Concours 14 Discussion (C14 / ZG1400 / 1400GTR) => Accessories C14 => Topic started by: 56taskforce on October 22, 2017, 02:42:05 pm
Title: Rear fender NOW GROUP BUY!!!
Post by: 56taskforce on October 22, 2017, 02:42:05 pm
I am preparing to commute year around on my C14, being a brand new machine I would like to do everything I can to keep crap out of the nooks and crannies. I have looked at a few rear fender opinions however this one from Project D is the only one I found that isn't just an extension of the factory fender and doesn't add protection for the shock and back of the engine. http://projektd.com/product_info.php?products_id=123 (http://projektd.com/product_info.php?products_id=123)
This Fender from Project D looks like a fine piece, and does exactly what I was looking for but the price is ridiculous!!! Anyone know of a more cost-effective option to this fender??? I would like to use something like this fender in conjunction with one of the Factory Fender extenders for complete protection.
Title: Re: Rear fender
Post by: 56taskforce on October 22, 2017, 04:29:19 pm
Oh I found Project D has one made of fiberglass with a more reasonable price but still a little spendy. http://projektd.com/product_info.php?cPath=27_58&products_id=124. (http://projektd.com/product_info.php?cPath=27_58&products_id=124.)
Murph you need to make one and put it together as a package deal with your front and rear fender extenders!!! If you do put me at the front of the line please!!!
Post by: gsun on October 22, 2017, 05:03:12 pm
I have the Projektd in fibreglass. It is really worth the money and when you see it, what's involved in making it and the mounting hardware, I think the price is not bad at all. With that I don't know that you would need a read fender extender. Don't really like the looks either. The front extender works great.
Post by: 56taskforce on October 22, 2017, 05:31:41 pm
Thanks for your response. Does this fender keep the spray off the back of the bike and rider as well as out of the back of the swing arm?
Post by: MAN OF BLUES on October 22, 2017, 06:34:33 pm
Road spray and grit up the back of this bike is attrocious, if you ride on roads with dirt and in the rain...  I have to hose down my trunk box after a two day trip if raining just to get my trunk key to work...
 There is a large rear add on that works well tho...
http://forum.cog-online.org/industry-member-cog-offerings/concours-(c14)-fender-extenders-front-and-rear/msg102894/#msg102894 (http://forum.cog-online.org/industry-member-cog-offerings/concours-(c14)-fender-extenders-front-and-rear/msg102894/#msg102894)
Pretty affordable, and if you use some lternate mounting thought, you can make it easily removable for changing rear tire, by using small screws with nylok nuts to install it..
As for that huge "gap" at the front of the rear fender, a small "mudflap" can be easily fabricated from an old innertube, and pop riveted to the lower lip up there, it is inconspicuous, and will keep that rectifier box and associated are much cleaner...
Post by: JTX on October 22, 2017, 11:02:41 pm
I am preparing to commute year around on my C14, being a brand new machine I would like to do everything I can to keep crap out of the nooks and crannies. I have looked at a few rear fender opinions however this one from Project D is the only one I found that isn't just an extension of the factory fender and doesn't add protection for the shock and back of the engine. [url]http://projektd.com/product_info.php?products_id=123[/url] ([url]http://projektd.com/product_info.php?products_id=123[/url])
I am using this project D from the UK. I think you can find it state-side for a little better price than that though.
When I installed it, I could NOT get the fender to install with equal clearance on each side. It was frustrating. I like %hit to be even.
I tightened things down per the instructions, not overly done.  The tire gets close to one side and its not perfectly straight, however, this fender has not budged or moved, or caused me any trouble since I installed it two years ago.  So far so good. Tire/wheel comes out without having to take fender off.
I ran through some fresh asphalt in Montana back in 2016 and it was nasty.  I just now several months ago got around to taking apart the lower fairing and getting all the gravel out of the fairing.
However this fender still did not prevent slinging all that oil up under the tail and I still got a dirty rear pack.   I never bothered to try to clean it off under the tail section.  I Figured it was pointless anyway and I would have caused another mess below it by trying to dissolve it with something.
I did get it though, for the same reason you want one, to keep the shock as clean as possible and avoid hits with rocks. I think the voltage regulator is under there too.
  So far so good though.  Nobody else makes one that I know of for the C14.
(https://i.imgur.com/m53sZeU.jpg)
Post by: gsun on October 23, 2017, 03:14:56 am
You will always get some dirt/grit on the bike but this stops most of it. No spray coming up that affects a rider or passenger that I have noticed. Mine is crooked too. I tried to straighten it when first installed but it wouldn't go. The nuts look really close to the tire but do not hit and no problems. Design I guess.
Post by: JTX on October 23, 2017, 09:23:29 am
Well, Like I said, after a 6000 mile ride, I had a line of dirt on the back of my rear pack from the back tire.  I guess theres just too much being thrown off the back tire and the rear packs set back far enough that it still got it dirty.   The Project D fender is really not that long and still lets some spray go forward.
   But it didn't get it all over the shock and voltage regulator which was what I was hoping for.
Post by: 56taskforce on October 23, 2017, 11:31:53 am
Well I had broke down and started ordering the Projekt D fender till it came to shipping charges, Holly Crap!!! I think I'll be making my own. It was too expensive to start with and when shipping charges double the price I find an alternative...
Post by: JTX on October 23, 2017, 12:21:50 pm
I dont think mine came from the UK.
I will look for the retailer i got it from im the US.   If i forget, PM me.
Post by: Daytona_Mike on October 23, 2017, 01:01:13 pm
[/quote]
[/quote]
OH Hell No!!  I have that setup on my bike  in Carbon Fiber and it looks really nice however- it does nothing but make a big huge mess in any  rain or even a wet road-
 It reminds me of Pig Pen on Charlie Brown.
