Author Topic: 2010 C14 CanBus  (Read 1171 times)
Offline Robby1953
  • 2003 Vulcan 800, 2006 Mean Streak 1600, 2010 C14
  • COG#: 11452
2010 C14 CanBus
« on: May 06, 2015, 11:25:02 pm »
I did a quick search of the area and didn't find my answer anywhere, My question is: can anyone tell me if the 2010 Connie is a single wire tail/light canbus or a 3 wire tail/brake light system. I've got an 'Addmorelights' tail, brake, turn light to add and the wiring is different dependant on the system. I know I could probably tear it down for the install and find out, but I wanted to get a jump on this and know before I begin.
Thanks for any help offered.
'A clear conscience is often the first indication of a failing memory." Unknown
Online jwh20
Re: 2010 C14 CanBus
« Reply #1 on: May 06, 2015, 11:28:54 pm »
The C14 does have a CANBus, but I don't believe the tail light is a part of that system.  It's possible I'm wrong on this as I've not looked at the wiring diagram but if I get a chance I will.
The CANBus does connect the instrument cluster, the KiPass ECU, the FI ECU, and the steering lock/key switch unit.  The CANBus can be accessed under the seat on the diagnostic connector.
2012 Concours 14 Arabian Red
Offline Robby1953
  • COG#: 11452
Re: 2010 C14 CanBus
« Reply #2 on: May 06, 2015, 11:48:26 pm »
 :-[ :-[ :-[ I've got a copy of the wiring diagram on my computer,,,,,DUHOH, didn't think to check it.... :sign0104:
Offline mattchewn
  • COG#: 10993
Re: 2010 C14 CanBus
« Reply #3 on: May 07, 2015, 12:44:29 am »
The tail light is a 3 wire.
Offline Robby1953
  • COG#: 11452
Re: 2010 C14 CanBus
« Reply #4 on: May 07, 2015, 12:46:55 am »
thanks Matt!!   :beerchug:
Offline Rob9876
Re: 2010 C14 CanBus
« Reply #5 on: August 10, 2017, 08:09:38 pm »
I know this is an old thread, but I had a question about CAN bus (for wiring lights to my topcase) and searched the forums and found this.  Noob question: Does that fact that the tail light is 3 wire mean that it is not on the CAN bus.  I have the same question about the turn signals.  BTW, my Concours is the 2015 model if that makes a difference.
Offline BDF
Re: 2010 C14 CanBus
« Reply #6 on: August 11, 2017, 12:42:19 am »
Lighting on the C-14 is conventional and does not use CANbus. In fact, CANbus is only used by internal systems and nothing accessible to the end user such as lights, horn, any switches or any other input or output.
Brian
Offline Rob9876
Re: 2010 C14 CanBus
« Reply #7 on: August 11, 2017, 02:55:36 am »
Brian
Great, thanks Brian!
