Author Topic: PIAA 1100 LED lights and PCA mirror mounts installed!!  (Read 12447 times)
Offline Wyorider
  • COG#: 10331
Re: PIAA 1100 LED lights and PCA mirror mounts installed!!
« Reply #25 on: January 22, 2015, 11:54:01 pm »
Got the lights from Hyperlights.com.
  Installed them with some left over brackets from my Lunasee kit.
I had some bullet lights from Cree but they were to heavy and I had two break off.The brackets are just aluminum.
Offline ZG
  • COG#: 9735
« Reply #26 on: January 23, 2015, 05:50:52 pm »
Got it, thanks WR!  :great: :beerchug:
Offline Caffeinated
« Reply #27 on: January 30, 2015, 08:45:43 pm »
Nice earrings to go with the red lipstick  :rotflmao:
might want to also check out Skene Designs http://www.skenedesign.com Photon blasters for the front and P3 for the back. I have the yellow phonton blasters in the front with turn signal and flash alert mounted down on the fender bolts (comes with the mounting hardware) and the P3 in the back with turn signal function. HID's, MM10 leds on the Canyon's and the Skene lights, I'm certainly noticed coming and going!
Chris
Bristow, Va
2012 Black Concours 14
2011 Silver Concours 14 (Totaled)
2002 Silver Concours (sold)
Offline Sailor_chic
« Reply #28 on: March 23, 2015, 12:03:02 am »
Here are my newly mounted Danali D2 lights with the PCA mounts. Sorry my bike is so filthy. Thats tomorrows project!
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline ZG
  • COG#: 9735
« Reply #29 on: March 23, 2015, 01:57:05 am »
Lookin good SC!  :great: :beerchug:
Offline Lonnie
  • Go far and get lost.
  • COG#: Forum Subscr
« Reply #30 on: March 24, 2015, 01:12:40 am »
I am wondering how you ran the wire's up through the mirror brackets, did you make the slots and what did you use. Drimel or something else. I might have to have one of those garage days here at the house and get them installed. :)
Offline ZG
  • COG#: 9735
« Reply #31 on: March 24, 2015, 12:17:04 pm »
The mirror bases are hollow, just drill a hole and feed the wire through.  :beerchug:
Offline Sailor_chic
« Reply #32 on: March 24, 2015, 12:30:27 pm »
If I might add... Also cut the expensive plug off of the end of the wire and void your warranty, before you feed the wire through.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline Lonnie
« Reply #33 on: March 24, 2015, 08:40:25 pm »
I know better than that, I'm kind leary when it comes to cutting or drilling on something like this. Just thought they may have some good suggestions on doing it. I'll take it from here.
Offline Rony6ble
  • COG#: 12513
« Reply #34 on: March 13, 2016, 05:20:48 am »
Lonnie, I'm planning on get a couple of DX under the mirror. What was the fix for drilling and get the plug off through?
Concours 14 2011
Concours 14 2009 RIP
GPZ 400 & Ninja 250
IBA# 57875 COG# 12513
Offline Lonnie
« Reply #35 on: March 13, 2016, 01:40:48 pm »
I didn't mount mine to the mirror's, I never could get the bolts to brake loose so I attached mine to the side of the bike just under the mirror's.
Offline Woody
  • COG#: 12243
« Reply #36 on: March 18, 2016, 03:24:21 pm »
I have the PCA mirror mounts and D2's still sitting in my closet. Would someone give an ideal on the proper way to drill the holes for the wiring harness and also getting the the clip off in order to get the harness through the drilled hole? This is something I really don't want to screw up on.
Offline Sailor_chic
« Reply #37 on: March 18, 2016, 04:09:54 pm »
Of my old memory serves me correctly, I believe that the wires are molded into the plug and won't come out. I know you don't want to hear this, but I cut my plugs off.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline Woody
  • COG#: 12243
« Reply #38 on: March 18, 2016, 06:01:58 pm »
If that's what I have to do so be it. Sure that will void the warrant though. I need to just get out there and get it done...   lol
