Author Topic: What is the best Throttle Lock or Cruise control for the C14?  (Read 11550 times)
Offline 4Bikes
Re: What is the best Throttle Lock or Cruise control for the C14?
« Reply #25 on: April 03, 2015, 12:00:46 pm »
I'm with Matt, ROSTRA!!!!
I can probably afford the Rostra, and could install it. I just don't ride enough slab, or commute so I can't justify it. For now the O-ring is working when I need a break on the throttle hand. It could help with speeding I suppose, because the C-14 has two speeds when on the throttle. Fast and FASTER  :motonoises:
« Reply #26 on: April 03, 2015, 12:03:39 pm »
Does rostra have a cruise control that just bolts on the C14 yet? I'm comfortable with wrenching and did the valve adjust myself, but for some reason, i'm a little timid about hacking up my bike and Macguyvering a cruise control thats really meant to be used on a car. It just doesn't feel right in my book.
Thoughts?
You did you own valve adjustment and your worried about doing a Rostra install??   You will not have any issues installing a Rostra. You have already proven your abilities.
NO you  do not 'hack up ' or MacGyver your bike. The install is clean and professionally done. All the leg work has already been done for you and there are thousands  and thousands of bikers with Rostra's already  installed.   Why dont you read up on the installation  first so you have an idea of  what is involved.
Offline mattchewn
« Reply #27 on: April 04, 2015, 01:16:46 am »
X9rider,
I have now done 2 Rostra installs. one on an '09 and one on a '12. Almost identical with the exception that the '09 is getting canyon cages requiring a different mounting location for the unit. I am spending far more time doing cleanup on the wiring than on the actual hookup. I cut over three feet out of the harness and soldered it all back together. This way there is no slop hanging out and needing to be tied up and out of the way. The only thing you have to work at is drilling the arm on the throttle body for attachment of the cable. you would have to do this same procedure even with the 1000.00 McCruise unit. Take your time and make it as clean as you want. It really isn't hard.
NOTE:  A large selection of Posi-Taps is a wonderful thing to have.
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Offline x9rider
« Reply #28 on: April 04, 2015, 02:10:19 am »
I had the chance to try on of the units that look like calipers and fasten onto your grip. I think it was the gocruise unit. I see what you mean about decel on hills. Its much better for slabbing it.
2010 Concours ABS - Blue
Offline Nozzlehog-C-14
  • COG#: 11783
« Reply #29 on: April 04, 2015, 11:48:26 am »
I put a Throttlemeister heavy throttle lock on my 2014. I've been very pleased with it. It's easy to install and it works great! It looks great and they offer several options on finish. It keeps the throttle where you set it, unlike other types I've used that either vibrate loose or drag when off if adjusted to keep it locked. It's safe to use and releases quickly, if needed.
A nice bonus is a reduction in high speed vibration due to the heavier than factory bar weights/throttle lock.
It comes down to a cruise control (apples) to throttle lock (oranges) comparison and personal preference. The Throttlemeister lock is quick to install, cost less than electronic cruise, it serves the job of allowing one to rest their throttle hand, and it's safe since it's easy to disengage or it's friction can easily be overpowered in case of emergency.
2014 C-14
2006 Honda VTX 1800N (sold)
2004 Honda VTX 1300 R (sold)
Nozzlehog
Offline MikeJ
  • COG#: 11581
« Reply #30 on: April 04, 2015, 05:21:50 pm »
Purchased a throttlemeister over the winter. Only tried it a couple of times but pleased with it as far as relatively flat slab riding goes, although I agree it's not ideal for hilly country. Excellent, precision quality item but got to pay close attention to getting the shims correct when installing it.
2014 Candy Cardinal Red
Offline freebird6
  • COG#: 11012
« Reply #31 on: April 04, 2015, 08:53:36 pm »
to GPD: I have been looking at the Kaoko one too, and do they come as a pair, or just one side?
Chris
aahaaha
the defiinition of obsessive. Got to have both sides the same. :)) :))
I am with ya there. I had throttlemeisters on mine. Looked good and matched
Offline gpd323
« Reply #32 on: April 04, 2015, 11:19:45 pm »
Chris
LOL! only throttle side my friend! :beerchug: Look like OEM bar weights.
Offline landman
  • COG#: 11621
« Reply #33 on: April 08, 2015, 03:55:50 am »
Omni-Cruise throttle lock, well constructed, the owner has a C14.
http://www.omni-cruise.com
+1 on the Omni cruise.
2015 ninja 1000 abs
2014 concourse 14
2012 concourse 14- sold
Offline Bobby Lee
  • 2010 Neptune candy blue
  • South central
  • COG#: 11740
« Reply #34 on: April 15, 2015, 08:44:17 pm »
+1 on the throttlemeister
Love the change
Offline Brant Bandit
« Reply #35 on: April 15, 2015, 11:59:34 pm »
So I've put just over 1000km on my bike, with probably 50-60km using the throttlemeister. I love it. It's fantastic. No slippage.....perfect precision fit. I was alone on a stretch of hilly road and turned it on....it slowed down and sped back up but I just let the bike do it's thing.
