Author Topic: PITTBULL Hybrid Headlift Stand  (Read 5446 times)
Offline Christopher
Re: PITTBULL Hybrid Headlift Stand
« Reply #25 on: August 31, 2017, 03:07:53 am »
*Hold the left side of the axle from spinning*  after i remove the coter, while loosening the castle nut, will the whole axle spin? Do i need to hold the left side?
Offline COGnosticator
  • SE AAD
  • COG 4478
  • COG#: 4478
« Reply #26 on: August 31, 2017, 07:46:20 am »
As far as the rear wheel, is it necessary to hold the left side when loosening the castle nut?
TYIA :)
I just changed my rear tire and, no I did not have to hold anything on the left side to loosen the castle nut
Jerry Holland  COG  4478
Offline Christopher
« Reply #27 on: August 31, 2017, 10:30:41 am »
Thanks man  :)
Offline Deepsea
« Reply #28 on: August 31, 2017, 02:47:47 pm »
You may not "Need" to hold the axle when removing the Castle Nut but you will need to hold it when re-torqueing it. Don't just get it "Tight enough" use a good torque wrench.
Retired Navy Saturation Diver
Offline Christopher
« Reply #29 on: August 31, 2017, 10:52:34 pm »
Crap, what size allen is it? 12? 14MM??  Being a former Master Auto tech, i own 4 Snap-on torque wrenches :)
« Last Edit: September 02, 2017, 11:09:14 am by Christopher »
Offline JDSCO
  • 2016 C14
« Reply #30 on: September 01, 2017, 04:56:48 pm »
^14
Use a 14mm bolt hex head with some nuts to use as hex wrench if your in a pinch
Gen James Mattis
Offline Christopher
« Reply #31 on: September 02, 2017, 08:05:21 pm »
Thanks! Turns out i had a 14MM hex socket. Had to hold it to get 94 ft lbs..
