Author Topic: quietest swlipon exhaust  (Read 11593 times)
Offline Jagman
  • COG#: 9631
Re: quietest swlipon exhaust
« Reply #25 on: August 07, 2011, 07:55:37 pm »
Guhl motors. Friendly and fast service.
Mick
Mike I was under the impression that Guhl only flashed the ECU for stock exhaust.  I have been wanting to send him my ECU from my Vance and Hines CS1 equipped bike but he doesn't have a specific MAP for it yet.  Did you just do the reflash for the stock exhaust on your Area P bike?
If so, sounds like what I had actually thought; that since my bike runs very well with the CS1 with no fuel adjustments etc, that the stock exhaust reflash should work fine for aftermarket.  Having said that I do have a very minor amount of decel pop with VH but not bad.
Offline mick6777
« Reply #26 on: August 07, 2011, 09:30:58 pm »
Jag,
I'm not as into the details as some. I wanted low end torque that I knew was missing, and has been missing from every stock bike I have ever owned. I consulted my friend, who is on here, Tundra Tom. He recommended butterfly removal and an Area P. Then someone else recommended the re-flash. That was appealing because I didn't have to tear the bike apart.  When I do the basic mods of PC and slip on, I'm very happy. That is enough for me. I don't run dynos and go crazy into the details, but I'm grateful to those that do. I do my research, go for what I believe to be the best mods, and that works out great for me.  I spoke to Don about using an Area P slip on, and he assured me I would get a noticeable improvement. He was right. I'm not sure what map he used, but if you call him he is very friendly and will answer any questions you have. Interestingly he said the Area P full pipe actually performs slightly worse, which made the decision to do the slip on a real no brainer! Compared to doing a jet kit or even a PC this is way easier!
Mick
Offline mick6777
« Reply #27 on: August 07, 2011, 11:20:34 pm »
Area P. A thing of beauty.
Mick
Offline Jagman
  • COG#: 9631
« Reply #28 on: August 08, 2011, 12:39:38 am »
That is a great looking pipe!
I have spoken to Don and to your point,  he didn't say his stock pipe map wouldn't work well on my CS1 equipped bike, he just asked "how is the bike with the slip on running now?"  Seem's like a reasonable question when considering whether or not his re-flash would work well for after market slip on's.  He and Fred H have basically said the same thing; that it was likely the stock map would work just fine for the majority of slip on's but to gain maximum performance a map specifically for that muffler would be ideal.  My experience in the past has been that slip on mufflers do not require much if anything in the way of fuel mapping, only when you full exhaust changes are made is it abolutely necessary to re tune.
 I'm very eager to get it done though, even have considered putting the stock can back on.
Offline Tall Paul
« Reply #29 on: August 14, 2011, 05:49:33 pm »
Hey, I have an idea. If you want a motorcycle for the sound of it, go buy a Harley. I love the way mine sounds and love the way it rides even more. I do believe I will keep my Kaw C14 and quietly blow by the loud Harley riders. :)
Offline Peter
  • COG#: 769
« Reply #30 on: August 14, 2011, 07:31:57 pm »
I recently put the Area P Carbon slip on pipe on my 2011 C14.  I love the looks, it is a very good quality pipe, and went on smoothly by following the directions supplied.
It is barely noticeable in sound from the seat while riding, and at idle has a nice sound.  It does seem to have gotten a bit louder after putting some miles (perhaps about 1,000) on it, but it is not annoying.  Sometimes I wear a half helmet and it is not objectionable with that on either.
I had noticed the inside rear corner of the right bag got VERY hot with the stock pipe, and with the Area P just slightly warm.
Area P claim a 15 lb weight reduction and I would tend to agree.  The stock pipe is VERY heavy comparatively.
1993 Honda CBR1000F
1998 Triumph Adventurer
2011 C14 ABS
COG member # 769
Offline Tundra Tom
  • XLR8
  • COG#: 8925
« Reply #31 on: August 16, 2011, 02:10:08 am »
Jag,
Mick
Honestly if the re-flash would have been available "back in the day" I would have gone that route. As it is I'm still satisfied, the C-14 really is muted on the bottom end as stock.
1974 Kawasaki H-1 500
1975 Norton 850 Commando
2013 BMW GS 650 Sertao
2008 Suzuki Bandit 1250
Offline wally_games
« Reply #32 on: August 24, 2011, 01:43:36 am »
Ok. I recorded two short videos with the new Leo Vince installed; one with and one without the dB insert. This exhaust comes with the insert installed at no extra cost (unlike the other slipon options) There's also one of the stocker, for comparison.
