Author Topic: WIRING OF BRAKE LIGHT FOR GIVI E52 MAXI BAG WITH BRAKE LIGHT  (Read 1999 times)
Offline JJPSUPERDAD
  • COG#: 8346
WIRING OF BRAKE LIGHT FOR GIVI E52 MAXI BAG WITH BRAKE LIGHT . WE NEED THE WIRE DIAGRAM. COULD ANY ONE PLEASE HELP WITH THIS ?
THANK YOU !
Offline Texas Concours14
  • COG#: 9760
Re: WIRING OF BRAKE LIGHT FOR GIVI E52 MAXI BAG WITH BRAKE LIGHT
« Reply #1 on: August 22, 2011, 01:37:27 am »
Here is a wiring diagram for C14 brakes.  Wires are tucked in a rubber boot under the back compartment under the seat.
2010 Concours 14
Offline 911ZG guy
  • COG#: 8019
« Reply #2 on: September 03, 2011, 09:35:34 pm »
so, I suppose that I would be dreaming if I wanted to buy a connector for this that would be a plug-n-play?
Offline Mad River Marc
  • COG#: 8442
« Reply #3 on: September 03, 2011, 09:45:11 pm »
It's not that difficult to splice in,   as long as you aren't tying in too big a load
  • COG#: 8442
« Reply #4 on: September 03, 2011, 10:03:05 pm »
JJ where are you located, if you are near NYC I could assist you with this...it's VERY easy if you have a multimeter :)
Offline JJPSUPERDAD
  • COG#: 8346
« Reply #5 on: September 04, 2011, 12:53:52 am »
Thank you very much !
 I got it the connector from the mount plate to the givi case need to be cleaned, there was to much grease inside the spring loaded terminals.
Which seat do you have my stock seat hurts after a little while, The 2004 concours we had a much better stock seat. we also tried a corbin  on the 2004 connie and it last 2 days to firm.
Offline 911ZG guy
  • COG#: 8019
« Reply #6 on: September 04, 2011, 01:00:12 am »
JJ- I had a problem with my E52's electrical connector when it was very new. The set screws inside the box were not tight. I popped the cover off , tightened the set screws, applied some nail polish (you might want to use threadlock) to the setscrews, and I have not had any other issue with the lights in a very long time. It seems to me that Givi should have done that at the factory.
Offline 2fast
    • ZG Heat Shields
« Reply #7 on: September 04, 2011, 01:51:05 am »
If you really want plug and play, Jim Davis at http://easternbeaver.com/ could probably make it for you. Super nice guy.
Brian in Minnesota