My back and the seat behind me will be full of little bits of gravel and dirt.  Do not remove the existing rear fender unless you want to make things far worse.
I cant figure out why I have this cloud of mist and cr@p coming up in to my face from around the fork tubes but I know it started only after I installed the rear hugger
Post by: JTX on October 23, 2017, 01:11:23 pm
I didn't experience anything like that.
Post by: robertv on October 23, 2017, 01:41:36 pm
I forgot all about Blue One's rear fender that MOB posted!! I have the front fender and that I like since it wasn't too bad to install. I'm going to try the rear since I've been commuting more.
Post by: Daytona_Mike on October 23, 2017, 01:54:36 pm
Yes!  That is what you want.  I like the look of the open wheel but functionally it really does suck. Just look at my picture.  No way does it help with anything other than looks. I do tend to run  grippy tires which will pick up and toss small rocks at anyone following me. Those tires you see in my picture are Pirelli Diablo SuperSport . Very very grippy even in rain but they wont last more than 2k miles..
Go with the fender extenders- those work.
Post by: MAN OF BLUES on October 23, 2017, 08:11:09 pm
 :great: :great:
I really like the looks of that part, and would be running one myself, but as I've installed a trailer hitch, I would have to modify things a bit to make it fit... which I really hate doing.
I know it will keep that roadspray in check tho...
Post by: Derek on October 24, 2017, 12:27:05 pm
I bought the extender on from Blueone but thought it was a little too big/long.  After seeing SiSF I cut mine down by about 1"=1 1/2".  Still give good coverage but doesn't look so big.
I'll try to post a picture later today.
Post by: robertv on October 24, 2017, 01:54:33 pm
Would like to see the modified rear fender pics. I agree it does look a bit bulky. Thanks!
Post by: connie_rider on October 24, 2017, 03:15:11 pm
I have the fiberglass inner fender hugger on my bike.
I agree, it does nothing at the rear for water sling, but it does help keep things cleaner up front. {Shock linkage etc}
I have the 55 series tire and it is "very" close, but does not touch.
When I bought mine, I contacted the US rep for Project D and he helped me set up a group buy for COG.
He was very helpful..
I'll try to dig up that information if your interested?
Post by: NYbiomed on October 24, 2017, 05:12:38 pm
I reached out to ProjektD about a year and half ago to set up another group buy as a follow up to yours, but could only manage a 10% discount- I was even gonna have everything sent to me to redistribute by USPS to save more 'cause individual shipping is kinda ridiculous, but couldn't match your 20% discount, therefore the savings wasn't really substantial enough, so I never moved forward with it....But the US rep for ProjektD huh.....wanna reach out to him and try that group buy again? I know im im for a helmet lock and I've wondered if the AeroForm Luggage Rack-Backrest can be retrofitted to work with  my Laam/Phil's rack combo 'cause my kids and wife would love a back rest! but it's a bit steep at $199
http://projektd.com/product_info.php?cPath=27_58&products_id=133 (http://projektd.com/product_info.php?cPath=27_58&products_id=133)
Post by: connie_rider on October 24, 2017, 05:24:28 pm
I'll try to find out who I contacted back then.
As I recall, I had to promise X amount of buyers to get him to do the 20% on the fender.
And, I think it was a Christmas deal.
It's not a 20% off on everything. Only the item he agreed to.
To get 20% on the backrest we would have to do the same. {X amount of buyers}
Ted
Update: here was the previous Group Buy;
http://forum.cog-online.org/c-14-emporium/group-buy-for-rear-innerhugger-fenders-from-street-fighter/msg402418/#msg402418 (http://forum.cog-online.org/c-14-emporium/group-buy-for-rear-innerhugger-fenders-from-street-fighter/msg402418/#msg402418)
As I sed, we had to buy a minimum of 6 fenders...
At that time, the fenders cost us $144 plus $10 shipping...
Did you contact??
   David Cork; (1) 772 597-3207
    sbd@davidcork.com
    www.streetfighterbydesign.com (http://www.streetfighterbydesign.com)
    http://www.streetfightersbydesign.com/ (http://www.streetfightersbydesign.com/)
Post by: NYbiomed on October 24, 2017, 06:20:17 pm
^^^ohh, didn't know it was one specific item that was 20% off. IDK who I reached out to now- it was really just sent to a general CONTACT there....aren't they in SE Asia someplace? Thailand?? and yeah, I recall something about X amount of orders/merchandise....perhaps it was even closer to 2 years ago now...details fuzzy...well, it's nearly getting to be that Holiday time of year again.....hint...hint, HINT  ;D
Maybe a new thread is warranted to gauge interest?
Post by: Derek on October 24, 2017, 09:09:13 pm
(https://preview.ibb.co/fzF01R/IMG_9357.jpg) (https://ibb.co/jrjtMR)
Post by: 56taskforce on October 29, 2017, 09:38:10 pm
Please -O-please Ted!!! If we can't strike a deal or they can't figure out better pricing and cheaper shipping then I think I may have to go into fender manufacturing...
Post by: connie_rider on November 02, 2017, 02:42:33 pm
Ok, I can try to contact David about a {fer Christmas} COG group buy.
Before I get too carried away, how many would be interested in one of the Hugger fenders?
We would need 5 - 6 folks to convince him.
Post by: 56taskforce on November 03, 2017, 02:24:30 am
Well I had started to order one until the shipping pretty much doubled the price... So depending on price I may be in
Post by: OKC14 on November 08, 2017, 06:53:39 pm
The same unit that Projektd sells is available direct from the manufacturer at https://www.pyramid-plastics.co.uk/accessory.html?accessoryCode=651 (https://www.pyramid-plastics.co.uk/accessory.html?accessoryCode=651)
There's also a comparable unit made with carbon fiber from Skidmarx.  Search 'Skidmarx GTR1400 hugger' on Google and it'll be the first result.
