Author Topic: 2009 C14 TPMS sensor battery low warning  (Read 588 times)
Offline Tony
  • COG#: 12616
« on: June 07, 2019, 02:18:39 am »
Is there any way to disable the warning message short of actually replacing the batteries?  That's a ton of work, but I'm tired of the warning.
Offline Freddy
Re: 2009 C14 TPMS sensor battery low warning
« Reply #1 on: June 07, 2019, 03:13:44 am »
If you call removing both sensors and disconnecting the bike's battery while doing so a ton of work, then - no.
Or you can wait until both batteries no longer cause the display info to appear then disconnect the bike's battery for some minutes, reconnect, and the TPMS system will become dormant (no longer appear on display) until new batteries are fitted to the sensors.
As stated in the other thread, pressing the buttons in the correct sequence will remove the warning.
The smart thing to do is replace the batteries.
« Last Edit: June 07, 2019, 03:20:24 am by Freddy »
Offline Egodriver71
  • I'm in here somewhere
  • COG#: 8321
« Reply #2 on: June 07, 2019, 10:07:21 am »
Or, press the top then then bottom button on your dash and release.
Thomas Mann
Jacksonville, FL
COG #8321
Offline Road Runner
  • Beep! Beep! ... YeeHa!
  • COG#: 12399
« Reply #3 on: June 08, 2019, 12:50:25 am »
Sheesh, I've tried this numerous times while stopped, bike in neutral, etc., I still see the warning msg on my dash. Quirky. Oh well ..., minor annoyance.
David L. Hamil
Offline Freddy
« Reply #4 on: June 08, 2019, 12:54:38 am »
It's press & hold top button in then press & release bottom button then top button IIRC.
Offline Road Runner
  • COG#: 12399
« Reply #5 on: June 08, 2019, 02:59:07 am »
Yes, sounds simple (thanks), but a no go on my '13. A-ok, minor ...
David L. Hamil
Offline Syxxphive
  • COG#: 12672
« Reply #6 on: June 08, 2019, 12:42:14 pm »
Not to be a douche, but if it’s not working, you’re doing something wrong. Every dash for each generation of C14 is programmed identically to each other. All the 08-09 are the same, all the ‘10+ are the same. It doesn’t just not work.
Offline lather
  • COG#: 10690
« Reply #7 on: June 09, 2019, 05:18:34 pm »
It seems to me there is a bit of a timing trick to it. It took me a few dozen tries to get where I can do it first try almost every time now.
« Reply #8 on: June 09, 2019, 08:33:18 pm »
those button contacts, over time, oxidize a bit, and unless "exercised" yearly, by flipping thru functions, they don't always "respond" to first attempts when expected to... pressing them repeatedly, and rubbing them when depressed, seems to 'clean them" and make them work again...
Offline Freddy
« Reply #9 on: June 09, 2019, 11:31:05 pm »
Yes - that would explain it.   :beerchug:
Offline Road Runner
  • COG#: 12399
« Reply #10 on: June 11, 2019, 06:01:41 pm »
Thanks MOB for the tip; hopefully that will do the trick for me ...
David L. Hamil
