Author Topic: PCA mirror mounted light brackets are no more!  (Read 1708 times)
Offline Big Brian
« on: February 11, 2019, 08:57:15 pm »
Just a heads up.
Tried to order the PCA mirror mounted light brackets today. I was informed that they are now discontinued and there is no leftover stock.
I suppose I will have to come up with another way to mount the lights under the mirrors.
I made a wanted post but in case someone sees this, i'd take a set if someone wants to sell.
Just figured i'd give you guys a heads up as it is still on the site and you can order it but then they will call to inform you it's done for.
1975 Honda Goldwing GL1000
1996 Honda Shadow ACE 1100
2001 Suzuki SV650N
2008 Kawasaki Concours ABS
2013 Ducati Monster 796 Anniversary Edition #35/200
Offline robertv
  • Go Hawks!
Re: PCA mirror mounted light brackets are no more!
« Reply #1 on: February 11, 2019, 09:46:34 pm »
That's too bad. If you have time, you can go the DIY route like MtnRider and I did. http://forum.cog-online.org/accessories-c14/my-diy-aux-light-mirror-mounts/
There's also a guy doing a 3d printer mount but we have yet to hear back if he's doing this. http://forum.cog-online.org/accessories-c14/any-interest/
Honestly, the DIY route was easy and cheap, I think i spent less than $15-20. YMMV...
2008 C14, silver [current]
2000 C10, red [sold]
Offline Big Brian
« Reply #2 on: February 11, 2019, 10:47:13 pm »
I'd really rather not go the DIY route as I dont have a lot of metal working tools, although yours looks very good.
Hopefully the 3d printed guy comes through.
2001 Suzuki SV650N
« Reply #3 on: February 12, 2019, 12:36:03 pm »
DAMMIT!
I knew that was gonna happen.  I have been putting off buying a set of those for 3 years, as well as putting off my Aux light mounting/purchase for that same amount of time.
I knew I should have bought a set for JUST this occaision -- but $100 for that chuck of billet seemed so excessive.
I'd say thanks for the info, but.....
My Horns have Horns.
Offline Big Brian
« Reply #4 on: February 12, 2019, 01:03:17 pm »
DAMMIT!
Tell me about it!!
At least I snagged a set of Canyon Cages before MC Enterprises ran out!!!
2001 Suzuki SV650N
Offline robertv
  • Go Hawks!
« Reply #5 on: February 12, 2019, 03:01:25 pm »
I didn't use any metal working tools or drills, just crescent wrenches and allen keys. BTW, the mounts were door stops from hardware store. It's the base metal plate that is needed since it's already pre-drilled exactly for the 3 holes and the center hole mount.  I found the tip from the other forum here.
Obviously shop tools are necessary if you want to do this from scratch using a piece of metal or a large flat washer. I was hoping for that guy with the 3d printer to maybe make and sell his item but he's been MIA since December. You can also find other mounts like near the front fender, forks, or on the cages if you have 'em. I just prefer the higher mount which creates a better visibility of lights both to me and surrounding drivers.
« Last Edit: February 12, 2019, 03:19:21 pm by robertv »
Offline Big Brian
« Reply #6 on: February 12, 2019, 05:38:57 pm »
Hey that's pretty slick! I might just try this!
2001 Suzuki SV650N
« Reply #7 on: February 13, 2019, 02:22:20 pm »
That is interesting, but you also gotta account for the canted angle.
The pucks corrected for that, so the lights sat level.
One of the things that has kept me from buying or installing bigger lights, is that I never ride at night.
And if I do get caught out after dark, I try to stay on the major highways where big driving lights will simply blind other drivers.
 :-X
Offline Big Brian
« Reply #8 on: February 13, 2019, 11:09:07 pm »
If someone could provide me with measurements, I am confident I could make these from either plastic or aluminium.
For work, I am an industrial supplier (bearings, electric motors, gearboxes, etc). We work closely with machine shops & fabricators.
Not that I am trying to steal PCA's design, I would just obviously like a set for myself.
If anyone would be so kind as to take measurements, I would be forever grateful.
Thank you!
2001 Suzuki SV650N
Offline Larry_Buck_FL
    • Buck Sport Touring
  • COG#: 3451
« Reply #9 on: February 14, 2019, 02:53:44 pm »
Big Brian
You would not be stealing PCA's design, as I am the original developer of these mounts that were stolen from me. I will look to see if I still have the CNC program & bill of materials for them or at least dwgs you can work from. They are pretty complicated to make, as stock is machined to the part configuration and the counter sunk holes for the mounting screws to the mirror base, and threaded holes to mount the lights level require multiple operations/angles.  All metric of course. My machine shop made 2 fixtures for these angles which added operations and hence cost. The mounts were powder coated gloss black rather than anodized, as black anodize tends to get "purpleish" with age.
