Author Topic: V&H CS One question  (Read 1409 times)
Offline 1965soda
  • COG#: 10056
V&H CS One question
« on: April 10, 2012, 05:57:08 pm »
Question for other V&H pipe users.....
I recently installed a CS One and had the ECU reflashed by Guhl.  I am thoroughly impressed with the results but have a product question on the pipe.  The instructions indicate the mid-pipe should have a slotted end where it connects with the header collector.  Mine does not.  Install went very smoothly and the pipe and muffler are very secure however I am detecting an ever-so-slight exhaust leak at the mid-pipe / collector connection.  I have loosened, repositioned the clamp and re-tightened to see if I can eliminate it but to no affect.
For other CS One owners, did your mid-pipe come with a slot at the one end and if not, did you cut one?
Thanks!
Currently in garage: 2011 C14, 2007 FZ1, 2001 M900 S4, 1983 900 Seca, 2003 ZRX1200, 1982 650 Seca, 8? Husq 430
Rides of the past: 2002 ZRX1200, 1986 900 Ninja, 1999 Ducati 900ss, 2002 R6, 2005 FJR, 1998 C10, 1998 VTR1000, 1989 1100 Katana, 1983 CB1100F, 1985 900 Ninja, 1983 900 Seca, 1982 Seca turbo, 1982 CX500 turbo, 1982 750 Seca, 1983 550 Vision, 1974 CB400F, mid 70's Rupp :-)
Offline stl-cards
Re: V&H CS One question
« Reply #1 on: April 11, 2012, 11:21:36 am »
Mine came with a slot.   Just installed it 2 weeks ago.   That seems very strange.
I would ask for a new pipe b4 cutting.   Worth a shot.  I guess its not a big deal either way.   Good luck.
2011 Kawa C14
2009 Kawa C14
2006 Suzuki c90t
Offline stl-cards
« Reply #2 on: April 11, 2012, 12:51:24 pm »
I tried to take a pic of the header / mid pipe connection.  The clamp is blocking the slots.
2011 Kawa C14
2009 Kawa C14
2006 Suzuki c90t
Offline 1965soda
  • COG#: 10056
« Reply #3 on: April 11, 2012, 01:55:05 pm »
Thanks for the reply stl-cards....very helpful.  I will reach out to V & H and see what they think.  I am otherwise very impressed with the quality of the CS One and the sound is really nice....maybe a little aggressive when sneaking out of my neighborhood for my early commute.  I may ask them to send me a sound insert at the same time.
Thanks again for the info!
Offline stl-cards
« Reply #4 on: April 11, 2012, 02:36:46 pm »
There are a few inserts.  I think the part numbers are on the installation instruction sheet.
Personally i like the sound!
2011 Kawa C14
2009 Kawa C14
2006 Suzuki c90t
Offline Larry
  • COG#: 9359
« Reply #5 on: April 11, 2012, 02:39:42 pm »
I installed the 1 7/8 insert in my CSOne and it quiets it down a bit but it still sounds great.
10 Kawi Concours 14 ABS
Offline Con05_NH
  • COG#: 8318
« Reply #6 on: April 12, 2012, 11:22:18 pm »
I spoke with them and put on the 1.5" insert. The sound is somewhat more mellow.
