Author Topic: 2008 heat issues vs. newer models.... is my dealer lying?  (Read 6287 times)
Offline Extant
  • COG#: 10278
« on: August 03, 2012, 10:54:59 am »
Hi Guys,
I purchased a used '08 back in April (when it was cooler here in upstate NY and didn't realize the extent of the heat given off by an otherwise very nice bike),  and several months later  I'm finding the excessive heat given off by this machine quite uncomfortable at times.
Question:  Was my dealer that I traded in my 'Busa for  blowing smoke up my a** when he told me that "Listen,  I'll gladly take your money for a new Concours if you'd like, but the newer machines are not that much of an improvement as regards  the heat; the bike has three catalytic converters and these things go up to 1800 degrees!"   He continued,
saying that lots of big bore bikes have this issue,  caused largely by legal requirements for emission control etc.   Funny thing is,  when I mentioned that my BMW K1200rs doesn't have this issue,  and nor did my R1200RT or my Hayabusa,  he expressed surprise.
Looking for honest feedback here. Yeah,  it would bother me to have to unload the '08 (paid 8400 for it with 10K miles) and spring for the additional cash,  but I need the heat thing to go away......or the bike goes.   On a related note,  would installing the insulation I've seen mention of largely take care of this issue, or.....?    On an unrelated note,  I can't believe the left headlight control knob fell off the thing a few days ago.   Pretty damn annoying.
Thanks,
Extant
Re: 2008 heat issues vs. newer models.... is my dealer lying?
« Reply #1 on: August 03, 2012, 11:12:31 am »
  Some folks find the 08-09 to be warm (such as yourself). The 2010+ models are cooler because of a redesigned fairing. But before you lose a bunch of money on your bike upgrading (debatable). Why not try Zteve's heat blockers for the 08-09. Some folks swear by them, others might not care for them. You can find them in the C14 Farkle directory under heat blockers.
http://forum.cog-online.org/index.php/topic,27354.0.html
Offline Gypsy JR
  • American Gypsy
  • Living the Gypsy Life
  • COG#: 9279
« Reply #2 on: August 03, 2012, 11:18:52 am »
I think trying Zteve's heat blockers is a great idea. They are basically what the 2010+ bikes have, a nearly vertical wall of plastic, rubber, and foam which seals off the engine / radiator area so the only way the air can go thats coming in the front is out through the side vents.
Which is how they wanted it to work to begin with, but engineering didn't think about the heat running inside the fairings and radiating onto the rider's lower legs. At least they fixed it after the got a few thousand complaints.  :beerchug:
Offline Jeremy
  • I put on my pants for this?!
  • COG#: 9899
« Reply #3 on: August 03, 2012, 01:38:09 pm »
ZSteves panels work great if you spend a lot of time below 45 mph, but at highway speeds having the extra air flow keeps the tank and seat cooler for my knee and thighs.
I use my ZSteves around town, but if I am going on a road trip I take them out.  They work but there are trade offs.
Kick the tires and light the fires
Offline rcannon409
« Reply #4 on: August 03, 2012, 01:49:30 pm »
The dealer is not far off, from what I've experienced.  My Ninja 1000 has a lot less plastic around the motor, but it still throws its share of hot air.
I dont like the tank getting hot on my 08 c14, but its never stopped me from riding.  I was getting irritated riding in Southern Utah at 106 degrees, though.  Once I climbed off the bike,  I realized it was very uncomfortable outside, bike or not.  There is a lot you can do to help with the issue. The rubber blocks that mount down low help a great deal as does a piece of insulation under the tank.
If you start checking pieces of the bike with an infrared thermometer, its amazing Kawasaki did as well as they did in insulating the rider from the heat.
Offline Gypsy JR
  • American Gypsy
  • COG#: 9279
« Reply #5 on: August 03, 2012, 02:06:18 pm »
true dat
On my ZX14, they did almost nothing to stop the heat, just a couple stiff foam pieces that slid on and were held in place by the cowling pressing against them. That bike would flat cook your feet and ankles.
After I ceramic coated Brock's Performance CT-Dual exhaust system the felt heat dropped significantly, because there was less blowing back off the headers. And I purchased some additional baffling which also helped. As she broke in, the felt heat lessened some more, I guess the engine just ran looser / more free or something. When I switched to dual fans and Engine Ice, the felt heat dropped again, which indicates some of the felt heat comes from the radiator.
Offline Tundra Tom
  • XLR8
  • COG#: 8925
« Reply #6 on: August 03, 2012, 02:18:29 pm »
Buy or fabricate some lower blockers then put a sheet of auto sun shield under the tank. Leave the edges long enough to cover the seams into the side panels. These did not affect running temps. and even helped keep the glove box cooler. It's not as noticeable as appears in the photo as the flash highlighted the material.
1974 Kawasaki H-1 500
1975 Norton 850 Commando
2013 BMW GS 650 Sertao
Offline Tundra Tom
  • XLR8
  • COG#: 8925
« Reply #7 on: August 03, 2012, 02:21:02 pm »
Also cut the stock shield down for summer riding which brings MUCH more air into the cockpit.
Offline GW2
  • COG#: 8947
« Reply #8 on: August 03, 2012, 03:31:50 pm »
ZSteve's heat blockers work great for keeping the heat off of your ankles and shins.  Be aware though that they will push more heat up around the tank.  You'll need to add insulation around the tank like other folks on this thread recommended to totally mitigate the heat.
Offline freebird6
  • COG#: 11012
« Reply #9 on: August 03, 2012, 03:54:34 pm »
Thanks for this report. I had considered trying these but my shortest day on the bike is 50-100 miles of open roads in IN and OH and the only time it sees 45 is on the way up and down to a stop. THink I will save the money for another farkle.
