Author Topic: Throttle Lock  (Read 1817 times)
Offline Doc
  • COG#: 12697
Throttle Lock
« on: October 30, 2017, 11:02:26 pm »
Interested in opinions on Kaoko vs Throttlemeister.  Thanks.
Offline Deepsea
Re: Throttle Lock
« Reply #1 on: October 31, 2017, 12:08:25 am »
I have the Throttlemeister. It's all stainless steel, no plastic and works great.
Retired Navy Saturation Diver
Offline bowtie39
  • COG#: 10014
Re: Throttle Lock
« Reply #2 on: October 31, 2017, 03:20:24 am »
Have had both and find the Kaoko easier for me to operate
Offline BiggusDekkus
  • COG#: 11944
Re: Throttle Lock
« Reply #3 on: October 31, 2017, 06:42:13 pm »
Ditto for the Throttlemeister.  Better looking, and I think the Throttlemeister is super easy to operate.
Jet Ski Ultra 300X & ST-15F
Lake Stevens, WA
Offline bowtie39
  • COG#: 10014
Re: Throttle Lock
« Reply #4 on: October 31, 2017, 09:39:17 pm »
Helps if your somewhat limp-wristed for the Throttlemeister :rotflmao:
Re: Throttle Lock
« Reply #5 on: November 01, 2017, 02:23:05 pm »
I just put a used Throttlemeister on and it is a bit hard to engage.  I got no instructions.  So far the easiest for me is to just reach over with the other hand and engage it.   I read a suggestion of rolling it on with the same hand but not much luck doing that.  What do you all do?
So far I like the look and build.  I have never had the other one.
Offline Deepsea
Re: Throttle Lock
« Reply #6 on: November 01, 2017, 05:00:40 pm »
When properly installed it should be easy to engage. Even when fully locked you should be able to move the throttle. I have mine adjusted so that I can lightly engage it to relieve my grip but still make minor changes to speed. The number and thickness of the shims (washers) is how you adjust it. It should never lock so tight that you can't move the throttle in an emergency.
  • COG#: 11944
Re: Throttle Lock
« Reply #7 on: November 01, 2017, 06:33:02 pm »
That seems like a difficult way to engage the TM.  When I want to lock the throttle, I use my thumb and index finger to control the throttle, and turn the TM bar end counterclockwise with my little finger and ring finger.   This locks the throttle, then you can make a final adjustment with your full hand to set the speed after it is locked.
Lake Stevens, WA
Offline Deepsea
Re: Throttle Lock
« Reply #8 on: November 04, 2017, 01:23:16 am »
+1 what he said. One hand.
Offline Jerdurr
Re: Throttle Lock
« Reply #9 on: November 08, 2017, 06:18:06 pm »
+2. One hand...pinky and ring finger, then full hand, off u go!  :)
Best,
JD