Post by: 56taskforce on November 09, 2017, 02:51:25 am
A little cheaper than Projekt-D but still $73 shipping. I find that to be ridiculous.
Post by: Deepsea on November 09, 2017, 03:28:41 am
I'm moving to Germany in 3ish weeks. I'll get one then. :) :nananana:
Post by: connie_rider on November 13, 2017, 03:25:18 pm
Ok, I called David. (I've been waiting to see if more express an interest in buying an Inner Fender}
David is no longer in the business of Motorcycle parts.
But he still has a connection in England and is willing to try to work something out for a group buy.
   {The biggest problem here is the shipping costs from England to USA}
He's currently checking prices to see what the cost would be to him.
If we can get 5 - 10 that want in on a group buy, he'll have them all sent to him as a batch (to save shipping costs) and offer them to us at the best price he can. {Plus shipping to your door}
I'll get that cost from him in a few days, and post it here..
So, the question is; Who wants an inner fender??
For now,,, Do not contact him.
  I'll co-ordinate the list from this site. (If we can get the 5-10 folks, I'll give everyone info on how/when to contact him).
Post by: Deepsea on November 13, 2017, 05:05:32 pm
The timing doesn't work for this buy, but since I frequently fly between the US and Germany if enough people (2 or more) want something I"m amenable to being used as a pack animal :D . But please don't ask for a complete motorcycle, just pieces. :) . I'll try to remember and post ahead of time for upcoming trips.
Post by: LURCH on November 14, 2017, 12:08:34 am
Just curious if you're still going to Germany if you are any chance I could get you to bring back a left and right
1400GTR Emblems ?
Post by: sam_uk on November 14, 2017, 05:50:43 am
Maybe of some interest to you. http://www.pandpbodyworks.co.uk/item/id/105/Kawasaki+GTR1400+rear+hugger (http://www.pandpbodyworks.co.uk/item/id/105/Kawasaki+GTR1400+rear+hugger)
Post by: The Pope on November 14, 2017, 10:20:47 am
Ted, sign me up. I'd prefer a Carbon Fiber one, but would settle for the Plastic or Fiberglass it that was all that was offered.
Also.... this does depend on the total cost.
Post by: Staylo on November 14, 2017, 11:19:28 am
I’d be interested.
Post by: connie_rider on November 14, 2017, 01:21:45 pm
Thanks Sam. That appears to be the same one I have on my bike.
                 I think %94 is about $145?? (plus shipping)
Pope/Staylo, thanks for replying. I'll post info here as I get it.
NOTE: During the last group buy (in 2014) list price for the fiberglass was $170 and the Carbon Fiber was $270. {plus shipping from Eu}    :-\
I think David was able to get the fiberglass for us at about $150. (total)
We'll see what he can do for us soon...
Ted
Title: Re: Rear fender NOW GROUP BUY!!!
Post by: 56taskforce on November 14, 2017, 10:40:28 pm
^^^Ted has made it a group buy!^^^
Post by: JDSCO on November 14, 2017, 10:51:33 pm
I'm definitely in.
Let me know?
Post by: OKC14 on November 15, 2017, 01:40:56 pm
I'd be in for a group buy as well.
Post by: turbojoe78_MA on November 15, 2017, 01:51:58 pm
Does the stock rear fender stay on, and this inner "hugger" fender go on in addition to protect the rear shock area?
Post by: Bigfoot_16 on November 15, 2017, 02:01:04 pm
Yes, that's correct. You can see photos of this on sites such as ProjektD.
Post by: connie_rider on November 15, 2017, 02:03:52 pm
Yes, the stock fender/etc. stays on.
The hugger comes with all hardware to install onto the swingarm.
Not the easiest installation to get it straight, but do-able.
I just talked to David again. Told him we already had 5-6 that want in.
He said the manufacturer isn't helping him much. {as he no longer sells motorcycle parts}
But David agreed to try again, and see if he can talk them into a good price.
NOTE: He's going out of his way to try to help us. Good guy!
He offered a name of a company that also might have Huggers in the USA.
Said it was the Superbike Store in Anarbor Michigan. (sp??)
If someone will {please} get me info on how to contact them, I'll try contacting them.
Post by: turbojoe78_MA on November 15, 2017, 02:06:51 pm
Ted,  I'm in for the group buy when it get's set up.
Joe C
Post by: JDSCO on November 15, 2017, 03:07:16 pm
Superbike Store
14630 King Dr
Milan MI 48160
superbikestore.com
I just called the number on their website 734-996-0135 and the gent who answered said he has no inner fender for the C14 specifically and has no idea of a US supplier, be it ProjektD or otherwise.
Post by: sam_uk on November 15, 2017, 03:42:29 pm
Maybe worth trying the company in my previous post.See what they can do for you guys. I have hugger fitted made by Skidmarx but  i cant find it on there site.  https://www.skidmarx.co.uk/ (https://www.skidmarx.co.uk/)
Post by: connie_rider on November 15, 2017, 11:01:27 pm
Sam, I found the hugger on their website.
    https://www.skidmarx.co.uk/kawasaki/kawasaki-gtr1400-2007-rear-hugger-grp.html (https://www.skidmarx.co.uk/kawasaki/kawasaki-gtr1400-2007-rear-hugger-grp.html)
Will try to figure out how to talk them into a group buy.
Ted
Post by: sam_uk on November 16, 2017, 04:36:41 am
Been on for a couple of years now with no problems.A good product.I sprayed mine matt back.
Post by: AmphibSailor on November 16, 2017, 09:08:28 am
At the very least, the European companies should discount the VAT (VAT is not paid when delivery is outside of Europe).  I believe the current European VAT is 20%.   :beerchug:
Post by: JTX on November 20, 2017, 11:07:37 pm
As a follow up to my post, I too have the skidmarx brand hugger. I wasn't able to find my receipt where I bought it, but I could have sworn I got it from a US based dealer of their products. I Will keep looking.