Offline ConcoursKZ
« Reply #10 on: August 03, 2012, 04:06:39 pm »
The heat blockers work great. So does adjusting the windshield height. Bikes get hot and you have to wear long pants. I guess peoples heat level is different. Personally I think too many of you have gotten soft in your later years. Get a Can Am and have an air conditioner put on it.
Offline anthony - Sacramento
  • live to ride
  • COG#: 10001
« Reply #11 on: August 03, 2012, 06:32:48 pm »
   Zteve's heat blockers I DID TRY A SET AND YES THE HEAT MOVES OFF YOUR LEGS . but now the heat comes out around the gas tank and now your JUNK is cooking , so i took mine off , i wear boots when riding anyway so i dont feel the heat on my feet ,
love my concours 1400 , im trying to keep it stock :) hahaha
Offline mike
  • COG#: 9595
« Reply #12 on: August 03, 2012, 10:41:52 pm »
I had the same results as Anthony - Sacramento. I'd rather have warm feet than cooked... um.... well.. you know. :o
Offline Tundra Tom
  • XLR8
  • COG#: 8925
« Reply #13 on: August 04, 2012, 02:10:49 pm »
THIS will alleviate "cooked junk" for the price of a sun shieldshield. In fact there is enough material to do two C-14's. Be sure to size it from the top of the glove box to the back of the tank and leave enough around the edges to block the seams. Just saying........
Offline EnsoniqDude
  • Running Down a Dream
« Reply #14 on: August 04, 2012, 06:20:46 pm »
Cap'n Bob has listed the changes between the Gen I and Gen II C14's.  There's far more differences between the 2010+ bikes and the earlier bretheren than just heat blocking.
2010 C14 - "Neptune Blue" - All praise be unto the blessed color!
2007 Ural Tourist
1997 ZX-11
1984 Nighthawk S
1976 CB750
1965 Dream
"Chicks dig me because I rarely wear underwear and when I do, its usually something strange and unusual."
Offline mike
  • COG#: 9595
« Reply #15 on: August 04, 2012, 09:52:09 pm »
I've got that in mine.... it helps but the panels trapped too much heat into the tank area. Keep in mind I'm in florida so im getting cooked from both sides along with the high humidity. It's really only bad for a few months in the summer.
  • live to ride
  • COG#: 10001
« Reply #16 on: August 05, 2012, 07:44:38 pm »
blocking the air is going to make it go some place worse , making the motor hotter , so just deal with it as i do or sell it for a newer one ,
« Reply #17 on: August 05, 2012, 09:11:45 pm »
   OK, I kept quite on my opinion. But we need a different perspective. I had no problem with the heat blockers themselves. Although I didn't feel that I had a problem with heat. I figured that I would give them a try.They worked as advertised. My problem is that it directed more hot air out the side vents. But I get the hot sun on my upper legs (thighs) that I tend to stick out in the wind on a sunny day, at times to cool them. Well the heat blockers worked so well that I couldn't really cool my thighs now because of all the hot air coming out of the side vents. (My problem was more with the suns heat, not the bike)
   So since I didn't think there was really a heat problem in the first place. I pulled them back out. So when the sun beat down on my thighs, I again could cool them. So mine worked fine.
Offline Russ
« Reply #18 on: August 07, 2012, 12:33:46 am »
Three cats????  Where are they???  I havent found even one yet!
Here kitty kitty...
08 C14
SOLD - 05 Victory Ness Vegas, 06 KLR650, 04 VT1100 Spirit, 01 VT750 ACE, 1986 VFR750F, 1991 CBR1000F
AMA# 2794531
Offline Finesse
  • With a one way ticket to the land of truth
« Reply #19 on: August 08, 2012, 02:28:12 am »
Hi Guys,
Thanks,
Extant
Answer is yes, the dealer was blowing hot air. Before and after I bought my 08, I asked multiple dealers employees about the heat. They go into theatrics about how all bikes this large are hot, how much hotter this and that model are, if you believe them you will expect to need a warm coat when you ride your new connie. That's their job, to blow enough warm smoke up your rear so that money falls out of your wallet. That is pretty much their purpose in life, to 'overcome objections' you have to giving them your money.
2008 C-14 ABS
Offline Extant
  • COG#: 10278
« Reply #20 on: August 12, 2012, 11:52:56 am »
Thanks, guys, for all the replies.  Trusting my instincts,  I decided to solve the problem.   I traded in my  beautiful steel gray '08 yesterday for a brand new, black 2012.  Honestly,  I don't know how anyone could claim the unwanted heat output is nearly the same and "don't waste your money". Put simply,  there's no comparison.  While I have yet to use my laser thermometer to measure the surface fairing temperature,  I would subjectively estimate the unwanted heat output of the 2012 to be no more than 40% of what I found all but unbearable on the '08.
So far, the 2012 feels like a great overall improvement.  I love the braking and will hopefully appreciate the increase in gas mileage afforded by ECO
mode. The bike just feels more nimble.  Too bad, though, that Kawi retired the 08-09 gray color.  I've had my share  of black vehicles, and it's probably the last color to choose in terms of summer heat and big engine power.  But heck,  I'm looking at the road.  The odometer's only got 120 miles on it, but I think this one's a keeper and has put that grin back on my face.
Offline Extant
  • COG#: 10278
« Reply #21 on: August 13, 2012, 06:04:40 pm »
I couldn't agree more.   I gave up on various issues with the '08 on Saturday,  trading it in for a new black 2012!  I'm ecstatic and grinning ear to ear.
The differences are enormous.
