Author Topic: 2005 Remnants - Free for the taking  (Read 766 times)
Offline Jorge
  • COG#: 9297
« on: July 20, 2017, 12:53:43 am »
The remainder of my 2005 Connie are available for anyone who would like to pick her over.
Bike was a solid runner, with no issues until the fateful day in Sept last year.
Remaining items, and my assessment of condition, on her include:
- Swingarm: Good shape. Bearings felt smooth.
- Driveshaft
- Rear shock & Rear Links: No leaks, lubed regularly
- Rear subframe
- Lower engine, clutch, & tranny. All worked smoothly. clutch fluid changed several time, so should be in very good shape. Head still attached, but broken upper left motor mount.
- Complete front forks. Not sure if tubes are straight. Oil changed at least twice. Seals not leaking.
- Frame, bent.
- Header pipes, very little corrosion.
- Radiator, no leaks, but dented in crash.
See photos for contents.
Free for the taking, but take all or nothing. Want it out (so does Irene!!)
Offline Stealth Connie
    • Don B Waln Facebook
  • COG#: 8503
Re: 2005 Remnants - Free for the taking
« Reply #1 on: July 20, 2017, 02:58:25 am »
I need the temp gauge (one right above the carbs). I got a little frisky installing my carbs last time, and broke the riveted tab off. I wrapped and tapped wire around the pin for now, and it seems to be working, but eventually, I'd like to fix it correctly. I'll paypal you $$.
97 Concours Stealth Connie - RIP
98 Concours Mean Green - RIP
98 Concours Black Stallion - Current bike
Offline ron203
  • COG#: 9847
« Reply #2 on: July 20, 2017, 09:09:04 am »
...and a moment of silence... She served you well.  :(
2014 C-14
Offline Mike
  • COG#: 12032
« Reply #3 on: July 20, 2017, 03:26:50 pm »
How the bevel gear?
Offline Jorge
  • COG#: 9297
« Reply #4 on: July 21, 2017, 02:00:07 am »
hi Mike,
Final Drive is in great shape, and is already removed from the carcass.
I changed the oil regularly, using good quality synthetic gear oil. The spline was lubed well with marine spline grease at each tire change (I figured if marine spline grease works for 300hp+ engines, it should work on the Connie, and it provides good corrosion protection to boot!).
The attached photos show its condition. I don't think there is any wear on the splines, only a slight polishing from the wheel's mating spline.
How does $40+shipping sound?
Offline Jorge
  • COG#: 9297
« Reply #5 on: July 29, 2017, 10:06:38 pm »
OK... bumping this to give one more chance in case there is a taker out there.
Good engine bottom end, and other components.
Will go to junkyard, or recycling, or ??? in about a week. If anyone is interested, let me know.
Jorge
Offline Mortech
  • COG#: 12208
« Reply #6 on: July 29, 2017, 10:11:04 pm »
DAMMI , if you were within 2 states of me , me and my truck would be on the way
1999 Kawasaki Concours - Conrad
2006 Honda CBR600F4i - Restless
2009 Kawasaki Concours - Constanza
  • OtP Co-ordinator (USA) (ie: Slave Labor)
« Reply #7 on: July 30, 2017, 01:14:25 am »
You said the motor was good, but the upper motor mount was broken?
As I recall, that motor mount is part of the head......
Sooooo, someone with a hydrolocked Connie could use the engine, install their head on it,, and be back on the road...
Anyone out there have a hydrolocked Connie?     hint hint!!!!
14 Connie (Traveler II)
03 Connie (Buddy)
Offline Anthony
  • COG#: 12574
« Reply #8 on: July 30, 2017, 09:32:08 pm »
Whatchu talkin' bout Willis?
Offline Jorge
  • COG#: 9297
« Reply #9 on: August 05, 2017, 03:46:58 pm »
Correct Mr. Ted (you like the formality?   don't get used to it :)
Yes, head is scrap aluminum; bottom end and tranny are (were?) in perfect working condition.
« Reply #10 on: August 05, 2017, 04:33:30 pm »
Someone with a hydrolocked engine, NEEDS to contact Jorge "Mr Jorge",,, NOW!!!
  {Ok Jorge, we're even. E'nuff of this nice talkin' stuff, ya Bum}   ;)
PS: Vacations over. Get back to work. "OtP 2018" needs to be started...
       {Being a really nice guy}  O:-)
                        I contacted Hans, {yer Boss}.
            He has the Flog-O-Matic warming up. {to enhance your initiative}
                                            :s_laugh:
« Last Edit: August 05, 2017, 04:36:46 pm by connie_rider »
03 Connie (Buddy)