I have 10,000 miles on the bike now and the hugger has not budged or caused me any issues.  Rear tire comes off without taking it off, too.
Post by: sam_uk on November 21, 2017, 05:12:21 am
They say on there web page they will ship to non eu countries.(under delivery at top of page).Maybe you could get a good price for your Group buy. :beerchug:
Post by: AmphibSailor on November 21, 2017, 08:14:52 am
If I recall correctly, I bought mine from Pyramid.  I've been really happy with it.
Post by: bowtie39 on November 22, 2017, 03:32:39 am
Would go with a group buy
Post by: connie_rider on November 22, 2017, 02:05:26 pm
Wasn't having much luck finding a Vendor in USA that could/would work with us.
Asked a friend in Eu to contact the Supplier to see if they can/will work with us, and to see if they have a representative in the USA.
More later.
Post by: JDSCO on November 22, 2017, 10:30:28 pm
More later.
Appreciate the effort! Thanks.
Post by: 56taskforce on November 23, 2017, 02:33:13 pm
^^^ THIS ^^^ THANK YOU Ted!!!
Post by: Heel2d on November 23, 2017, 04:01:59 pm
Better late than never, count me in.
Also, could we get them in the fastest color, green?  :)
Post by: connie_rider on November 23, 2017, 05:56:20 pm
No, {dey come in black} but the fastest color {ie; 2014 / Red} guys will pitch in and buy ya sum of that cheep green paint...   >:D
                   {Sed while ducking and weaving}      :))
Post by: TimR on November 23, 2017, 11:29:37 pm
Sorry Ted. But a 2014 red and 2015 green isn't as fast as a 09 red. The 09 doesn't have a speed limiter.  ;)
Post by: connie_rider on November 24, 2017, 02:05:05 pm
Hee hee,,,  >:D
      Neither does my 2014, and mine's been flashed..  {err} adjusted...    :nananana:
                   {Thanx Steve}...
Post by: 56taskforce on November 24, 2017, 04:11:27 pm
Yah yah but their not black so still speed limited by color LMAO
Post by: Tjnoma99 on December 04, 2017, 02:27:23 am
If you do find a US vendor ( or anyone thats willing to hook us up) I'm in too!!!
Post by: connie_rider on December 04, 2017, 02:19:38 pm
I've sent out notes and called various places.
No luck.
If someone knows of a good source, let me know...
Post by: sam_uk on December 05, 2017, 08:51:04 am
Email sent to you Ted. :great:
Post by: 56taskforce on December 05, 2017, 03:25:32 pm
If I build a steel fender as a form, do we have someone here that can reproduce it in carbon fiber???
Post by: connie_rider on December 05, 2017, 08:26:09 pm
I talked to sam_uk.
He has talked to the manufacturer for us..
  More to follow soon.
Ted
Post by: Rev Ryder on December 06, 2017, 11:33:11 pm
Yes we do.   :)
Post by: 56taskforce on December 07, 2017, 01:53:14 am
Ok then how would you want it sized, I mean would it be the outside dimension or the inside dimension or just actual size??? I guess what I'm asking is would it be the mold or would you just build the mold from it?
I'm pretty sure I could provide a nice prototype out of steel, and then provide mounting brackets and Hardware most likely from stainless.
Post by: Rev Ryder on December 07, 2017, 12:32:30 pm
Since the metal fender would be the proto or the plug, the outside of it would create the "finushed"'side of the mold.  Yes, I would pull the mold from your plug.  Since the Carbon and the steel wouldn't share dimensions except the outer surface that would be the surface to perfect for fit and appearance.  I would then do any clean up and prep and pull a mold from that. Since c.f. Is the desired final material, I would want to extend the part on all sides by at least an inch and a half as to create a mold with a good sized flange so that the part could be made by vacuum infusion. Its really the only good way for carbon to hand lay a part.  Now prepreg and an autoclav would be even better, but THAT I don't have.  Infusion yields very high percentage good parts so it is the best method for me.
Post by: Rev Ryder on December 07, 2017, 12:37:17 pm
I think I would also want to finish the inside of the part with flexible coating to repel rock damage that could create spider or star cracks through the part. Then paint the outside with a couple of coats of a UV clear to make the resin hold up better/longer.
Post by: connie_rider on December 07, 2017, 03:34:01 pm
All, sam_uk has talked to Ian at Skidmarx.
Ian is willing to give us a discount, but we have a problem.
   below is what he offered.....
Individual shipping to USA would be approx £55 gbp {approx. $62} with the hugger at £94.95 gbp. {approx. $108}
    He is willing to  offer 10% off the hugger for ten units and 15% for 15 units
The problem is Skidmarx doesn't have a US representative.
 So,,,  shipping and handling the transactions is a problem..
     Not sure how we would pay for these with individual charge cards?
     Bulk shipping of all the fenders to 1 location and then re-distribute would save a huge amount on shipping costs..
ie; We need someone with Charge card handling capabilities.
     We need someone to receive all the fenders in bulk and re-ship to each of you.
Any idea's??
Post by: sam_uk on December 08, 2017, 04:49:25 am
An idea.If someone is willing to ship them on and has paypal you could collect the 10 or 15 payments that way then make the 1 payment to Skidmarx .If they dont want the hassle of reshipping the buyer could arrange collection and delivery through a postal service. Just an idea. :great:
Post by: JDSCO on December 08, 2017, 08:40:10 pm
i]Individual shipping to USA would be approx £55 gbp {approx. $62} with the hugger at £94.95 gbp. {approx. $108}
    He is willing to  offer 10% off the hugger for ten units and 15% for 15 units[/i]
I'd buy 10 units and have them shipped here in Colorado. It's not that much ($1080 US -10% or less plus $300 shipping?).
