Author Topic: Tail Bag Suggestion(s)  (Read 4150 times)
Offline SuperBee
« on: May 31, 2011, 04:12:20 am »
Hello all,
Looking for a small to medium size tail bag that can detach easily and fit into a smallish school locker at work.  I thought I'd see if y'all have some suggestions or experiences for a good fitting one.  Any help is greatly appreciated.
Ride Safe,
SB
Re: Tail Bag Suggestion(s)
« Reply #1 on: May 31, 2011, 07:52:20 am »
 I use a Bags Connection rear seat bag when I'm on trips. It's a awesome bag. But it may be too large for what you want.
 So for around town. I have been using a Saddlestow Montana Jr. (by Saddlemen) rear seat/rack bag. I have had mine for years and loved this bag. It's on my bike right now. It should do what you want and fit in a locker. It is soft sided so it can be scrunched down if need be.
 I strap it around the rear seat. Then just undo the snaps and go when you want to take it off. It stays attached to the seat if you remove the seat also. Or I will some times strap it on to the rear rack. Both methods work well!
 I'll give you a link to a place that has them and pictures of my older sun faded bag with many years and miles on it. Hope it helps!
Bob
http://www.discount-motorcycle-parts.net/saddlestow-montana-rack-p-433.html
Offline MKorn
  • COG#: 9527
« Reply #2 on: May 31, 2011, 09:27:20 am »
i had a Cortech tail bag for a few years now and it has served me well.
i only plan to use it on the C14 for long trips.
here it is on my DRZ.
2009 C14 ABS
2002 750 Nighthawk (sold)
2006 DRz 400s
Offline none
  • Teleskier
« Reply #3 on: May 31, 2011, 03:08:57 pm »
I use this one too and its great. Even has enough room for multiple day trips if you don't want to use the hard bags because its expandable on both sides.
Offline MrPepsi
  • COG#: 8402
« Reply #4 on: May 31, 2011, 06:16:19 pm »
I am very happy with this one.
http://www.amazon.com/Motogear-73727-Motorcycle-Tail-Bag/dp/B000RN04VU/ref=sr_1_1?ie=UTF8&qid=1306869165&sr=8-1
Easy on off and seems to be made very well.
Good price too.
Brent Johnson
Why MrPepsi? I collect and consume Pepsi!
2009 C-14 "Razzi"
2013 SFO to PDX Loop Ride Trip Report
Offline SuperBee
« Reply #5 on: May 31, 2011, 07:50:22 pm »
Thank y'all for the help, pics, and links.  Much appreciated.
SB
Offline joe in calif
« Reply #6 on: June 05, 2011, 12:32:22 pm »
Mine is a Fastrax, it looks great and fits great and it expands up so you can fit a full size helmet in it if needed. Also has 2 zipper pouches on the inside of the top flap.
« Last Edit: June 05, 2011, 12:34:09 pm by joe in calif »
Offline SuperBee
« Reply #7 on: June 05, 2011, 09:38:24 pm »
Is that a Dowco Rally Pack or does it say 'Rally Pack' on it?  I like the looks of yours and am trying to find Fastrax but it comes up as Rally Pack from some sellers.  Thx for the pics.
SB
Offline JS_racer
« Reply #8 on: June 06, 2011, 08:59:37 am »
any tips on hooking a tail bag to the c14?? cant seem to find any good points on the rear of this thing.
thanks
« Reply #9 on: June 06, 2011, 09:41:12 am »
thanks
I normally strap it down around the rear rack or around the rear seat. It works well. It worked really well with the Corbin seat. Since the rear seat is a separate piece.
Offline wmathi
  • COG#: 9531
« Reply #10 on: June 07, 2011, 06:38:54 pm »
Joe  - your bike looks like mines twin - I also have the fasttrax bag. I have a "better" way of strapping it on. (my opinion). I attached pics, hopefully you can see. I like it because I can attach/disconnect fast and it looks clean. It is also very secure.
In a nutshell, the fasttrax comes with an assortment of straps. Two of them are always attached, loosen rack mounts put under rack and mount -  re-tighten, cut to length. the front strap loop goes through ahead of side grips(seat off), strap goes through loop, cut to length. to put bag on attach clips on rack, then  front straps and snug front.
Bill
Offline 2011Blk
« Reply #11 on: June 27, 2011, 04:04:36 pm »
I'm having the same results when searching for the bag on line. The Rally Pack doesn't look like yours either from the pictures I see on line. Help!
Thanks.
TJ
TJ
Colorado Springs & Las Cruces
2011 Concours - Fun ;D
08 KLR 650 - 11,000 miles ... sold
78 Yamaha XS-750E - 42,000 miles then gave it to a friend
Studies show that spending one sunny day alone on your motorcycle riding twisty mountain roads does more for your soul than mowing the lawn every Saturday morning for a decade.
« Reply #12 on: June 29, 2011, 12:46:50 pm »
Sorry it took me so long to answer but I have been busy and have not checked the board,
 Here is a link to the tail bag
http://www.phatperformanceparts.com/Dowco_Rally_Pack_Deluxe_Series_Tail_Bag_p/50109-00.htm
or do a search with
dowco tail bag 50109-00
Bill, the pictures you posted are hard top see, they are small but I think I have an idea of what your talking about,I'll give it a try.
« Last Edit: June 29, 2011, 12:50:05 pm by joe in calif »
Offline wmathi
  • COG#: 9531
« Reply #13 on: June 30, 2011, 04:40:28 pm »
Joe - I hope this helps. I had to figure out how to post pictures properly.
I think I got it.
The rear straps are between the rack and mount, with the screws going though them. straps are cut to leanth and "permant"
https://picasaweb.google.com/lh/photo/R-i1stSVJDLbh-8awGBOx2Zn66N4h5HXD-R-mcSvMbo?feat=directlink
This shows where the front straps go though, seat off, strap though loop one end and clip on other.
https://picasaweb.google.com/lh/photo/nzvJu8DvE30DP5vKvRJ-kGZn66N4h5HXD-R-mcSvMbo?feat=directlink
So clip the rear, clip the front and snug the straps. Ta Daaah :)
https://picasaweb.google.com/lh/photo/ndIsh79uVX4acx0z5cmjbmZn66N4h5HXD-R-mcSvMbo?feat=directlink
Works great for us, I hope it helps you.
If Pictures don't work email me wmathison27@gmail.com
Bill
« Reply #14 on: July 02, 2011, 02:35:45 am »
wmathi
Thank you for those pictures, that is a clean install, I'll do it tomorrow, since it's to hot to ride!!  100 + for the next few days.
