want to install a plug for a GPS.
Pulled the panels and don't see them.
Hate to run a wire from the battery..
« Last Edit: June 26, 2019, 06:54:58 pm by connie_rider »
Re: Non switched/battery powered leads
« Reply #1 on: June 26, 2019, 11:01:14 am »
Fuzeblock Ted, or PDM if you're made of money.  :rotflmao:
My Horns have Horns.
Offline LSGiant
  • COG#: 7524
« Reply #2 on: June 26, 2019, 11:46:35 am »
Unless you are much less prone to forgetting things than me the switched power is the way to go.  If you still have the same GPS as you did the the last time I saw you the GPS will prompt you when you turn off the bike if you want it to stay on using its internal battery. If you put it on non switched power and you forget to turn it off you will have a dead battery on the bike.
COG 7524 IBA 46513 GLMC 214
« Reply #3 on: June 26, 2019, 01:34:10 pm »
Good point.
  {Everyone knows about my lack of memory}
Sooooooooooooo,,,,,,,
« Last Edit: June 26, 2019, 02:28:36 pm by connie_rider »
Offline Harry
  • Cartoonist at large
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #4 on: June 26, 2019, 02:25:29 pm »
Ted, there are plenty of devices like this one that may help. I use a splitter that turns one port into two. Then I add my GPS along with cell phone charger.
Offline Harry
  • COG#: 4090
« Reply #5 on: June 26, 2019, 02:32:21 pm »
This is what I use. Then you can plug in even more pigtails for all the power hungry farkles (until you start blowing the fuse).
« Reply #6 on: June 26, 2019, 02:34:53 pm »
Thanx Harry.. Appreciated..  :great:
I bought 1 with USP ports as I'm tired of the Cigarette Lighter plug popping out of the Connie receptacle.  >:(
Gonna install it in the dash if I figure out which wires to hook to it..
https://www.ebay.com/itm/Car-SUV-Dual-USB-Port-5V-4-2A-Charger-LED-Digital-Voltmeter-Parking-Location-Kit/362482524493?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Offline Harry
  • COG#: 4090
« Reply #7 on: June 26, 2019, 02:50:12 pm »
Mine stays put.
I think the quality of the plug is a big factor.
I Never had one to back out and there are ways to tighten it up and lock it in place.
Offline AmphibSailor
  • Cibolo, TX Hooligan
  • COG#: 12210
« Reply #8 on: June 26, 2019, 03:05:28 pm »
Ted,
If you plan to install the USB receptacle in the corresponding position on the left side, you will limited as far
as the length of the receptacle (there is a metal piece in the way). {Alternatively, you could drill out the metal plate.}
« Last Edit: June 26, 2019, 03:19:44 pm by AmphibSailor »
« Reply #9 on: June 26, 2019, 03:34:52 pm »
Arghhhhhhh..   >:(
Ted
Offline Sailor_chic
« Reply #10 on: June 26, 2019, 03:36:45 pm »
I installed this USB port on mine.
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
  • COG#: 12210
« Reply #11 on: June 26, 2019, 03:39:05 pm »
Nice!  I assume that's a waterproof cap.
Offline Harry
  • COG#: 4090
« Reply #12 on: June 26, 2019, 03:41:57 pm »
Ted, that looks like a handy gadget. Why not remove the stock receptical and just put that in it's place? In reality, very few gadgets really need the outdated cigarette plug anyway. Almost everything I use now only requires the USB plug to get power.  I may do that.  :great:
You could go the extra distance, and mount a couple of those on the right side panel. Not sure if there is enough depth for them, but I'm liking the idea.
Here is a surface mount version...
« Last Edit: June 26, 2019, 04:03:12 pm by Harry Martin »
Offline LSGiant
  • COG#: 7524
« Reply #13 on: June 26, 2019, 04:29:25 pm »
Good point.
Yes,  left side under a rubber boot.
Offline PeterL
  • Keep that platypus away from me!
