AdMore;
(unless I am totally confused) There is an error in the (LED470-KAW-T-TS-LIGHT KIT) installation instructions:
The instructions say Green is Right side/yellow is Left side..
On my bike wiring (2014 C-14); green is on the LEFT side and I hooked it to your GREEN plug. (ie: green to GREEN)
There is not a yellow (nor green) wire on the right side on my bike.
(Don't recall the color, but it was not yellow or green).
I hooked the Right side to your Yellow plug. (ie: ?? to YELLOW)
I followed thru from there (with Green on left and yellow on right) and all worked out fine...
VERY IMPRESSIVE LIGHTS!!!!
Hi Ted,
Thanks for your post. You may be a little confused (not totally but just a little!). The AdMore C14 adapter that you bought with your AdMore Light Kit comes with the following instructions:
"Unplug the three (3) OEM connectors and connect the AdMore PH-KAW1 Plug-n-Play Adapter (Green = Right, Yellow = Left)."
The green and yellow wire colors are in reference to the adapter connector colors (not your bike wire colors). So, the green connector on the AdMore adapter should be connected to your C14's right side OEM connector and the yellow connector on the AdMore adapter should be connected to your C14's left OEM connector.
The fact that your light kit is operating correctly with the green connector on the left and the yellow connector on the right is interesting but as long as your AdMore lights flash with your respective right and left OEM turn signals, you're all good! Glad to hear that you are pleased with the final outcome!
