Author Topic: GPS mounting options  (Read 6512 times)
Offline free2ride
  • COG#: 11979
« on: June 11, 2015, 12:25:25 am »
I wanted to get opinions on the best way to mount a GPS.  I have a Zumo 660.  I have searched GPS and didn't seem to come up with the info so I apologize if this is a topic already addressed recently.  If you would be kind enough to post a pic of your mounting solution that would be helpful.  Thanks in advance.
2014 Concours Candy Cardinal Red (Roxanne)
Offline Justin726
Re: GPS mounting options
« Reply #1 on: June 11, 2015, 12:47:42 am »
Not the best pic, but I replaced the clamp for the clutch lever mount for one that Ram sells.  It put's the GPS up nice and high which is where I like it.  Doesn't block any of the other gauges or controls.
Offline Brass
« Reply #2 on: June 11, 2015, 11:26:41 am »
I have a techmount specifically designed for the Concours that mounts between the risers without blocking access to the stove knob.  I had the techmount for the left side clutch perch but it put the GPS to high for my liking.  I do prefer the rigid mounts over the RAM mounts but have never had any issues with RAM mounts in th east
I like the fact the GPS can be viewed with a quick glance down without being visible all the time or in the way.  Most of the time I don't even use the screen just listen to the direction through my SENA
http://www.techmounts.com/products/?page_function=detail&product_id=177
Shaun - Collegeville PA
2017 Yamaha FZ-07
Offline Argyle64
    • Argyle Armoring
« Reply #3 on: June 11, 2015, 12:47:25 pm »
I have the Murph's RAM ball mount (centered) that attaches to the risers in between the handlebars. I love it and it's very solid. I also use a brand new Garmin Zumo 660.
http://www.murphskits.com/product_info.php?cPath=130_133&products_id=282
Offline Jim
« Reply #4 on: June 11, 2015, 01:42:02 pm »
You know that adhesive disc that most GPSs come with? I glued mine onto my clutch fluid reservoir after carefully filing small circles for removal of the screws that hold the cover on, then use the suction cup mount.
Offline vquad
  • COG#: Forum Subscr
« Reply #5 on: June 11, 2015, 01:45:32 pm »
2 words
RAM MOUNT
http://www.motorcyclelarry.com/index.php?main_page=product_info&cPath=46_59&products_id=260
I have had one of these on my c14 since day one.
places your GPS front and center.
rock solid...5 outta 5 stars!
« Last Edit: June 11, 2015, 02:00:07 pm by vquad »
2015 BMW S1000RR
2015 Victory Magnum X1
Offline NakedFun
« Reply #6 on: June 11, 2015, 02:06:43 pm »
I did this.
http://forum.cog-online.org/index.php/topic,59327.0.html
Cheap and better looking than some of th other options.  I also made a seperate pedestal RAM ball mount to a plate that bolts on top of the clutch resivior for my action camera.
Cory
2008 Concours 1400
1999 ZRX1100
1976 KZ900
Offline Not So Wild Turkey
  • COG#: 10559
« Reply #7 on: June 11, 2015, 04:26:20 pm »
+1 on the Tech Mount
2012 Concours Arabian Red & 80 Suzuki GS1100E
2003 VTX1800R Black / 1979 Suzuki GS1000E / 1969 Norton Commando
Yamaha DT3 250 / Kawasaki 100 G4TR
Offline free2ride
  • COG#: 11979
« Reply #8 on: June 11, 2015, 05:19:26 pm »
Thanks for the replies everyone.  I just ordered a set of risers with the techmount from Murphs.  I'll have them installed in time for the COG get together in Arkansas next month.
Offline JS_racer
« Reply #9 on: June 12, 2015, 10:02:31 am »
2 words
RAM MOUNT
 :great: same here
Offline Alan
  • COG#: 11662
« Reply #10 on: June 12, 2015, 02:16:06 pm »
I am using the Kawasaki mount between the risers, got it when I bought the bike works fine.
Put a Ram mount ball on it use a long clamp, gets the GPS up in the center of line of sight.
Center of line of sight and up is where I like to have it.
Don't Panic!