  • COG#: 13031
« Reply #14 on: June 26, 2019, 04:44:03 pm »
If I recall correctly, there was a pair of leads (switched) on the throttle side under the cover plate. On my 2008 I wired in a pair of tethered 2A USB connectors located inside my "glove box" atop the tank.
Mine all mine: 2008 C14 ABS (aka "Thunder")
projects: 1982 cb750F (project "Ichigo"), 1983 VF750S (x2) (I named the first one "SabreOne" just so's I could name the second one "SabreTwo-th"), and something that started life as an '03 SV1000s but has now mutated beyond recognition...
just gifted: 2003 BMW K1200RS, 2018 Multistrada 950, 2019 Yamaha Tracer GT (Nice. But I'd still rather have my friend than his bikes, y'know?)
« Reply #15 on: June 26, 2019, 04:47:51 pm »
Thank you. I'll look again.
I was just told there are leads in the black covered Bundle on the left side of my 2014?
  There is a black wire and a black w/ yellow stripe wire in the large black boot right there under the left upper inside fairing.
Will look there too.
Ted
Offline Harry
  • COG#: 4090
« Reply #16 on: June 26, 2019, 06:13:20 pm »
Looking at these ports, they need about 1-1/8 inch hole to mount.
When I look at my C14, I see two holes on the port and starboard sides just above the headlight adjustment knobs.
The most squarish holes are just a tad under 1" gap from top to bottom. If I were to mount the USB charge ports, I would install 1 each on each side, using an x-acto knife to whittle out roughly 1/16 inch curved clearance to fit the chargers in there. There would be minimal cosmetic change to the plastic. Probably not noticable at all if removed. There is sufficient clearance in depth to mount these things. The original 12V port would be left intact.
I'm liking this even more. This would give 4 charging ports total, 2 on each side. >:D
Ted, I think you got me started on a new farkle project.
Offline Harry
  • COG#: 4090
Re: Switched/battery powered leads at front?
« Reply #17 on: June 26, 2019, 07:13:03 pm »
Other options:
1. Cut out the middle joining plastic, mount the charge port to the plate, and then mount the plate to the enlarged hole.
2. Cut a round hole on the outer plastic above the current charge port.
3. Cut a hole on the inner plastic below the current charge port.
« Reply #18 on: June 26, 2019, 07:14:33 pm »
Thanks all.
I ground the plastic/metal out to fit the new plug where Amphibsailor/Sailor_chic suggested..
1 1/8" is correct and too big to fit between the scr4ews in the back, so I filed 4 flats on the plug to get it to fit.
Harry, yes, it's supposedly waterproof.
PeterL/Jeff, on my 2014, the wires were in the large black boot on the left side and are switched power.
  I still may go to non-switched power though.
   This plug can supposedly help me find my motorcycle in the parking lot/other** but needs non-switched power to do so.
     ** Needed when certain smart elecks hide my bike. {Not mentioning names, but}
  :violent-smiley-007:
Offline Harry
  • COG#: 4090
« Reply #19 on: June 26, 2019, 07:21:55 pm »
Thanks all.
Dang...is that a regular problem? <snicker> wonder where they got that idea from?
 :08: :72: :)) :)) :)) :))
Offline Harry
  • COG#: 4090
« Reply #20 on: June 26, 2019, 07:30:25 pm »
Ted, what's the range of that transponder, a mile?
Offline LSGiant
  • COG#: 7524
« Reply #21 on: June 26, 2019, 08:46:39 pm »
So it is guaranteed to drain your battery when the bike is not running.  :) If you are going to buy a USB plug get on that shuts down when you put the cover on.
« Reply #22 on: June 26, 2019, 10:00:02 pm »
Sorry, too late, already installed.
I opted to stay with switched power because of the battery drain.
PS: Harry, I'll be watchin' you...  :29:
Offline LSGiant
  • COG#: 7524
« Reply #23 on: June 26, 2019, 10:13:44 pm »
Alrighty then. See you in a few weeks.
