Author Topic: FS - C10 Trailer Hitch - $75 - FS Now SOLD  (Read 374 times)
Offline Stasch
  • COG#: 6830
« on: July 19, 2017, 06:54:33 pm »
Trailer hitch for sale from a '93 C10.  It will fit all C10 years 86-06.
I bought from a C10 owner with the intention of pulling a trailer for all the extra stuff my wife wanted to take for 2 up motorcycle trips.  She ended up with her own bike so I won't be using it - never had it mounted.
Not sure of brand but its similar to Hitch Doc in shape.  Note: The receiver is different than Hitch Doc.
Connects to rear bolts of rear outside footpeg mounts and behind / under the antler stays (Part No: 35011-1299 not to be confused with the antler itself) at the rear most mounting bolt.
Rear of hitch tucks inside bottom rear fender, mostly hidden when viewed from the back.
Helmet locks must be removed from the OEM position.
May need some longer bolts all around, and washers to use as spacers for the front mounts of the 35011-1299 stays.
The horizontal 'U' clears the rear caliper (right) and drive 'pumpkin' (left).
Do not have the hitch / ball or its bracket to fit into the receiver.  A welder should be able to fabricate something that works.
It needs a light sanding followed by rattle can primer and black paint to look its best again.
$75 plus shipping from zip code 48433.
Shipping Wt: 12 lb.  Size:  24" x 17" x 5".  (I can calculate your shipping if you provide your zip code).
« Last Edit: August 30, 2017, 05:07:11 pm by TimR, Reason: Sold »
Offline Stasch
  • COG#: 6830
Re: FS - C10 Trailer Hitch - $75 - FS
« Reply #1 on: July 19, 2017, 06:57:58 pm »
One more pic.
Offline dboogie2288
    • BeginnerBikers.org
  • COG#: 11628
« Reply #2 on: July 19, 2017, 07:09:59 pm »
Does it come with the paired tongue and ball?
Current Bikes:
« Reply #3 on: July 19, 2017, 07:32:43 pm »
That looks to be a Unigo hitch, make sure it has the brackets,
The other stuff, ball plate and adaptors can be gotten from Unigo for easy boltup ...
Here's a reference of the hitch..
http://www.unigotrailers.com/product/kawasaki-concourse-pre2009/
Offline Stasch
  • COG#: 6830
« Reply #4 on: July 19, 2017, 08:38:13 pm »
I do not have that part of the hitch.
MOB - thanks for confirming the possible brand.
The pic in the Uni-Go link sais its Pre 2009 - C14 ??   The vertical arms are placed farther forward in the pic than the ones I have.
Everything I have is shown in the pics.  The vertical brackets align perfectly as is, placing the upper half of the receiver hidden behind the lower rear fender.  Anybody know if the entire receiver part is supposed to be lower than this?
If so, the brackets (or something like it) as shown in the link MOB provided would lower it.
Doesn't look like it would be very hard to fabricate those if not available.
Offline Stasch
  • COG#: 6830
SOLD: FS - C10 Trailer Hitch - $75 - SOLD
« Reply #5 on: August 30, 2017, 01:13:05 pm »
The hitch has been sold