Right?
Any idea of 10 unit shipping to CO? Bueller?...Bueller?... Anyone?
I would accept payment from committed COG members by money-order only but that implied warranty, damaged in shipping as one example is a mess so I'm not feeling that idea.
I'd buy one for $158 delivered if I could.
Post by: JDSCO on December 08, 2017, 08:57:43 pm
There are several US manufacturers who have 190-17" rear huggers in stock for other bikes. They are not inexpensive but they are cheaper shipping than buying one from the UK.
Has anyone ever modified an existing fender from another mfr?
Preston Petty Products has some nice plastic fenders.
Is this ZG inner hugger attached at two points only, left and right?
The two points being the aft end of the torque rods?
Post by: sam_uk on December 09, 2017, 05:15:57 am
contact Ian at   sales@skidmarx.co.uk  .He knows about your possible Group buy.He said he would need a shipping address to calculate the shipping costs and can give you more info.Address emails for the attention of Ian. :great:
Post by: turbojoe78_MA on December 09, 2017, 01:31:29 pm
Any idea's??
Murph?
Post by: 56taskforce on December 09, 2017, 01:39:59 pm
^^^^ this^^^^
Post by: Traveler on December 09, 2017, 09:06:59 pm
If this works out I would like to be included.
Alan
Post by: connie_rider on December 09, 2017, 10:25:15 pm
I admit. I hadn't thunk about that.
Ok, (someone send me a PM) how can I get Murph on the phone?
Post by: JDSCO on December 11, 2017, 02:38:45 pm
Here's the response from IAN at Skidmarx UK
Hi Jim
The cost of shipping all of the products to this address would be £145($193.75 US)
A 10% discount on orders upto 14 and 15% discount on order over 15 items.
If I can help further please let me know.
Kind Regards
Ian
Based on this (10-14 units), $98.00 + $20.00 shipping, $118.00 per unit shipped here in the US, which is an appreciable discount over one unit!
Post by: AmphibSailor on December 11, 2017, 02:58:49 pm
Don't you have to add the additional shipping from the single point he's shipping to...to the individual buyers?
Post by: JDSCO on December 11, 2017, 05:48:23 pm
Yes. $118 plus shipping. (ProjektD $169 to your door)
Post by: bowtie39 on December 17, 2017, 03:30:00 pm
Are you looking to start a buyer list??
Post by: 56taskforce on December 17, 2017, 07:16:19 pm
Hi Jim
Kind Regards
Ian
If total costs is $118.00 to my door or less count me in please.
Post by: bowtie39 on December 18, 2017, 01:07:14 am
Hi Jim
Kind Regards
Ian
Thinking the cost will be that plus shipping from whoever gets the whole order here in US and ships to us.
Post by: connie_rider on December 19, 2017, 03:39:36 pm
I talked to a Buddy that has a shop here in Houston.
He brings stuff in to sell all the time. But he didn't want any part of the receiving and reshipping..
If someone will PM me Murph's phone number I'll see if he wants to handle the fenders.
Other than that; Does anyone want to volunteer to do the receiving/shipping?
Post by: Staylo on December 19, 2017, 04:44:41 pm
I could probably be talked into doing that(heck, it would save me the second shipping cost). My only concern would be it would have to be a situation where I wasn’t at risk of getting stuck with a bunch of fenders. I assume everything would have been paid up front? Hopefully directly with the seller? There would have to be boxes bought for each one, in addition to the shipping cost. I don’t know if there’s any good way of estimating shipping cost without knowing what size box would need to be used. Weight should be a negligible factor. Thoughts?
Post by: bowtie39 on December 19, 2017, 05:48:36 pm
Might be possible the mfg. would have those already boxed individually......kinda hoping anyway
Post by: Staylo on December 19, 2017, 06:25:21 pm
Hadn’t thought of that. That would be really handy if they were. That would even allow us to get pretty accurate shipping estimates since the mfr could give us the box dimensions/weight.
Post by: Staylo on December 19, 2017, 06:30:57 pm
I’m east coast as well so maybe we’d luck out and the freight from the UK might be a little cheaper.
Post by: AmphibSailor on December 19, 2017, 06:51:52 pm
From Murph's website...
Phone (270) 322-8097 | Fax (888) 243-4209
PO Box 338, Hanson Kentucky, 42413
murph@murphskits.com
Post by: Tjnoma99 on December 21, 2017, 02:50:03 am
I'm in.
Post by: connie_rider on December 21, 2017, 03:39:13 am
I talked to Murph today. (He has been out of town).
He's interested in carrying the Hugger fenders at his shop.
I'll transfer contact info with Skidmarx to him. (to look the numbers over)
More to follow.........
Ted
Post by: JDSCO on December 21, 2017, 03:22:33 pm
Thanks Ted
Post by: connie_rider on December 21, 2017, 11:33:29 pm
All the info has been sent to Murph, and Ian at Skidmarx (in Eu).
Now we wait and see if they can work something out..... :popcorncouple:
Ride
Post by: connie_rider on December 27, 2017, 01:22:35 am
On this old note, ya'll forgot  that "someone" has to front the $$ for 15 units to Skidmarx {to get the fenders to the USA}.
Ya also forget the what it would cost the "volunteer' to handle everything after the fenders get to his house.
ie; cost of individual boxes and packing material, time to put the fenders in individual boxes, shipping them all over the country, and whatever the Credit card company charges the receiver for the use of everyone's credit card/PayPal..
I'm guessing the total will be closer to $150... {delivered to each person's home}
NOTE:
      I've handled several group purchases before.
      My first time; I did everything listed above, then tried to get folks to pay, send info etc. {some folks backed out}
      Was a PITA and I lost my shirt!!
