Author Topic: Searched but can't find (Mode Button Mod)?  (Read 2237 times)
Offline Bobby M.
« on: May 31, 2011, 07:46:40 pm »
A friend told me there has been a few people to use their "high beam flash" trigger to operate the mode switch on the 08-09 dash.
 Anyone have a link to what was done?
BR MUNROE
'09 C14
Offline Necron99
  • rise again....
  • COG#: 9384
Re: Searched but can't find (Mode Button Mod)?
« Reply #1 on: May 31, 2011, 08:40:02 pm »
Is there a mod to use the high beam flash to do that AND fire the forward guns?   :rotflmao:
Offline Grumpy Goat
  • IBA 57952
    • The Grumpy Goat blog
  • COG#: 8923
« Reply #2 on: June 01, 2011, 01:43:58 pm »
Bobby M: I recall it too. The information including pics was on the ZG Fanatics forum before it crashed.
I recall that the mod is to solder a wire to one of the connections on the circuit board in the instrument cluster and wire it to ground when the headlight flash switch is flipped. Unfortunately I have no idea which part of the circuit board it is.
Sorry.
2008 Kawasaki 1400GTR;  1986 Kawasaki 1000GTR;  1985 Kawasaki GPz900R;  1984 Kawasaki GT750;  1982 Suzuki GS650GT;  1981 Honda CX500;  1979 Kawasaki Z400;  1978 Kawasaki Z200
Offline Bobby M.
« Reply #3 on: June 01, 2011, 03:13:12 pm »
I guess I'll have to find a wiring diagram and trace it down.
BR MUNROE
'09 C14
Offline Russ
« Reply #4 on: January 01, 2012, 06:33:23 am »
Any luck with this??
08 C14
SOLD - 05 Victory Ness Vegas, 06 KLR650, 04 VT1100 Spirit, 01 VT750 ACE, 1986 VFR750F, 1991 CBR1000F
AMA# 2794531
Offline Wyorider
  • COG#: 10331
« Reply #5 on: January 01, 2012, 08:53:07 pm »
I did this on my 06 ZX14 and my buddies 08 Connie.
 Here's a pic of the back of the dash board.The top one is the mode button.Pretty easy to do.I've been using the model airplane connectors so I ca disconnect everything if I have to take the dash out.
 Then from there all you do is run a wire up to the left controls and splice into the pass switch.
Offline Amoray
« Reply #6 on: January 02, 2012, 12:48:08 am »
THIS IS A WICKED EASY MOD...  I INSTALLED A SEPRATE WEATHERPROOF BUTTON  SWITCH .  MAKES IT NICE TO SWITCH SCREENS ON THE FLY...
Offline Russ
« Reply #7 on: January 02, 2012, 10:44:38 pm »
I'm assuming that the location where the wires are soldered is also the location of the lower switch?  Great info - Thank You!
08 C14
AMA# 2794531
Offline Bobby M.
« Reply #8 on: January 03, 2012, 01:57:46 pm »
Thanks BJ, That's what I was looking for.
BR MUNROE
'09 C14
Offline Gypsy JR
  • American Gypsy
  • Living the Gypsy Life
  • COG#: 9279
« Reply #9 on: January 03, 2012, 02:21:44 pm »
Caps lock challenged?
Offline Huero
« Reply #10 on: April 29, 2012, 04:49:22 am »
http://www.zggtr.org/index.php?topic=6597.0
This write up from the other board shows the wire being soldered in a different spot. Can anyone advise which place is correct? Or, if either will work? I would like to make my flash to pass button scroll through instead of adding another switch. I never use the flash to pass button anyway.
I am really not sure how to undo or unhook the FTP button to use it just for this mod. Does anyone have experience with this?
Thanks for all the help,
Huero
