Author Topic: two brothers exhaust  (Read 7224 times)
Offline Brick Man
  • COG#: 11133
« on: August 13, 2014, 08:54:09 pm »
I would like the BLACK Two Brothers slip on for my 2012. But my dealer says I must put in a Power Commander at a cost of about $500 parts and labor. (Sure they want the work.)
The Two Brothers site says I don't need to do that , although it is desirable. (Sure they want to sell an exhaust)
I don't care if I have 5 more or 5 less HP.  Just want a good sound. I DO NOT WANT TO DAMAGE THE BIKE.
WHO DO I BELIEVE??????
Also what should I pay for the exhaust itself?  Who is best on line source?
Offline Brass
Re: two brothers exhaust
« Reply #1 on: August 13, 2014, 09:11:55 pm »
I've been running a Two brothers black series for a year and a half with no issues and no power commander.
Shaun - Collegeville PA
2017 Yamaha FZ-07
Offline Brick Man
  • COG#: 11133
« Reply #2 on: August 13, 2014, 09:24:27 pm »
Thanks Brass.  where did you buy it and what did you pay?
Offline Dave Scott
  • COG#: 8603
« Reply #3 on: August 14, 2014, 12:26:36 am »
you might get a little bit of dedel popping.  I get that with mine and a cs.1.  Nothing to worry about though.
Offline KennyS
« Reply #4 on: August 14, 2014, 12:38:47 am »
I have a two brothers black diamond on for two years now no fuel management..just like other guy said you will get some decibel pop but no worries.....buy it the sound is sweet
2008 kaw c14
2007 Suzuki m109
2008 Honda 650 xrl
Offline 1warlock
« Reply #5 on: August 14, 2014, 01:10:45 am »
I put on a two brothers black, bit the bullet and put on a power commander and gained 14 hp :)
Offline ZG
  • COG#: 9735
« Reply #6 on: August 14, 2014, 01:49:10 am »
With just a slip-on?  ???
Offline Squid4life
  • COG#: 11499
« Reply #7 on: August 14, 2014, 10:36:14 am »
I was wondering the very same thing....
Slipon No PC needed it.
Full exhaust."..Yes any kind of fuel management a must.
I Read More than I Post!!!
Offline gpd323
« Reply #8 on: August 14, 2014, 11:09:57 am »
I just installed mine this AM. I have the ECU flash from 2 wheel dynoworks. Nel's wants to put it on the dyno and tweak it if necessary.
Offline Brass
« Reply #9 on: August 14, 2014, 11:20:12 am »
Revzilla I paid around $450 for the black carbon
2017 Yamaha FZ-07
Offline gpd323
« Reply #10 on: August 14, 2014, 12:53:13 pm »
I really like the sound of the CS1. Mellow and not loud at all. perfect! But how to gid rid of the sputtering at the header midpipe joint?
I see a metal ring gasket on the stock pipe. Instructions did not say to use this part for a better seal.
Guess I am going to pull it off and see if I can get that gasket to fix the sputtering.
Offline motonerd14
  • Nerd n' Ziggy
  • Go West, young man...
  • COG#: 9283
« Reply #11 on: August 14, 2014, 03:57:13 pm »
Run away from that dealer and never look back! I have over 10k miles on a TBR Carbon black slip-on and am very happy with it. No need for any additional installations or equipment either.
2012 C14 - 'Ziggy'
2005 KLR650 - 'Klara'
Offline Big Mike
  • Binghamton, NY
« Reply #12 on: August 14, 2014, 04:23:04 pm »
I ran a Two Brothers on my 2012 with no issues other than the annoying decel pop..
Got mine off ebay (new) pretty cheap..
2014 Concours 14 Candy Cardinal Red..
HeliBar Risers/Knight Design Lowered Pegs/Super Shark Skins/Cee Bailey Ultra Tour/TechSpec Snake Skin
Offline Bigfoot_16
« Reply #13 on: August 14, 2014, 06:40:26 pm »
I had to use the aluminized exhaust repair tape and Inferno metal repair paste to seal up the leaks at both ends of the midpipe of my CS One. Otherwise the noxious exhaust fumes were just too much for me and my wife. Now I have no leaks, no fumes and it sounds great.  :)
Jim
2015 Concours 14
Offline Cold Streak
  • Cold Streak
  • 952-215-2264
  • COG#: 8811
« Reply #14 on: August 14, 2014, 07:16:46 pm »
I have the Muzzy slip on with no fuel management and no problems after 58,000 miles.  The deceleration popping can be cured by plugging a tube coming from the air cleaner box.  Search decel pop or some variation of that on the site and you'll find pictures and instructions.  I don't mind it myself and if I hold the throttle open very slightly while decelerating it doesn't happen.