They look great....no added bulk, levers, or switches.....and it works much better than the the old vista cruise I had on my last bike.
Short of a real electronic cruise system, the TM rocks.
Offline CW
« Reply #36 on: April 16, 2015, 02:43:45 pm »
Got the TM on mine, but it's so hilly around here that I rarely use it. I can't stand constantly having to adjust it, and I hate dropping from 80 to 45 when climbing a hill...and it's probably a bit dangerous if I did. Gotta admit, though, the TM on long trips at least gives the right wrist a welcomed break now and then, even if just for a few seconds.
2010 Neptune blue C-14
2009 KLR
2103 DR-Z400S
Offline Scup
  • COG#: 11596
« Reply #37 on: April 16, 2015, 04:16:30 pm »
This is a good looking unit. Hope it works.
I can't stand the bar end units = somewhat difficult and somewhat dangerous to apply.
https://www.kickstarter.com/projects/1830026006/atlas-throttle-lock-a-universal-motorcycle-cruise/posts/1160562
It's nice just to flick ones thumb.
Josh
Offline CDawg1506
  • COG#: 11421
« Reply #38 on: April 16, 2015, 08:57:09 pm »
I started with a Omni-cruise and went all in on a Rostra after 3 months. Didn't like adjusting it all the time. Too many hills around here.
Offline Larry
« Reply #39 on: April 17, 2015, 11:01:39 am »
I just installed a Throttlemeister on my new C14.. I have had one on every bike I have owned for the last 15 years
Larry
Melbourne FL
2015 C14 "Green Goblin"
"Ride like the wind, straining the limits of machine and man"
Offline RideBellChain
  • I ride because I can...
  • Nothing like a good sweeper on an empty road...
    • RideBellChain.com Send a bell, receive a free bell!
  • COG#: 10039
« Reply #40 on: April 18, 2015, 10:08:41 pm »
I have the Throttlemeister  It slips after a few minutes.  I removed a thin shim, it's an improvement.  Not sure if I want to pull out another, because I want to be able to "override" it when necessary without turning it off. Maybe I'm expecting too much.  Had the other type before that locks on the brake lever, but that slips, too.
What's the level of effort for the Rostra, and where's the best deal?
BTW: that Atlas kickstarter one ... $105????  Really?
Ride Safe!
Mark
http://www.RideBellChain.com
Road Captain SCRC 456 - West Palm Beach, FL
ROK ROK100028857
Offline mattchewn
« Reply #41 on: April 18, 2015, 11:22:38 pm »
Mark,
I would rate the Rostra install a 6-7 out of ten on a difficulty. Ten would be equivalent of a full on valve adjust using only pliers.
It takes a fair amount of time to do it right. There is nothing specifically "hard" on the install, just time consuming and even a bit tedious. An accomplished motorcycle tech should be able to pull it off in 5-6 hours doing high quality work. I can do it in about the same time frame now that I have done 2.  You do need to have ALL the pieces of the puzzle ready and waiting at one time.  Here is the kicker;  do not allow yourself to get psyched out about the difficulty of pulling the plastics and doing the install. It really is NOT that hard. Take your time and solder all your connections, route the wires neatly and cleanly so there will be no issues later on down the road. Wrap everything with corrugated tubing to keep it from being chafed.  Last step, ENJOY THE NEW CRUISE THAT YOU INSTALLED!!!
Sorry Murph, The best deal is on Amazon for 172.00 for the unit, and 75.43 for the lighted switch with the engage light. Free shipping too.  Get the began switch mount from Murphs for 20$
Or bring it by with a keg  (imported only please) and I will do it.   :)
2011 GSX1250 FA
Offline Sailor_chic
  • COG#: 11610
« Reply #42 on: April 19, 2015, 02:05:54 am »
Wow Matt, you work cheap! Had I known this earlier I would have had you install mine. Of course I would of had to make sure that beer stayed fresh on top of the keg for you. This would have required frequent sampling on my part.
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline Flat-spot
  • COG#: 11111
'08 C14
Offline mattchewn
« Reply #44 on: April 19, 2015, 10:45:55 am »
FS,
That one does NOT have the engaged light.
2011 GSX1250 FA
Offline Sailor_chic
  • COG#: 11610
« Reply #45 on: April 19, 2015, 11:28:08 am »
IMO, I would order one with the engage light.  I didn't think it was a big deal when I ordered my CC, but now that it's installed, I'm certainly glad to have that little light. And CC!!
« Last Edit: April 19, 2015, 04:47:28 pm by Sailor_chic »
2013 C14 Black
2006 Vmax
IBA # 60267
Offline Flat-spot
  • COG#: 11111
« Reply #46 on: April 19, 2015, 02:18:33 pm »
Yup,  I see that now.  Good to know.  :great:
'08 C14
