Author Topic: throttle lock  (Read 1116 times)
Offline el paso
  • COG#: 10048
throttle lock
« on: August 25, 2019, 08:50:45 pm »
I saw on FB that a member just bought a Atlas throttle lock and it was a bottom mount. I got on the Atlas website and their saying to use the top mount on a C14. I think I would prefer the top mount. From what I can tell it shouldn't interfere with the heated grips wire. Can anybody help me out here? Thx in advance.
Offline Gumby
  • Black 2011
  • COG#: 10640
Re: throttle lock
« Reply #1 on: April 19, 2020, 05:48:37 am »
Did you ever buy one of the Atlas throttle locks? I was reading on advrider about this thing and it sounds better than the Throttle Meister throttle lock.
https://advrider.com/atlas-throttle-lock/
Offline Tundra
  • 2012 Candy Arabian Red
  • "SPORT" tourer
Re: throttle lock
« Reply #2 on: April 19, 2020, 10:08:13 am »
Haven't used that brand, so no hands on advice. It sure looks pretty slick and basic. I researched it and WOW sticker shock. I see others that look similar for a fraction of that cost?
  I've owned the Kuryakyn, which is no doubt the prettiest with different finishes in a smooth billet aluminum. Hard to find now accept old models used.
  Also own the Kaoko throttle lock which fits the bikes looks extremely well, heavy bar weight to match and finish to match the Kawasaki finish. I find it functions better than the Kuryakyn as it's easier to activate even with gloves. Still blending into the bike well, looking factory unlike some of the cheap obtrusive bulky types I've seen.
Again I guess I didn't answer your question, just throwing some other options out there. If I was going to spend over $200 bucks on a Throttle lock, I'd probably go for the Cruise Control.
Offline Gumby
  • Black 2011
  • COG#: 10640
Re: throttle lock
« Reply #3 on: April 19, 2020, 01:17:14 pm »
I have a Throttle Meister throttle lock, and it works fine for my needs. I was intrigued and a little curious after reading the article so I did a search on the forum to see who had one and if there were any reviews.
Offline JPD
  • COG#: 12064
Re: throttle lock
« Reply #4 on: April 19, 2020, 01:43:46 pm »
I have these on both of my C-10's. I also used one way back on my 82 KZ550. They say that they are not for late model Kawasaki's but instead of using the bottom plastic tab as a lock to the throttle cables I pull out the pins and reverse it, while it is disassembled I sand down the ridge to make it narrower and then after I get it to the position I want for the activation lever I shoot a glob of ultra black RTV between it and the switch housing to retain it in position. You can use the set screw to adjust the holding power. Mine will just keep the throttle from creeping back when I let go of the grip. Stick your thumb straight out as you roll off the throttle and it disengages. I don't have heated grips so not sure on how the wires come out for interference.
NEP Motorcycle Cruise Control Throttle Lock for Dual Cable Throttles 7/8" CC3 | eBay
5
(8)
· $22.95*·
Online robertv
  • Go Hawks!
Re: throttle lock
« Reply #5 on: April 19, 2020, 02:16:53 pm »
This Atlas throttle lock has piqued my interest! I have aftermarket Oxford heated grips, so would love to read a review or feedback even on newer C14s with heated grips. I think in my case the bottom lock option would be best. Definitely a lot more $$ but still cheaper than CC.
2008 C14, silver [current]
2000 C10, red [sold]
Offline MaxTO
  • COG#: 13086
Re: throttle lock
« Reply #6 on: April 19, 2020, 03:02:54 pm »
I've had the Atlas throttle lock for a couple of years now. First on my SV650, now on the C14.
I find that it works well, and gives me opportunity to rest my hand every now and then. I typically don't use it for extended periods of time, usually about 1 minute stretches or so when my right hand gets tired.
Summary:
+ looks pretty good on the bike, not overly bulky
+ easy installation
+ easy to use (e.g., on/off, slight adjustments to speed etc.)
+ can be transferred to other bikes
- I'd say it's a bit pricey
- unless on a flat road, speed will fluctuate, requiring small adjustments
Offline BiggusDekkus
  • COG#: 11944
Re: throttle lock
« Reply #7 on: May 08, 2020, 12:40:49 pm »
Robert - I ordered an Atlas Throttle lock yesterday.  I'm not using it on the Connie though, it's going on a new Honda CB500X, and I'm also installing the Oxford Adventure Premium heated grips.  Will let you know how the installation goes.  From looking at this and e-mailing Josh at Atlas, either the top mount or bottom mount version will work.  I went with top mount.
A factor to consider if you want to install the Atlas on a Connie is that the grips must be removed to install the Atlas.  Since I'm already removing the factory grips and installing heated ones on my Honda, it's not a consideration for me.  If you have heated grips already, it may be difficult to remove them without damage.
Jet Ski Ultra 300X & ST-15F
Lake Stevens, WA
Offline Shizzle
Re: throttle lock
« Reply #8 on: May 08, 2020, 03:30:55 pm »
I have had just about every Throttle Lock known to man and compared to the Rostra on the C14 they all suck. You can do the whole Rostra project for under $300. Yep, it's kind of a pain in the butt to install but it really is worth it.  :)
Online robertv
  • Go Hawks!
Re: throttle lock
« Reply #9 on: May 08, 2020, 04:38:27 pm »
Thanks Steve! Hope you're doing well. Its been awhile since we've ridden with our NW COG brethren. I think the last ride was St Helens with some of the members experiencing flats, hope that's out of their system!  :)
Good to know on removing the grips pre-install, I will have to check removal difficulty of the heated grip on the throttle side without damage. I'll wait to see what your review thoughts are!