COG #8811
14 Kawi KLR650 NE
08 Kawi Concours
75 Kawi H1
Offline Big Mike
  • Binghamton, NY
« Reply #15 on: August 14, 2014, 08:02:02 pm »
http://www.holeshot.com/Concours_c14/c14decel_inst.html
Offline gpd323
« Reply #16 on: August 14, 2014, 09:50:53 pm »
Ok, I was able to cure the sputtering at the header, still get some blow-by at the mid-pipe. I will try some metal tape used for furnaces.  :beerchug:
Offline Alan
  • COG#: 11662
« Reply #17 on: August 15, 2014, 12:05:42 am »
Put a Two Brothers carbon fiber black series on my '12, looks better than the potato launcher and about 12 lbs of weight gone.
Did not do put on a PC, runs no problems at all, does pop some on decel but nothing bad, more pronounced  coming off of high rpms.
Got mine here, best price I could find.
http://www.biohazardcycles.com/servlet/the-5602/TWO-BROTHERS-2-BROS/Detail
Don't Panic!
AMA Charter Life 34 years
GWRRA Member 3 years
LIMNCS #147
'77 BMW R100/7 Manfred
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
'08 Suzuki DR650SE Mootzimo
'09 Honda GL1800Navi/XM HAFACAR
'12 Kawasaki ZG1400 Concours
Highly recommend http://letsrideclyde.com/
Offline 1warlock
« Reply #18 on: August 15, 2014, 12:34:57 am »
with the two brothers black, pcv the dyno doesn't lie...box stock the dyno showed 128hp ;D, with the pipe, pcv  the dyno showed 142hp. :motonoises:
Wonder or no that's what it showed :))
Offline Alan
  • COG#: 11662
« Reply #19 on: August 15, 2014, 12:43:03 am »
Thinking about doing the Guhl ECU flash over the Winter, so it also does something with the secondary flys, as opposed to just removing them.
Don't Panic!
LIMNCS #147
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
Offline ZG
  • COG#: 9735
« Reply #20 on: August 15, 2014, 02:10:53 am »
Sorry bro, but...
FWIW, the C14 comes out of box at 133... So my only guess is whoever is doing yer dyno work has a dude behind the curtain doing funny business.  ???
Offline Bigfoot_16
« Reply #21 on: August 15, 2014, 03:16:57 am »
Sorry bro, but...
Now that's an interesting topic. When I bought my 2013, the dealer told me that the HP at the crank was 156. I've only seen rear wheel HP figures in the motorcycle mags. Kawi doesn't publish anything on their web site that I've been able to find.
Jim
2015 Concours 14
Offline 1warlock
« Reply #22 on: August 15, 2014, 11:53:05 am »
Sorry bro, but...
I trust this guy and I'm standing there watching. My disappointment was the stock HP :-\, I read a report when I was shopping for buying the C14 that the stock HP was out of the box 139HP, I assure you there was that much change :)
Offline Dave Scott
  • COG#: 8603
« Reply #23 on: August 15, 2014, 03:08:10 pm »
I'm not experienced with it, but as I understand, there can be variation between dyno machines.   from the sounds of the stock numbers, that could be the explanation there.  As to the "after" numbers, I've not heard of gains like that, but have no expertise to refute it either.
Perhaps someone with some experience will chime in with how these things are calibrated and trusted.
Offline spencer
  • Burly Biker
  • COG#: 12030
« Reply #24 on: August 16, 2014, 03:06:51 pm »
Sorry bro, but...
Okay you say it makes 133 out of the box, his was down a bit, 5-hp that's certainly within a normal range, and then with a pipe and PCV it went to 142, what is so unbelievable about that. It is totally within a reasonable expectation. 14 hp with a pipe and a tune, you're talking 11%
2009 ZG1400 Sold
2004 BMW 1200RS Sold
2002 ST1300 Sold
1999 Suzuki Bandit 1200 Sold
1996 Honda Valkyrie Sold and 20 others all sold
