Author Topic: ProjektD Helmet locks  (Read 1614 times)
Offline ron203
  • COG#: 9847
« on: August 08, 2018, 10:48:55 pm »
Anyone happen to know if these bolt up to Phil's Rack?
Thanks.
2014 C-14
2008 Goldwing
Offline ErikS
  • COG#: 10322
Re: ProjektD Helmet locks
« Reply #1 on: August 09, 2018, 02:41:26 am »
I just installed ProjektD helmet locks and I have a Phil’s Rack.  They don’t actually bolt to the rack, they come with a thin metal mounting strip that spans across under the Phils Rack and mounts to the same screw holes that the Phils Rack (or stock Rack for that matter) mounts to.  They are of good quality and work well.
"No hour of life is wasted that is spent in the saddle." - Winston Churchill
2014 BMW R1200GS Adventure
(Past Rides: '08 C14, '99 C10)
Offline ron203
  • COG#: 9847
« Reply #2 on: August 09, 2018, 11:06:47 am »
Excellent! Thank you for the quick reply. I've gotten "hooked" on the helmet locks on the Goldwing and these look very similar. Thanks ErikS.
2014 C-14
2008 Goldwing
Offline Bumblebee
  • COG#: 12745
« Reply #3 on: August 09, 2018, 11:31:05 am »
I agree with ErikS.  I have installed these helmet locks with Phil's rack.  Both are excellent additions to the C14.  The only thing I might mention is that you will need four slightly longer bolts (5mm longer) to install both the rack and the lock to the bike.  ProjekD supplies the appropriate hardware but I was not happy with it - call me fussy - and opted for a Kawasaki replacement which may (or may not be) sturdier but certainly looks better.
2015 Black C14
Offline ErikS
  • COG#: 10322
« Reply #4 on: August 09, 2018, 12:48:40 pm »
I agree with Bumblebee about wanting slightly longer bolts than ProjekD supplies when installing helmet locks with Phil’s Rack, I should have mentioned that but forgot.  I went to HW store and got some hex head bolts that were slightly longer.  Just brought along one of the OEM bolts to ensure correct diameter and thread.
Offline ron203
  • COG#: 9847
« Reply #5 on: August 09, 2018, 07:33:24 pm »
Good info. I wondered about that. Thanks guys. Mission on!
2014 C-14
2008 Goldwing
Offline Sailor_chic
« Reply #6 on: August 11, 2018, 02:08:58 pm »
And if you get lucky, they will be the same key blank as your ignition. ie: A or B. Was arrived being the same, and I had a locksmith re-key them.
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline ron203
  • COG#: 9847
« Reply #7 on: August 11, 2018, 02:11:10 pm »
Cool. Thanks.
2014 C-14
2008 Goldwing