      That's why, {since then} the only way I do a group purchase is to make arrangements, collect names, and have the mfg
        handle $$ collection, shipping, etc.
          In this case, it's not possible for this mfg to handle everything individually. {as Skidmarx is in Eu.}
      If Murph/other handle everything, we can't expect them to eat the expenses themselves.
         So, {IMPORTANT QUESTION}, If approx. $150 is the cost, who's still interested?
PS: Any volunteers???
Post by: Staylo on December 27, 2017, 03:19:28 am
I mentioned above that I would consider it, if some of the same concerns you mentioned could be ironed out.
Post by: Tjnoma99 on December 27, 2017, 03:23:26 am
I'm still in.
Post by: sam_uk on December 27, 2017, 06:18:31 am
Here in the UK we would pay £103 delivered Which is roughly $137 usd.  :beerchug:
Post by: 56taskforce on December 27, 2017, 01:04:22 pm
I am still in, I really want one of these. We should also check to see if Murph is interested in a combo deal, The hugger fender and his two fender extensions for total protection. Also see who maybe interested in such a deal.
I am still looking at the possibility of manufacturing a hugger fender for us here. I however would want to do a little better than breaking even and it's definitely a back-burner project as I have so many already.
Post by: turbojoe78_MA on December 27, 2017, 02:39:10 pm
Ted, I'm still in.
Post by: JDSCO on December 27, 2017, 03:16:07 pm
I'm still in!
Post by: connie_rider on December 27, 2017, 04:37:46 pm
Thank you Staylo; For now, let's wait and see what Murph decides.
                 Grant; Mfg them in USA might be an option, but I suspect easier to just pay out the bucks?
OK: I built a list to pass on to Murph.
       If I have you as interested, let me know if you want your name removed, or moved to Still In.
I'll pass this info on to Murph. {to help his decision making}.  <evil grin>
Hugger Fender Group Buy List;
Interested @ $118: Staylo
                             Traveler
                             Heel2D
                            Bowtie39
                             OKC14
                            The Pope
                            NYBiomed
Still in @ $150:  JDSCO
                        Turbojoe78_MA
                        Grant
                        Tjnoma99
                        *Traveler
                        *The Pope
                        *Bowtie39
                        *al_ferguson01
                        *Go Caps
                        *Heel2D
Post by: Traveler on December 30, 2017, 10:50:27 pm
Still in at 150.00
Post by: The Pope on December 31, 2017, 12:52:10 pm
Still in at 150.00
Post by: bowtie39 on December 31, 2017, 01:24:38 pm
In at 150.00
Post by: al_ferguson01 on December 31, 2017, 03:01:21 pm
I would be in @ $150 for a rear "hugger" for my '2016 C14-ABS. Thanks, Al
Post by: connie_rider on December 31, 2017, 04:20:14 pm
Great. 4 more moved to the "In at $150" side.........    :great:
I updated the list on Post #100.
Now; We wait for Murph/other to decide.
Post by: JDSCO on December 31, 2017, 05:07:10 pm
Thanks Ted
Post by: Go Caps on January 01, 2018, 02:31:18 am
I'm in at 150.00.
Post by: Heel2d on January 01, 2018, 11:50:43 am
OK, I'm in at $150 too.
Post by: connie_rider on January 01, 2018, 05:02:28 pm
Go Caps / Heel2d added to the list.
That takes us to 10 committed (if he can deliver at approx. $150).
  The wait continues....
Post by: connie_rider on January 07, 2018, 09:08:14 pm
I just got this note from Murph;   :great: :great: :great: :great:
Ted ,I'm going to place the order for them..
Soon, you can contact him to order your fender's...
Post by: 56taskforce on January 07, 2018, 10:14:27 pm
 :)  :beerchug:  :)
Post by: JDSCO on January 08, 2018, 05:12:53 pm
Thanks Ted!
Post by: Heel2d on January 08, 2018, 06:42:12 pm
Good work & thanks,Ted!!
I'll also go ahead and order some of that, extra fast, green paint so the rear end can keep up with the rest of the bike.  :)
Post by: Daytona_Mike on January 08, 2018, 07:14:28 pm
I am curious as to how your going to use the hugger.  On my bike this same  hugger (In my case it is carbon fiber) was used to replace/remove the rear fender.
Are you guys keeping the rear fender and  adding the hugger so you will have both?  Just curious. I have never seen that done before so I wanted to ask.
Post by: connie_rider on January 08, 2018, 07:29:26 pm
On my bike, I removed nothing, just bolted the Hugger onto the swingarm.
It fits tightly over the O.D. of the tire and works with the existing fender.
I'm almost certain it would also work if someone wanted to add the rear Fender Extender from Blue One.
https://www.pyramid-plastics.co.uk/accessory.html?accessoryCode=651&d=GTR%201400%20Concours%20Hugger%20-%20Black&partNumber=073870B (https://www.pyramid-plastics.co.uk/accessory.html?accessoryCode=651&d=GTR%201400%20Concours%20Hugger%20-%20Black&partNumber=073870B)
Post by: Tjnoma99 on January 08, 2018, 09:22:14 pm
Thank you Ted!
Post by: connie_rider on January 09, 2018, 03:11:43 am
Ya'll got it wrong..
Should be,,, thanks Murph!!!
Post by: al_ferguson01 on January 09, 2018, 03:32:19 am
So, what is the recommended approach to reach Murph to complete the order? I used the "Contact Us" link on his web site to send him a note... not sure if that was the way forward...?  Thanks, Al
Post by: Tjnoma99 on January 09, 2018, 03:33:59 am
Thanks Murph!!
Post by: Go Caps on January 09, 2018, 03:42:43 am
Thanks Murph and Ted!
