Author Topic: Pre 2010 tank cubby box  (Read 1671 times)
Offline wyomingpat
  • Concours 14 newby
  • I look nothing like Gyneth
    • My Martial Arts website
  • COG#: 11232
« on: July 04, 2014, 01:30:41 pm »
I have a 2013. Has anyone fitted that cubby box they had on the pre2010s? Does it fit and where can I get one? Also seems that the righthand top fairing panel could accommodate something as there is loads of space underneath. Any ideas? Radio, Storage, Gun holster!
Pat
Offline mattchewn
Re: Pre 2010 tank cubby box
« Reply #1 on: July 04, 2014, 01:46:03 pm »
Pat,
On the 10 up models there is a relay harness that would need to be relocated in order to clear the center cubby. Probably not impossible to move. Under the right side is where a lot of the CC actuator housings get mounted. then there is no extra space under there.
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #2 on: July 04, 2014, 02:38:04 pm »
If I remember right, I think several members have added the pre 2010 glove box to the 2010-2014 bikes.  I think that Fred Harmon actually did a write up on the mod. and there should be several posts from other people that have done the mod.  I would try a search.
Fred
Wa2gzw
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #3 on: July 04, 2014, 03:12:33 pm »
Ok I found a link with pics on the other forum.  About half way down page 2 posted by 556Alpha you will find step by step instructions including pics.
http://www.zggtr.org/index.php?topic=1855.15
Fred
Wa2gzw
Offline Spackler
« Reply #4 on: July 05, 2014, 11:18:52 pm »
I have the tank top storage box on my '09, I'm going to remove it and install the 2010+ cover in order to install pullback risers.
You need to not only get the tank top storage compartment but also the relax bracket, as someone as pointed out. And maybe some creative installation.
Offline RS
  • COG#: 9763
« Reply #5 on: July 06, 2014, 09:32:49 am »
Pat,
I suggest you get a tank bag and save yourself a lot of money, time, and aggravation. Seriously the ""glove box "" is essentially useless. Does anyone else agree?
Richard
Offline gPink
  • MMVIII C XIV
« Reply #6 on: July 06, 2014, 10:38:04 am »
Pat,
Richard
It's a sandwich warmer and a cell phone killer and screws up the use with a tank bag.
Offline freebird6
  • COG#: 11012
« Reply #7 on: July 06, 2014, 12:43:59 pm »
2008 here.....I can get my sunglasses, a credit card and a couple of allen keys in there. Cell will overheat in there. I do keep a little USB adapted for the 12v in there also. I agree on the tank bag. Would not mess with it.
Offline dixie
  • whatcom
  • whatcom
« Reply #8 on: July 06, 2014, 05:06:16 pm »
Having come from 80k on an 08 to a 12 and used the top glove box all the time, I orderd all the glove box parts right away from powersportswarehouse.com for an 09. It came to a little less than $200 as they are about 40% less than retail. Took all the relays, wrapped them in rubber tape and laid them behind the left storage box behind the little wall. Had to take the pan of the top golve box and dremel out where the new brake lines are to make it fit flat, worked perfectly. Looks and works like stock!!!! 25k later and still smiling every time i use it.
Offline TLR
  • COG#: 11171
« Reply #9 on: July 06, 2014, 06:00:46 pm »
Have a 2009 and find the tank box somewhat useful, for a tire gauge, micro-fiber rag, registration and license in a zip-lock baggy, and a Leatherman tool.  But, those things get really hot!   I don't put the iPhone in there!
Not to hijack Wyomingpat's thread, but has anyone fitted a 2010+ left inner cover to a 2009, to get the extra storage box?  Seems like there would be room there for the storage box, and the 2010+ inner cover might fit there.
1982 Suzuki SP250Z
1994 Suzuki VS800GL Intruder
2009 Kawasaki Concours 1400 (the fast red color)
Offline Gypsy JR
  • American Gypsy
  • Living the Gypsy Life
  • COG#: 9279
« Reply #10 on: July 06, 2014, 06:03:18 pm »
At least in 2010, when KHI changed the tank dash cover to not have the cubby box, they put "prongs" on it for forward tank bag straps, making it easy peasy to put a strapped tank bag on.
On my ZX14 I had to reach down along the forks and find an upper fairing member to hook the straps too, so when I got the 2012 C14 I really liked the forethought put into the new tank cover.
Offline TJ
« Reply #11 on: July 06, 2014, 06:24:27 pm »
I would buy the small Chase Harper over installing the box.  It is portable, will not overheat, and costs less.
Offline wyomingpat
  • Concours 14 newby
  • COG#: 11232
« Reply #12 on: July 06, 2014, 07:28:00 pm »
Thanks guys for the excellent response - If it had just been a few screws it would be worth it but it sounds way more complex for little benefit.
Thanks again!
Pat
Offline Mad River Marc
  • COG#: 8442
« Reply #13 on: July 07, 2014, 06:03:00 pm »
It's been done but it's a pain in the backside
Offline freebird6
  • COG#: 11012
« Reply #14 on: July 08, 2014, 02:11:37 pm »
OFten wondered that also
Offline dixie
  • whatcom
  • whatcom
« Reply #15 on: July 08, 2014, 02:47:15 pm »
It is not that bad! Dremels are pretty cheap, did not think it was too complicated. I have the full areaP and the box and fairing does not get hot anymore. In fact, the fans hardly ever come on anymore, the whole bike is pretty cool running. When i had the stock exhaust, then it does get pretty warm in there, lots of heat!
