Author Topic: 2011 Kawasaki 1400 Windshield Rest removal !  (Read 849 times)
Offline Formichella
  • Florida 1 Mad Max
  • COG#: 12365
« on: December 22, 2015, 05:52:57 pm »
how do I delete Windshield Rest when key turned off , seems like a lot of wear and tear on motor , I would like to  leave it up !
should be a wire I can cut on ECU or ECM ????????
John Boy
Offline SWOJO95
  • COG#: 190
Re: 2011 Kawasaki 1400 Windshield Rest removal !
« Reply #1 on: December 22, 2015, 06:11:08 pm »
I don't know if you can choose for it not to move at all?  You can chose 1 of 4 positions for it to return to.  I believe if you normally have it all the way up, it will remain there if you chose that position? It is in the Owners Manual, on pages 51 & 52 for 2012 model. It is accessed thru the menu, "windshild set", and there are 4 positions to choose from. I think "4" is all the way up?
Offline Formichella
  • Florida 1 Mad Max
  • COG#: 12365
« Reply #2 on: December 22, 2015, 06:21:09 pm »
Thank you , never got a manual but will download one tonight !,  Be safe, see everybody in Helen Ga, this summer  !! Ride safe Ride Often ! 85 here in Sunny Florida !!!!!!!
John Boy
Offline CW
« Reply #3 on: December 22, 2015, 06:55:09 pm »
Depress the shield up/down button as you turn off the ignition, and the shield stays put.
2010 Neptune blue C-14
2009 KLR
2103 DR-Z400S
Offline LSGiant
  • COG#: 7524
« Reply #4 on: December 22, 2015, 07:12:11 pm »
+1. On the quote, or I think it is on a separate fuse you could remove.
COG 7524 IBA 46513 GLMC 214
