Author Topic: 12v plug that stays put in the 12v receptacle?  (Read 4330 times)
Offline MJinCP
  • "I'm not quite dead yet." - Monty Python
« on: May 06, 2015, 09:40:21 pm »
I know there are other options, such as the USB and the Battery Tender-type plug, but has anyone come across a plug that goes into the stock 12v receptacle (commonly known as a cigarette lighter plug) on the dash and stays solidly connected while riding?  I've tried a couple different ones, but all seem to vibrate out after a bit of time.  Heading off on a 4-day ride soon, and would like to use the plug to charge my cell phone and GoPro.  I'll be camping, so no hotel room outlet to plug into at night.  Thanks!
Mike
2013 Concours 14
2012 KLR650
1983 GPz 550
2023 Concours 16 (planning ahead)
Offline ZG
  • COG#: 9735
Re: 12v plug that stays put in the 12v receptacle?
« Reply #1 on: May 06, 2015, 09:49:54 pm »
Offline MJinCP
« Reply #2 on: May 06, 2015, 09:55:37 pm »
Powerlet plug, here's a link to my install...  :beerchug:
http://forum.cog-online.org/index.php/topic,38323.msg218557.html#msg218557
Yea, I get that ZG.  But what I'm asking is if anyone has found a 12v plug that stays connected in the stock 12v outlet on the dash without vibrating out.
Mike
2013 Concours 14
2012 KLR650
1983 GPz 550
Offline Flat-spot
  • COG#: 11111
« Reply #3 on: May 06, 2015, 09:57:29 pm »
Nothing stayed plugged in for me either.  Jam something in beside the plug for a temporary fix.
I had the BT pigtail so I got one of these until I get proper sockets installed.
'08 C14
« Reply #4 on: May 06, 2015, 10:02:22 pm »
wrap a rubberband, a small one, around the device plug about 1/4" inward of where the opening comes to... works great.
also, with the bike off, reach up behind that socket and firmly tighten the nut that holds the socket in, when you ride with something plugged in, it tends to loosen, and the socket will pop out... damhik
I've also jambed a strip of innertube down alonside the plugin, opposite the side contact on the plug, this seems to work best... but you might want to tie a piece of string to it, and to the flap cap, so you don't loose it...
« Last Edit: May 06, 2015, 10:05:49 pm by MAN OF BLUES »
Offline Matt
« Reply #5 on: May 06, 2015, 10:40:50 pm »
I have the same problem.  I bought one of these, and it actually stays put.  I got mine at Walgreens but I see them for sale everywhere.
2013 Concours 14
2012 Suzuki GSXR 1000 (sold)
2011 Suzuki M109 LE (sold)
2005 Suzuki GSXR 1000 (sold)
2004 Suzuki GSXR 600 (sold)
1993 Kawasaki Vulcan 1500 (sold)
Offline MikeJ
  • COG#: 11581
« Reply #6 on: May 06, 2015, 10:43:23 pm »
Use a toothpick between the plug and socket. Works every time.
2014 Candy Cardinal Red
Offline jwh20
« Reply #7 on: May 06, 2015, 11:26:13 pm »
2nd that!  I've found the flat-tapered ones work best vs. the round ones.  But either can be made to work in a pinch.
2012 Concours 14 Arabian Red
Offline Not So Wild Turkey
  • COG#: 10559
« Reply #8 on: May 07, 2015, 12:13:54 am »
If it's an android the motorola charger from Amazon works for me
2012 Concours Arabian Red & 80 Suzuki GS1100E
2003 VTX1800R Black / 1979 Suzuki GS1000E / 1969 Norton Commando
Yamaha DT3 250 / Kawasaki 100 G4TR
Offline stevewfl
  • COG# 9334
  • COG#: 9334
« Reply #9 on: May 07, 2015, 12:25:03 am »
the 12V outlet that comes with our bike sux, nothing stays plugged in  :truce:    :truce:    :truce:
KiPass!
Offline cuda
  • Ignorance Is Bliss.
