Author Topic: Question about handlebar risers  (Read 1453 times)
Offline slidebite
  • There is no "e" in "Concours"
« on: September 12, 2011, 03:52:11 pm »
I recently picked up a 2010 KTRK (with a whopping 1400KMs on the clock!) and the previous owner had put some risers on it. I've ridden for a week or so and another 1400K with them but think I might want to try the bike without them to see if I prefer the geometry.
Question is, will I need new, shorter bolts or should the existing ones work? They're about 1-3/4" risers. Also, does anyone know what the torque should be for them?
Thanks!
Re: Question about handlebar risers
« Reply #1 on: September 12, 2011, 06:07:15 pm »
You will need the shorter OEM bolts. If nobody chimes in first, I can probably give you the part numbers and torque values later when I get home.
Offline slidebite
« Reply #2 on: September 12, 2011, 06:11:00 pm »
Thanks for the reply!  I actually think I've got a torque value of 18ft/lbs from another source.
As for the shorter bolts, I'm going to take one out and go to a local specialty fastener shop and see if they have something. If not, I'll order some in from Kawi.
Appreciate it
Offline Dayrunner
  • COG#: 9781
« Reply #3 on: September 13, 2011, 03:51:34 pm »
I have the stock bolts I removed to put on risers if you live within the Portland area! I will not be putting them back in the bike, just let me know!
 :beerchug:
Tony (aka Sarge) Ret USARMY
"I can not control what happens in my life, but I can control how I react"
Offline slidebite
« Reply #4 on: September 14, 2011, 12:21:57 am »
Thanks lots. I actually got some proper stainless 8x25 stainless bolts at that fastener place. Appreciate the offer though.
I'm going to try it without the risers for a bit and see how I like it. If my hunch is right, a 1-3/4 riser set will be in the classifieds soon! :)
Offline Jagman
  • COG#: 9631
« Reply #5 on: September 14, 2011, 02:40:43 am »
Let us know what you think.  I have played around with lots of different variations and always curious to hear others opinions.