I know owners think they are expensive (agreed), but are more complicated than they appear. They are a pretty darn good design. Shameless plug. HTH
Offline fartymarty
  • COG#: 9712
« Reply #10 on: February 14, 2019, 03:08:58 pm »
If you can still adjust the lights in two perpendicular directions what does that matter? The overpriced pucks were just for aesthetics because
people tend to think in up and down and left and right terms, but they actually aren't needed to aim the lights. They don't need to be level,
they just need to be aim-able. Personally as far as aesthetics goes I think they look better the closer you can get them to the mirrors,
dangling off the pucks just makes 'em look more like earrings.
Offline robertv
  • Go Hawks!
« Reply #11 on: February 14, 2019, 04:38:03 pm »
^^ +1 ^^
Yes my thoughts as well since the MM10 lights I mounted can be adjusted in 2 axis. When riding especially on the curves and twisty's, its actually an advantage to point it outward for enhanced road visibility even in daylight or in shaded areas. I don't ride much at night but comes in handy when caught at twilight.
Offline Big Brian
« Reply #12 on: February 14, 2019, 05:46:27 pm »
Big Brian
That would be absolutely fantastic!
You've developed an excellently designed product!
Thank you!
2001 Suzuki SV650N
  • COG#: 3451
« Reply #13 on: February 14, 2019, 08:37:40 pm »
With my mounts the lights are horizontal, level. This is important for incandescent and HID lights due to the configuration of the reflector.
With LED's, it's generally not as important. The longest range lights are still halogen or HID.
Offline Big Brian
« Reply #14 on: February 17, 2019, 07:31:39 pm »
Any luck on finding the drawings?
2001 Suzuki SV650N
Offline Whitey
« Reply #15 on: September 04, 2019, 09:29:36 pm »
In an attempt not to tread on anyone's toes I have made some mounts that mount under the mirror also.
Unsure what the PCA ones look like so have not copied theirs. Mine are a copy of a set that were originally designed and made by a fellow Australian who has given me permission to remake them as long as he is acknowledged for his original work.
Mine are not 3d print so are solid. They are highly UV and heat/cold stable (made from the same stuff Teflon is made from) and wont rust. As I said I am not here to tread on toes as I am aware of other 3d printed ones (only found this out today)
Long story short only made these for a few fellow riders here in Aus due to not be able to get anything here, had no intention on going further than that but it appears there is a big gap of affordable quality mounts for the 1400.
Photos attached for your viewing pleasure.
Offline gPink
  • MMVIII C XIV
« Reply #16 on: September 04, 2019, 09:47:27 pm »
....and?
What's the story on the lights you have hanging from them?
Offline Whitey
« Reply #17 on: September 04, 2019, 09:57:12 pm »
....and?
They are a LED light supplied by an Aussie company. They call them C4 lights.
https://www.stedi.com.au/c-4-led-spot-light.html
that is their website. I have no affiliation with them except I bought a set of lights from them. I will say out of the hand full I tested these have blown what I expected out of the water
« Last Edit: September 04, 2019, 11:51:28 pm by Whitey »
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
« Reply #18 on: September 04, 2019, 11:14:27 pm »
This COG Industry Member also makes Aux Light Mounts...
http://forum.cog-online.org/peterl-c14-auxiliary-light-mount-kit/
| Steve Smith | COG #3184 |
BECOME A COG MEMBER
Offline Whitey
« Reply #19 on: September 04, 2019, 11:41:19 pm »
Yeah saw those today after I signed up here.
Offline gPink
  • MMVIII C XIV
« Reply #20 on: September 05, 2019, 12:07:15 am »
The Stedi lights are quite impressive.
Offline gPink
  • MMVIII C XIV
« Reply #21 on: September 05, 2019, 12:26:05 am »
What's your point Mr. Smith? Are you saying that the OP here cannot talk about an item he has built without someone jacking the thread to shamelessly plug another forum subscribers product because he has paid the buck 2.98 to get listed as an industry member?
Gary
Offline Bowyerv
« Reply #22 on: September 05, 2019, 12:35:18 am »
.... I have made some mounts that mount under the mirror also.
I use these mounts on my 2010!  They are awesome. They are strong, robust and look like original equipment. The quality of the kits Whitey provides is 2nd to none.  They were straight forward to install.  I highly recommend them.
You can see them here: http://bit.ly/2HPrMfw
Offline gPink
  • MMVIII C XIV
« Reply #23 on: September 05, 2019, 01:17:31 am »
thank you
Offline Whitey
« Reply #24 on: September 05, 2019, 03:28:02 am »
They sure are. I "wasted" a few dollars on other lights before pulling the trigger getting the stedi.  SO impressed by them especially for their size.
