Author Topic: 5 bars in a tailwind  (Read 435 times)
Offline Mark D
« on: August 01, 2018, 09:40:41 am »
I've had my 09 C14 for 5 trouble free years. Maintain the crap out of it and then some. For the first time ever my temp went to 5 bars on an 85 degree day in traffic with a slight tailwind. An odd ball situation where the airflow with fans running is compromised? My former 1800 Wing had the dreaded parade mode overheat on occasion. A flaw for sure. But on the C14 I wasn't anticipating something like this happening. Been fine ever since. Fans spool up at 4 bars. Was just a little worried and almost shut her down! Do I worry about the 5 bar issue. Had no overheat warning come up on display that day or ever.
Offline Syxxphive
  • COG#: 12672
Re: 5 bars in a tailwind
« Reply #1 on: August 01, 2018, 01:31:15 pm »
When is the last time you flushed the coolant? If you’re in a hot climate a 50/50 mix of coolant and water might be too much coolant. Switch out to either straight engine ice or look up the coolant cocktail from Steve In Sunny Florida.
Offline Colt45
  • COGnito Ergo Zoom
  • COG#: 7914
« Reply #2 on: August 01, 2018, 04:20:41 pm »
That is a unique situation.  Since the red warning light did not come on, I would not worry.  If it did not puke coolant, I would not worry.  A good gauge will warn you well before damage so you can react before damage.
'00 748/853 "Rosetta"
« Reply #3 on: August 01, 2018, 07:28:08 pm »
I recently also experienced a tail wind and ran pretty hard to get enough air through the radiator. When I was headed into the wind the bike ran 2 bars. When U headed back home I had a strong tail wind. I made to  4 bars briefly and picked up my forward speed and temp went to 3 bars for the rest of the ride until I got to town. The fans were signing as I pulled into my drive way. The day was warm enough I was sweating in my neo tech and humidity is pretty low here in the high dessert.