Post by: connie_rider on January 09, 2018, 12:55:48 pm
NOTE: Murph has not told us to order yet.
          I suggest we wait a few days as he just ordered the fenders and they have to be shipped from the Eu.
          I'll send him a note and ask when/how he wants you to start ordering.
Post by: turbojoe78_MA on January 09, 2018, 08:23:11 pm
A big +1 on this!!   :great:
Post by: JTX on January 10, 2018, 11:36:21 am
MURPH is good people!
This is how I got my rear fender. I dont' recall who the vendor was, but it was a US based retailer. Maybe Ebay.  But I"m glad to see Murph stepping up and doing a bulk order.
Post by: JDSCO on January 13, 2018, 09:57:51 pm
The C14 Hugger is now on Murph's site!!!
Post by: Tjnoma99 on January 13, 2018, 11:54:30 pm
I payed for mine! Ill can wait if they havent made it to murph yet!
Post by: 56taskforce on January 14, 2018, 02:25:21 am
Just ordered mine along with one of his front fender extensions... :)
Post by: connie_rider on January 17, 2018, 10:46:13 pm
For those that are on the "Still In" list, go here to buy your fender from Murph.
https://www.murphskits.com/ (https://www.murphskits.com/)
For those that weren't on the list,,, here's the new offering from Murph.
It's a C-14 rear inner fender...
COGggers asked for it, and he came thru.  {again}
https://www.murphskits.com/product_info.php?products_id=532 (https://www.murphskits.com/product_info.php?products_id=532)
Post by: turbojoe78_MA on January 18, 2018, 12:24:03 pm
Ordered placed!   :great:
Post by: JDSCO on January 18, 2018, 02:41:08 pm
Both URL's go to the same eventual page.
Are there two lists?
Thanks Ted
Post by: Cjilla on January 18, 2018, 10:45:28 pm
I'm in!
Post by: connie_rider on January 18, 2018, 11:37:03 pm
Thanks Ted
Not sure what's happening?
When I click on the first one, I go to Murph's site.
When I click on the second one, I go directly to the fender.
Glad you got in on the deal, Cjilla...
Post by: 56taskforce on January 19, 2018, 02:32:33 am
Mine is supposed to be here this Saturday. :motonoises:
Post by: al_ferguson01 on January 25, 2018, 05:34:16 pm
Has anyone heard from Murph on these rear huggers? I placed my order on the 14th, never received an acknowledgment or response to three email requests (from his website) for an update. His phone recording directs to send him email. No luck.  I totally appreciate that these huggers are coming from the U.K. and may take awhile to get out but just curious if anyone has had any communication from him on these or received one?   Thanks, Al
Post by: Staylo on January 25, 2018, 06:01:05 pm
Not yet. I had ordered the hugger and one other item at the same time, and the other item arrived today, but no fender. I just checked my account and it simply says processing.
Post by: connie_rider on January 25, 2018, 06:18:37 pm
I'm not sure they arrived his place yet.
He has not told me they arrived...
I'll check and let everyone know.
NOTE: He's hard to get hold of as he has a day job.
          But, I have my ways....  >:D
NOTE 2: There is a potential for a problem on those that ordered first.
             Murph was not aware the Fenders had been added to his system.
               I have him checking into that possibility already.
               Everyone that ordered, send me a PM and I'll cross the names with him too.
More later. Ride safe, Ted
Post by: bowtie39 on January 25, 2018, 06:44:05 pm
Sure thought I read on his site these would be available maybe by end of this month....the reason I haven't ordered yet.
Post by: Staylo on January 25, 2018, 08:18:59 pm
Just looked at my receipt for the item that arrived today and there’s a handwritten note that says hugger should ship end of February.
Post by: connie_rider on January 25, 2018, 09:49:45 pm
New message just arrived from Murph ...
Hey Ted
Just heard from Skidmark's.
 The huggers are still about two weeks out before I see them.
      Can you pass that on please?
Murph
Post by: JDSCO on January 25, 2018, 10:36:17 pm
Murph had the "not available until February" shipping notice on his website January 14. I know this because I ordered mine January 13.
I'm glad they're on their way. Way to go Murphs!!!
See my post #183
Post by: connie_rider on February 15, 2018, 09:32:19 pm
I received this note from Murph today.
Ted
Ted, They are supposed to show up at my place tonight, hope to be shipping tomorrow..
Murph
Post by: JDSCO on February 15, 2018, 10:48:29 pm
Yep, on it's way from Murph's today!
Post by: Tjnoma99 on February 15, 2018, 10:59:37 pm
I just got my email tracking too!!! :))
Post by: Doc on February 15, 2018, 11:23:36 pm
Are these difficult to install?
Post by: JDSCO on February 15, 2018, 11:39:45 pm
^ I've never installed one
Looks very, straight forward to me
We're about to find out, eh?
Post by: connie_rider on February 16, 2018, 02:08:47 am
I did mine 3 years ago...
   Not overly difficult, but does take some patience as some of the clearances are tight..
   My memory sux, but I think I did it without removing the rear tire..
Post by: sam_uk on February 16, 2018, 04:10:11 am
Note on fitting the hugger,Leave enough space for the odd small stone to roll under the hugger. over here UK we have stone chippings put down on the roads for grip,In the hot weather they can stick to the tyre and  chip the edge of the hugger as they try to roll under. Recheck the mounting bolts after a few miles , Painted mine matt black .easier to keep clean than the gloss black. :great:
Post by: 56taskforce on February 16, 2018, 12:12:23 pm
One more time I would like to thank Ted for taking the ball here and running with it and Murph's Kits for adding it to their inventory and saving us the ridiculous shipping charges from the UK.
I can't wait to get this on my bike....
Post by: JDSCO on February 20, 2018, 06:52:01 pm
Thanks Ted!
