Author Topic: brake rotor bobbin question  (Read 3981 times)
Offline Con05_NH
  • COG#: 8318
Re: brake rotor bobbin question
« Reply #25 on: October 10, 2017, 11:56:58 pm »
The procedure is very simple. Use a nut, lock washer and bolt snug enough to prevent slipage. Free up and spray with cleaner while turning. This simple procedure fixed my slight pulsating problem. I was on my 2nd set of rotors, had crosshatched, cleaned and installed new pads and still had issue. Once complete make sure slot is facing down. When i did mine 20,000 miles ago grit came out of each button. It takes all of 15 minutes. Give it a try. You may be surprised.
