Author Topic: Vented stock windshield  (Read 4073 times)
Offline Tjnoma99
  • COG#: 12686
« on: January 06, 2018, 03:21:57 am »
Will the newer vented windshield fit on a 2013? It gets warm in the summer here and would like to have the vent.
Offline Fred_Wa2gzw
  • COG#: 10400
Re: Vented stock windshield
« Reply #1 on: January 06, 2018, 04:35:41 pm »
I have read in other posts that the mounting holes are the same.  You may want to do a search.  Another solution would be the Craig Vetter snap in vents that would cost under $50.00 and have been time tested.  Here is the link to them, along with a short video, just scroll down the page to find them.
http://craigvetter.com/pages/Online_Store/Replacement_Parts/Details.html#Anchor-Original-46384
Fred
Wa2gzw
Offline Staylo
« Reply #2 on: January 06, 2018, 05:10:08 pm »
I thought I had read something about the new style windshield exerting more force on the mounting brackets, and that Kawasaki had to beef up the mounting bracket/adjusting hardware in order to account for it.
Lancaster County, PA
'11 C14
Offline Tjnoma99
  • COG#: 12686
« Reply #3 on: January 06, 2018, 06:27:59 pm »
Staylo- I'll have to look into that.
Fred- I kinda like those vents. Any idea how much air flow they allow?
Offline Fred_Wa2gzw
  • COG#: 10400
« Reply #4 on: January 06, 2018, 09:41:56 pm »
In reality I don't know how much air will flow,  but you could figure the area of the 2 circles and than compare that to the area of the 2015 vents and maybe come to your own conclusion.  I believe that the 2015 and later windscreens along with the venting mechanism are fairly expensive unless you can find a used one on ebay.
Fred
Wa2gzw
Offline JDSCO
  • 2016 C14
« Reply #5 on: January 07, 2018, 01:23:39 am »
I have a 2016 C14. The oem windscreen will fit the older year C14's.
The vent assy is attached to the windscreen via two steel brackets w/ AHCS bolts, two per side, and that windscreen assembly mounts to the brackets on your C14. That vent assy allows the vent to open and close with detent locks.
The vent, when opened, does allow noticeable air to flow through the windscreen.
The oem windscreen is taller than previous years, too tall for me, the vent vibrates and it's difficult to clean around the vent area.
I replaced the oem with a MRA Vario screen. I am a sport rider.
I had to purchase the older style rubber gaskets and appropriate hardware for adapting the MRA to the 2016.
Gen James Mattis
Offline Tjnoma99
  • COG#: 12686
« Reply #6 on: January 07, 2018, 01:31:55 am »
Good to know! Looks like im better off with the vetter vents. Thanks for all the help everyone!
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #7 on: January 07, 2018, 11:38:50 pm »
I don't open the vent for air flow.  At least, not for cooling. I just lower it.
The vent is to stabilize the air to reduce buffeting, which it does very well.
If it does offer rider cooling, I dont notice it.
Offline Deepsea
« Reply #8 on: February 16, 2018, 08:25:21 am »
I installed the Vetter vents in a VStream early last summer as well as cutting out the small triangular center section to relieve back pressure. The vents work great and are easy to install.
Retired Navy Saturation Diver
Offline Egodriver71
  • I'm in here somewhere
  • COG#: 8321
« Reply #9 on: February 16, 2018, 01:35:06 pm »
Look into a `08-`09 stock windshield
Works great in the summer here in humid FL.
Thomas Mann
Jacksonville, FL
COG #8321
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #10 on: February 16, 2018, 10:26:32 pm »
I found there was more air if I just lowered the screen.
Offline bowtie39
  • COG#: 10014
« Reply #11 on: February 16, 2018, 10:50:07 pm »
Would like to see that revised shield with the Vetters.   :great:
Offline Just Cliff
  • COG#: 9547
« Reply #12 on: February 16, 2018, 10:50:17 pm »
Look at the MRA Vario, smaller than the 08 & 09's. Lot's of smooth clean air!
Cliff   :beerchug:
Cliff
2014 1000 V Strom
Offline Rob9876
« Reply #13 on: February 16, 2018, 11:01:53 pm »
^^^Same here on all of the above.  In fact, even with the vent open I sometimes have to lower the windscreen to get enough air to un-fog my helmet visor.
Offline Deepsea
« Reply #14 on: February 17, 2018, 07:04:50 pm »
I'll post some pics when the bike finally clears customs and I have it back. Should be around the first week of March.
Offline Tjnoma99
  • COG#: 12686
« Reply #15 on: February 18, 2018, 02:30:16 am »
How much does it help the buffeting? I just put a vstream on. Its good but not great! If i could eliminate even more buffeting, im in!
Offline Deepsea
« Reply #16 on: February 18, 2018, 06:33:22 am »
In the lower half/center there is a "V" shape forming an inverted triangle. I cut out a section starting at the bottom of the "V" going up so that the horizontal cut line is approximately 4 inches long. I think it helped a lot, but that's just my subjective opinion.
Offline JDSCO
  • 2016 C14
« Reply #17 on: February 18, 2018, 03:40:24 pm »
MRA Vario
This windscreen is quite aerodynamic and these cutouts aid in that airflow
This MRA is a huge improvement relative to the 2016 oem vented windscreen
I'm a sport rider with touring tendencies
« Last Edit: February 18, 2018, 03:44:23 pm by JDSCO »
Gen James Mattis
Offline Tjnoma99
  • COG#: 12686
« Reply #18 on: February 18, 2018, 03:58:09 pm »
I have the vstream now and im not impressed at all!
Offline Deepsea
« Reply #19 on: February 18, 2018, 06:17:32 pm »
If you do cut out the VStream be careful not to go to large. The idea is to create just enough laminar airflow to relieve back pressure not create turbulence. The other option is to raise the bottom edge but thats more difficult to calculate airflow since it's a variable opening depending on height setting.
Offline Tjnoma99
  • COG#: 12686
« Reply #20 on: February 18, 2018, 07:47:47 pm »
If i cut a windshield its gonna be my stock one!
Offline Deepsea
« Reply #21 on: February 20, 2018, 07:57:55 pm »
I have a stock 09 shield that I cut just about in half for hot summers and track days.
« Reply #22 on: March 14, 2018, 03:50:49 pm »
Cliff   :beerchug:
I agree with Cliff. {don't tell him I sed that}
Like he said, lots of smooth clean air.
In the full up position/vent fully folded out, it keeps you amazing dry in a rain storm because of how it deflects the air.
  Almost as much coverage as a stock shield in up position,,, but way smaller...
Offline Deepsea
« Reply #23 on: March 15, 2018, 06:33:54 am »
Here's photo of the stock 09 screen cut down. The bike is still being held for customs clearance so I can't post a photo of the V Stream yet.
Offline Egodriver71
  • COG#: 8321
« Reply #24 on: March 15, 2018, 10:26:29 am »
To help notice the difference
Thomas Mann
Jacksonville, FL
COG #8321
