Author Topic: #2 Carb for a C-10  (Read 464 times)
Offline Brian
  • COG#: 6374
#2 Carb for a C-10
« on: March 08, 2012, 01:15:31 am »
Due to a ham fisted previous owner,  I am looking for a #2 carb body for a 2000 C10.   Preferably I am looking for only the body for number 2 as the remaining 3 are fine, but I would consider a full rack.   If you can help out me out I can be emailed thru the forum or directly at bheiple at gmail dot com.
If you are wondering why I need the #2 body, when I pulled the carbs off for their first service since I bought it over 40,000 ago. I discovered that the hole where the needle from the air pilot screw protrudes had several cracks spiraling outward from it.  It appears whomever serviced the carbs before I bought the bike got carried away and overtightened the screw causing it to crack the body.
The Other Brian in Minnesota
2010 Yamaha FJR
Offline hlh1
  • COG#: 548
Re: #2 Carb for a C-10
« Reply #1 on: March 08, 2012, 02:06:49 am »
There's always a few complete carbs on Ebay for the C10.  That's where I got a set for $35 and I'm using them now.
92 GW1500A, 06 WeeStrom, 09 C14 ABS, 09 C14,