AMA Charter Life 34 years
GWRRA Member 3 years
LIMNCS #147
'77 BMW R100/7 Manfred
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
'08 Suzuki DR650SE Mootzimo
'09 Honda GL1800Navi/XM HAFACAR
'12 Kawasaki ZG1400 Concours
Highly recommend http://letsrideclyde.com/
Offline gpd323
« Reply #11 on: June 12, 2015, 08:27:13 pm »
I mounted mine here using a PAM ball mount the bolts to the brake master cylinder OEM bolt.
Similar mount on the clutch side for the Escort 9500ix
Offline Deanc
  • COG#: 10429
« Reply #12 on: December 06, 2016, 07:41:54 pm »
I found a great spot to mount the GPS with this:
Car Mount TechMatte MagGrip
https://www.amazon.com/gp/product/B01E86ONW2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Had no issues over railroad tracks, potholes and other unexpected bumps in the road.
Hope this helps...
2011 C14 Silver, Canyon Cages, Leo Vince SBK exhaust, Sargent seat, SISF Mountain Runner Flash, etc.
Offline d04011
« Reply #13 on: December 06, 2016, 08:39:43 pm »
X2 on the motorcyclelarry center mount with a long clamp from Ram puts it just below the guages.  Tried a couple other options including on the brake fluid reservoir but I really prefer the motorcyclelarry version.  Works great and I'm totally satisfied with it.
2020 Triumph Rocket 3 GT; 2016 Kawasaki ZX-14R SE; 2015 C-14 Concours; 2014 Triumph Rocket 3 Roadster; 2014 Triumph Rocket 3 Touring; 2012 H-D Fat Bob; 2011 Triumph Rocket 3 Roadster; 2009 Triumph Rocket 3 Standard; 1984 Honda V65 Sabre
Offline Kman
  • COG#: 10569
« Reply #14 on: December 06, 2016, 09:06:47 pm »
+1 Techmount.  Make sure you apply thread locker to the Garmin interface plate screw (ask me how I know :-[)
2012 Black, PR4GTs, Guhl Flash, CS1 Slip-on, Blaster X Brake Flasher, Cree 10W Lights, H4 Extreme Bulbs, Baldwin Heated Seat, Screaming Banshee Horn, MRA VarioTouring Screen, Throttlemeister, Crampbuster, ProjectD Radiator Guard, Front & Rear Fender Extenders, Techspec Snakeskin Saddlebag Protectors, Techmount GPS Bracket, OEM Tank Guard, 47L Top Bag, Helmet Locks, ProjectD Kickstand Bigfoot
Offline ConcoursKZ
« Reply #15 on: December 06, 2016, 10:14:17 pm »
I put Velcro tape on the back of the GPS and Velcro tape on the tachometer. Easy on easy off. Plus the tachometer really serves no purpose on a C14.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #16 on: December 12, 2016, 11:49:16 am »
Offline roy826
« Reply #17 on: June 22, 2017, 10:30:37 am »
Here is my setup. I just got the bike a few days ago. So last night I went to work installing my old Zumo 550 GPS and battery tender SAE plug. I used a stem mount a friend gave me off his old Concours many years ago that I had been using the past few years on two GSXRs. Works great! running the power wire wasn't bad at all. I will say this though this bike has a gazillion fasteners and stuff. :-\
The bike came with Murphs bar risers which are still on the bike and it had two ram ball mounts on those but I will be getting rid of the bar risers and selling them as soon as my 6 oem bar clamp bolts come in this week hopefully.
I still cannot believe the great deal I got on this bike. I took the Corbin seat off too that will be sold later. I do not like the two piece design of the Corbin.
That Cee Bailey windscreen will be for sale too as soon as I get an OEM windscreen for it. The Cee Bailey is just too tall for me.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #18 on: June 22, 2017, 01:06:26 pm »
I had my gps where yours is in the pic initially but i noticed i had zero perifial vison when looking at it so moved it up on the bars by the fluid reservoir.
Offline roy826
« Reply #19 on: June 22, 2017, 01:24:07 pm »
I guess there is really no good place to have the distraction box placed but I rarely look at one for any length of time. The one in my truck is in the middle of the dash so you literally have to turn your head to look at it.
