Author Topic: Turn signal cancelation ?  (Read 3075 times)
Offline JJPSUPERDAD
  • COG#: 8346
« on: August 23, 2011, 11:16:04 pm »
Would anyone know of turn signal auto cancel besides kisan for the concours 14 that works well.
I wish the factory would install these with a timer.  :-\
Offline joe in calif
Offline rlyons
  • COG#: 4150
Re: Turn signal cancelation ?
« Reply #2 on: August 26, 2011, 11:25:04 am »
I had to train myself that after every turn I instinctively reach up and punch the turn signal button to cancel, even if I didn't use them. Put a reminder up somewhere on the dash or windshield and try this. After a while you'll do it too.
Offline JJPSUPERDAD
  • COG#: 8346
« Reply #3 on: August 27, 2011, 12:01:59 am »
GOOD IDEA I WILL TRY THAT ! I INSTALLED THE KISAN ON OUR 2004 CONCOURS AND IT WAS SUCH BS WITH TAKING APART THE SWITCH AND INSTALLING A SPRING! SORRY ABOUT CAPS BEING LAZY TODAY
Offline C1xRider
  • I'm not monitoring this forum. PM me at zggtr.org
« Reply #4 on: August 27, 2011, 01:36:26 am »
snip...
Wow, I never knew pushing a button was so much work.   :))
2010 C14 ABS  :great:
2000 XT350
1998 C10
1983 V65 Magna
1978 SX250
« Reply #5 on: August 27, 2011, 09:23:11 am »
snip...
 :rotflmao:
Offline Thedugger
« Reply #6 on: August 29, 2011, 03:07:39 pm »
LOL  :rotflmao:
Ride Till You Can't....
« Reply #7 on: August 30, 2011, 01:07:05 pm »
A friend with a Honda ST1300 had that problem, he mounted a small LED light on the dash that was connected to te turn signalss and it flashes with the blinkers and is easy to see as a reminder
Offline Mad River Marc
  • COG#: 8442
« Reply #8 on: August 30, 2011, 03:36:44 pm »
You mean in addition to the lights that are on the dash already that do just that :)  :))
Offline ZG
  • COG#: 9735
« Reply #9 on: August 31, 2011, 01:29:42 am »
 :-[ :D
Offline Boomer
  • Wickford, UK
    • Boomers GTR Site
« Reply #10 on: August 31, 2011, 12:17:44 pm »
Friend did the same on his Trophy 1200.
With a tankbag fitted he couldn't see the lights on the dash so he fitted tiny LEDs up high on the screen.
Works a treat and now he never leaves his signals on.
I've tried all the bikes fitted with auto-cancel and several aftermarket add-ons and they all cancel when you don't want them to.
Far easier for you to cancel them when YOU want to.
Just think of it as a workout for your left thumb,..... and your mind!  :))
George "Boomer" Garratt
Wickford, UK
CDA-007
Offline Bobby M.
« Reply #11 on: August 31, 2011, 02:19:42 pm »
I did the same as RLyons... Now I have a compulsion to press the signal cancel button every so often while riding. Even if I hadn't used the signal in a while. It's second nature now.
BR MUNROE
'09 C14