  • COG#: 11405
« Reply #10 on: May 07, 2015, 01:32:02 am »
I use a little ,narrow strip of Velcro inside the receptacle , the fuzzy side of the Velcro. :party0036:
Offline LouSpag
« Reply #11 on: May 07, 2015, 01:49:48 am »
I must be doing something wrong because I've plugged several things into it and never had a problem. Have you guys tried to clean the inside of the plug? I clean mine when I wash the bike with a little alcohol wipe. It keeps it clean and so far nothing has come loose from it.
LouSpag
~~~~~~~One Day At a Time~~~~~~~~~
2000 ZX12r
2009 Concours 14
2012 ZX14R
Online gsun
  • CDA #560
  • COG#: 9127
« Reply #12 on: May 07, 2015, 02:24:29 am »
LouSpag
You actually have to ride the bike to get it to loosen. ;D
Offline Flat-spot
  • COG#: 11111
« Reply #13 on: May 07, 2015, 02:37:06 am »
Cuda,  I like the little Velcro strip idea. :great:
'08 C14
Offline stevewfl
  • COG# 9334
  • COG#: 9334
« Reply #14 on: May 07, 2015, 03:09:37 am »
LouSpag
+1, mine worked great up until 30-40 thousand miles, then it started spitting every thing out of it
KiPass!
Offline MJinCP
« Reply #15 on: May 07, 2015, 03:10:15 am »
LouSpag
Ouch.
Mike
2013 Concours 14
2012 KLR650
1983 GPz 550
Offline bearbait
  • Bearbait
  • COG#: 8920
« Reply #16 on: May 07, 2015, 10:07:21 am »
Is it OK to add a USB plug to the left side dash and piggy back it off the wire on the right side?  It seems to be the easiest way to add the extra receptacle in that blank spot.
2009 C14 ABS, Muzzy exhaust with Power Commander V, and best of all the Corbin Seat!
Past bikes:
1962 Honda Super 90, 1965 Honda 305 Super Hawk, 1971 Yamaha 360 Enduro, 1973 Hodaka Road Toad 100, 1973 Hodaka Combat Wombat 125, 1970 Husqvarna 400 Motocross, 1975 Honda 360 Scrambler, 1980 Kawasaki 250 Enduro, 1978 Honda 750 Four, 2000 Kawasaki C10, 2006 Kawasaki Z750S
Offline Flat-spot
  • COG#: 11111
« Reply #17 on: May 07, 2015, 10:48:08 am »
Keep in mind the factory cig. socket is a switched circuit.  Bike off-power off.
'08 C14
Offline stevewfl
  • COG# 9334
  • COG#: 9334
« Reply #18 on: May 07, 2015, 11:19:49 am »
I added a Fuzeblock and USB receptacle on the right side
finished product
sorry about the crappy phone pics right there^^^
KiPass!
Offline Flat-spot
  • COG#: 11111
« Reply #19 on: May 07, 2015, 11:26:07 am »
stevewfl,  those are better than many phone pics.  :great:
'08 C14
« Reply #20 on: May 07, 2015, 06:16:53 pm »
that doesn't work, the metal framework behind the left hand plastic has no hole like the right side has... just saving you the aggrivation....
Offline mff
  • COG#: 8168
« Reply #21 on: May 07, 2015, 07:13:55 pm »
Rotate the male connection 90 degrees- works on my garmin
Offline stevewfl
  • COG# 9334
  • COG#: 9334
« Reply #22 on: May 07, 2015, 07:53:27 pm »
When the outlet gets a slight bit looser after a few more miles, shove a toothpick in  ;D
KiPass!
Offline rogracer
  • COG#: 11346
« Reply #23 on: May 07, 2015, 08:20:10 pm »
I got a couple of "low profile" usb-type chargers from amazon that barely extend past the end of the socket. They do not vibrate out. You should be able to search for and find them.
Offline LouSpag
« Reply #24 on: May 07, 2015, 08:24:08 pm »
LouSpag
you guys are funny.  Ok, lets see after I put more miles on it if it stays put.
LouSpag
2000 ZX12r
2009 Concours 14
2012 ZX14R