5 months, well worth the wait
Suspension due tomorrow
Just in time!!!
Post by: 56taskforce on February 20, 2018, 10:26:05 pm
Yep got the notification it is waiting for me at the Post office today, be picking it up tomorrow.
Post by: Tjnoma99 on February 20, 2018, 11:27:32 pm
I got mine today too! Gonna put it on tomorrow!!
Post by: connie_rider on February 21, 2018, 12:03:01 am
Thanks all.  Sounds great.
As I sed;  MURPH is the man that made it happen.
To make it fit right...
       Work on it awhile, then {when you see red} walk away, cuss me (err Murph) and think about it awhile.  >:D
                 Repeat this process {particularly the Murph part} until ya get-er-dun.........
                         {Beer may be required}   :beerchug:
Post by: turbojoe78_MA on February 21, 2018, 02:40:05 pm
Got mine yesterday too!   :)
Title: Re: Rear fender NOW GROUP BUY!!! - Installed
Post by: al_ferguson01 on February 21, 2018, 05:54:17 pm
So, I haven't seen anyone post on their installation yet so I thought I would. See Pics.  Nice looking and super-easy to install.
Post by: JDSCO on February 21, 2018, 07:00:09 pm
I was thinking it would "hug" the tire more than it appears to.
Does appear there is plenty of clearance, though.
Nice Moondust Gray, I must add!
Post by: sam_uk on February 21, 2018, 07:09:55 pm
i have mine set lower than that but as long as there is enough clearance at the front it will be good (https://i.imgur.com/GlC2zvv.jpg)
Post by: JDSCO on February 21, 2018, 07:17:19 pm
I'm waiting for the truck to deliver my suspension so...I guess I'll mount mine whilst I wait
So...I added an extra M6 nut/washer to the rear brake hose clip bolt to back-up the M6 fiberlock (tighten nut until it pinches bracket)!
And it has some adjustment and it's actually very rigid
I like it a lot!
Post by: Tjnoma99 on February 21, 2018, 11:29:05 pm
Got mine installed today! Had to pull the exhaust to get it done! They arent joking when they call it a tire hugger  :)) !!
Post by: 56taskforce on February 22, 2018, 12:12:35 am
Check the clearance of the lower edge of the fender to the tire, it is likely to be really close with that much at the top. I noticed that as you adjust the clearance to tire the fender Teeter totters from the mounts, otherwise as clearance increases at one end it decreases at the other.
Post by: 56taskforce on February 22, 2018, 12:15:02 am
I like it a lot!
[/dquote]
I did that as well.
Post by: al_ferguson01 on February 22, 2018, 12:56:20 am
There seems to be adequate clearance all the way around... with the welded bracket (right) and the left bracket, there really isn't much adjustment to be had (or needed). In fact, upon closer inspection, the swingarm prevents much "rocking" of the hugger - it's snug against the swingarm so not more adjustment to be done - it just fits.
Post by: connie_rider on March 06, 2018, 10:03:13 pm
Ids anyone else interested in getting one of the Hugger Fenders?
I'm sure Murph still has some.
Post by: Staylo on March 17, 2018, 05:54:54 pm
 So there was some sort of mixup on my order and it didn’t get shipped with the others, but I contacted them and they sent it out right away. The only question I have, for those guys that ordered one was there supposed to be some sort of brackets with this thing? All I have is the fender. I’m looking in the photos and I’m seeing metal brackets for attaching to the bike. I don’t have those if they were supposed to be included.
Post by: 56taskforce on March 17, 2018, 07:38:35 pm
Did you order from Murph's Kits?
Yes it comes with all needed hardware. If you ordered from Murph's give them a call their customer service is excellent.
Post by: Staylo on March 17, 2018, 09:40:37 pm
I reached out and they got back to me already. They’re sending the missing parts out Monday.
Post by: Boomer on March 18, 2018, 10:58:22 am
My Hugger is the Skidmarx. I rode the bike to Weymouth back in 2008 so they could measure my bike and take photos. I got a hefty discount when they delivered it and about the only complaint is the brackets could do with better quality powdercoating. I later organised a 21 units group purchase for the French GTR club GTRMANIA. Drove the car to Rouen in France with their Huggers and had a fun afternoon eating chatting and fitting Huggers. If you phone Skidmarx they will arrange a VAT free group buy shipped to the USA. Just remember we are on GMT/UTC here when you phone.
Post by: JTX on March 18, 2018, 11:11:59 am
I dont remember having to do this for the hugger, but I do remember taking the pipe off for something......Maybe it was!
The good news is, the rear wheel comes off without having to remove the hugger.
I've had mine installed for several years and it's never moved, budged or needed adjustment or service.
Post by: 56taskforce on March 18, 2018, 12:22:11 pm
That is what happened here a group buy through Murph's Kits and now we have a states side supply that saves a ton on shipping. I believe it was a win all around. BTW thanks for being the original model bike... :) :beerchug: :)
Post by: connie_rider on March 18, 2018, 01:46:08 pm
I have an Aww Sxxx to report.
I've had a hugger on my bike since 2014.
    Liked it and will get another.
I had 1 incident 3 years ago; I picked up a rock and it wedged between the fender and the tire.
   Wasn't a problem, just stopped and removed the rock. (But it slightly damaged the fender)
Now to the AS:
At the Sport Touring School in Jennings, my Hugger was torn from my bike while riding.
   I want everyone to know "it was a "pucker" moment"!!  :-\
   ie; I was in a turn after a fast straightaway..  :motonoises:
I recovered the fender and don't see where anything failed to cause the problem.
         The fender appears to have been torn from the bike.
   I think it was caused by the 55 series tire, high speed, and rubber build up on the tire from the track.
Post by: JDSCO on March 18, 2018, 02:29:16 pm
^^That "hugger" profile is the only drawback to this fender installation