I really like this exhaust with the insert installed. It has a nice sound, not too loud, and doesn't drone while at speed.
With dB insert:
Without dB insert:
Stock:
Offline ZG
  • COG#: 9735
« Reply #33 on: August 24, 2011, 03:42:52 am »
Sure looks alot better WG!  :great:
Offline wally_games
« Reply #34 on: August 24, 2011, 03:51:45 am »
That was the first reason I got the slipon, looks. Second was sound. You don't realize how really big the stock pipe is until you lay it on the ground next to the bike with the new one installed!!
Offline Loren
    • Baldwin Motorbike Saddles
  • COG#: 9775
« Reply #35 on: August 24, 2011, 10:56:29 am »
WG, thanks for posting the videos.  I sure like the looks of the Leo Vince.  One of those is on my Connie farkle wish list.
« Last Edit: August 24, 2011, 03:50:05 pm by Loren »
Loren
www.MotorbikeSaddles.com
Offline cablebandit
« Reply #36 on: August 24, 2011, 08:36:33 pm »
You sure the db insert is in there?  I don't see the reduced exhaust opening like the insert that came with mine.
Offline wally_games
« Reply #37 on: August 25, 2011, 03:17:45 am »
I took several videos. I think I posted one without and two with the insert. Can you post a pic of yours for comparison.
Offline cablebandit
« Reply #38 on: August 25, 2011, 11:59:53 am »
With...
Without...
Offline wally_games
« Reply #39 on: August 25, 2011, 04:33:43 pm »
Yep. That's what mine looked like.
Unless I posted the wrong versions of the "with" and "without" videos. Guess I better go look at YouTube again.
On another note. Is there a "secret" to getting that rubber stopper back into the insert bolt's access hole?
Offline cablebandit
« Reply #40 on: August 28, 2011, 12:11:10 pm »
Spit
Offline Loren
  • COG#: 9775
« Reply #41 on: August 31, 2011, 09:49:12 pm »
I had a Leo Vince titanium arrive today.  It was a quick install and it is pretty darn quiet with the db silencer installed.  I like a quiet exhaust but do not like the huge stock can, so this will fit the bill real nice.  Again Wally thanks posting up the videos.
« Last Edit: September 01, 2011, 02:34:54 am by Loren »
Loren
Offline wally_games
« Reply #42 on: September 01, 2011, 04:06:03 am »
You're quite welcome. Glad they could help.
I rode last weekend with the insert installed. It's very quiet (not potato launcher quiet, but...) and I liked it a lot. I'm going on a trip this coming week and I pulled the insert just for grins. I'll be taking it along just in case I find it to be too loud without it. I'll post my impressions when I get back.
Offline 911ZG guy
  • COG#: 8019
« Reply #43 on: September 03, 2011, 08:23:36 pm »
 I would like to hear a Leo Vince with insert right next to a CSOne with insert(IF anyone ever gets the CSOne insert).
 Where is the best (cheapest) place to by the LV?
Offline wally_games
« Reply #44 on: September 04, 2011, 02:58:27 am »
www.pipecity.com is cheapest I could find and customer service was awesome.
Offline wally_games
« Reply #45 on: September 04, 2011, 03:58:47 am »
Our trip to Deal's Gap this week got re-routed due to weather. I removed the insert from the Leo Vince today on some great roads around Eureka Springs, Arkansas. Barely heard it although there is a nice burble on decel. I'll probably put it back in this week and see how I like it, but the insert made it very on my test rides last week.
Offline Jagman
  • COG#: 9631
« Reply #46 on: September 04, 2011, 12:37:34 pm »
We're heading to Eureka Springs next Month from DFW.  I can't wait to get on some of the roads after riding around here all Summer.  I can't hear my Vance and Hines CS1 without insert either at full cruise unless the windshield is all the way up, and even then it's a very muted purr.
Offline wally_games
« Reply #47 on: September 05, 2011, 03:15:19 am »
Find 123 south of Eureka Springs!!!! Amazing road. Will give you more detail when I get home and can get to my laptop.
Offline Tundra Tom
  • XLR8
  • COG#: 8925
« Reply #48 on: September 05, 2011, 12:25:40 pm »
The Area -P has gotten noticably louder of late. 30,000 miles on it and will be re-packing it this winter.
Offline mick6777
« Reply #49 on: October 29, 2011, 11:22:40 pm »
I find the Area P slip on to be just right. Don't feel it's too loud on the highway at all. It's got a nice bark when you get on it, but not too much.
Mick
