Author Topic: One key for all locks! (including Givi Maxia E55)  (Read 17651 times)
Offline DialedN_13
  • COG#: 12141
Re: One key for all locks! (including Givi Maxia E55)
« Reply #50 on: September 28, 2015, 12:23:16 am »
dialed,
That is correct.
I had the "A" key and the core is way to short to work in the give case lock.
Thanks Matt.  That's a pretty shady move on Kawi's part.
I read that you were going to give it a go.  Since the core didn't work, did you find another work around?
Still have the type A lock?
Russell
2013 Black C14
Central North Carolina
Offline mattchewn
  • COG#: 10993
« Reply #51 on: October 03, 2015, 11:44:51 pm »
Dialed,
I was able to make it work by changing out the plates in the Givi cylinder but it was a really (exceptionally), sloppy fit so I went back to the Givi key.  I was concerned that I would end up not being able to open it at some point in the future and then having to smash the case open.
Safer this way.
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Offline DialedN_13
  • COG#: 12141
« Reply #52 on: October 04, 2015, 02:28:56 am »
Dialed,
Safer this way.
I ended up going the Kawasaki branded case route which requires the A Type key cylinder.  Hated to spend the extra coin, but with the fitment issues and the topic you just addresses I figured it would even itself out over time.
Thanks for the input
Russell
2013 Black C14
Offline Brant Bandit
« Reply #53 on: October 15, 2015, 04:48:41 pm »
Dialed,
Safer this way.
I'll admit that mine is a bit more wiggly than it was, but it's still worth it for me to use one key. I'm going to take it apart over the winter and try to make the fit a bit better but it works fine the way it is.
Offline Derek
  • COG#: 11636
« Reply #54 on: February 05, 2016, 02:32:34 pm »
Just a follow up for those that have searched this tread (like I did) and want to add the "one key" to an older C14 box.  I have only just recently  ought a 2010 C14 with Kawi top box.  It only came with 1 key for it which the plastic head broke off, I thought if I'm spending money on a new key and I love the idea of a 1 key for the whole bike.
Purchased the kit and found the cylinder is different.  Took it back to the dealer who found it says "only for 2015/16 (so far) model years".  They contacted head office who said not "one key" kit available for older boxes.
Oh  Bother!
They think the Givi Z140 lock set will work so I'm going to try that.
2010 C14 Concours
1983 Honda V45 Sabre (sold)
Ottawa, Ontario
Offline Larry
  • COG#: 9359
« Reply #55 on: June 20, 2017, 05:05:14 am »
Any update on this?
10 Kawi Concours 14 ABS
« Reply #56 on: June 20, 2017, 05:33:01 pm »
I can update that I'm still using only one key and it's still working perfectly.  :great:
Easy.... pull your lock and see if you can rearrange the wafers to make it work like I did. Derek is just a big ole quitter!  :nananana:
Offline Derek
  • COG#: 11636
« Reply #57 on: June 21, 2017, 12:31:45 am »
Hey I resemble some of that remark!  well the big ole part anyways! LOL
I did order the kit from my local GIVI dealer... came with the cylinder and 2 keys.  Easy peasy to change.
Oh and Mr Brant Bananna.... I also have a 1 key box.... I had a new key cut, then cut the head off and glued it into a radio knob.... now I leave that ONE key in the box 99% of the time!
2010 C14 Concours
Ottawa, Ontario
