Author Topic: 90 degree tire valve stems 2008  (Read 1015 times)
Offline Fix ur Critter
« on: September 22, 2018, 01:56:33 am »
Hello
I know this has been covered a bunch, but all the threads I read through were very old. I found out today that Murph no longer carries the 90 degree stems.
Anyone have good option for 90 degree stem to fit 2008-2012 TPS? Dealer offered me units that I know dont fit in the TPS.
Be Kind, especially to the innocent
Spay/Neuter always
Show interest to a kid, they will remember it for life
Offline G-Mazz
  • COG#: 9048
Re: 90 degree tire valve stems 2008
« Reply #1 on: September 22, 2018, 02:59:35 am »
https://www.revzilla.com/motorcycle/oxford-valve-access-tool
https://www.amazon.com/Degree-Extension-Adapter-Motorcycle-Scooter/dp/B075ZLRHC6
If I recall correctly, Goldwing 90 degree valve stems are compatible with our TPMS sensors.  But that is just a recollection from a long ago, previous thread.
Good luck.  If you find a valve stem that attaches directly like the ones Murph use to sell make sure to let us know.
Offline Freddy
« Reply #2 on: September 22, 2018, 04:27:59 am »
Honda p/n: 42755-MCA-R31
Offline NYbiomed
  • COG#: 11887
« Reply #3 on: September 22, 2018, 07:05:56 am »
^^^Yep, what Freddy wrote is correct, these are not extensions, they require removing and replacing the old tire stem with these 90deg ones. They are a huge help and are worthwhile, of course easiest to install during tire changes when you already have the tire off. You can use a large c-clamp to break the bead and expose the area of the TPMS sensor to swap out if your intrepid enough and don’t want to wait.
2002 Honda VTR1000F SuperHawk
2009 Kawasaki Concours 14 ABS
Offline Staylo
  • COG#: 12548
« Reply #4 on: September 22, 2018, 11:44:07 am »
But these will only work if the TPMS was never replaced with the new style, correct?
Lancaster County, PA
'11 C14
Offline Freddy
« Reply #5 on: September 22, 2018, 11:57:36 am »
Correct.
« Reply #6 on: September 22, 2018, 01:07:08 pm »
Thanks All.. I just ordered the honda part. will advise after install if they work. may be a while, tire change not needed just yet..
Spay/Neuter always
Offline AwesomeDad
« Reply #7 on: September 22, 2018, 07:53:05 pm »
If your looking for an easier way to put air in your tire try this.
Accu-gage - Chek A Spare, Valve Extender https://www.amazon.com/dp/B0006O2S8M/ref=cm_sw_r_cp_tai_gTQPBb85BN39P
JJ
Offline Jacquelyn
« Reply #9 on: September 23, 2018, 07:35:00 pm »
What about the newer style TPMS on my 2017? The Honda part is no bueno?
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #10 on: September 24, 2018, 01:26:55 am »
JJ
+1, excellent solution.
Offline strum
  • COG#: 12307
« Reply #11 on: September 24, 2018, 02:05:29 pm »
JJ
 Correct me if im wrong but if you screw that thing on and check your pressure then unscrew to ride youve not only lost the air inside the tube but also whatever you lost getting it unscrewed. I just dont see how thats helpfull at all.
2008 C-14
Offline oldnslo_MO
  • COG#: 9924
« Reply #12 on: September 24, 2018, 03:14:52 pm »
correct.. :'(
Offline mike
« Reply #13 on: October 01, 2018, 06:25:02 pm »
I tried the 90deg valve stem extensions and the flexible extension.  All leaked and let out more air than I could put in.  Broke down and bought this instead.  Adding air has never been easier!  https://www.amazon.com/gp/product/B0719925K5/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
« Reply #14 on: October 02, 2018, 12:27:14 am »
I carry a small, really small, C-H pump (no longer available) that has the same tire chuck.. works fine, but I have a compressor, and my hose has a 90* tip on it.. no problem...
I'll just say, that portable is running at the limits of the fuse that protects the plugin socket... at 120w/10Amp draw... so you may pop a fuse, make sure you have spares...
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
« Reply #15 on: October 02, 2018, 08:35:25 am »
ProTool Pro-Tool Brass Lock-On Tire Chuck
Works beautifully every time!
Offline NYbiomed
  • COG#: 11887
« Reply #16 on: October 02, 2018, 09:59:50 am »
It’s been said before, this:
https://www.amazon.com/Motion-Pro-Fill-Chuck-08-0602/dp/B01CGKI3OG/ref=sr_1_3?ie=UTF8&qid=1538477827&sr=8-3&keywords=motion+pro+air+chuck
Excellent investment and just works. The variable angle head can be very stiff to manipulate for some, hasn’t been much of a problem for me.
« Reply #17 on: October 02, 2018, 11:09:29 am »
30 bucks for an air chuck...Madness!
At Harbor Freight angled air chuck is like 3 bucks... :beerchug:
Offline Staylo
  • COG#: 12548
« Reply #18 on: October 02, 2018, 11:22:23 am »
I bought the Motion Pro air chuck, and added one of these, and now I carry it around in my top case. Gas stations always have those horrible long 45* air chucks that won’t fit on the valve stems. Now I just put the Motion Pro on the valve stem, and I can use the gas station air chuck. It’s been indispensable for filling up on The road.
https://smile.amazon.com/gp/aw/d/B001PLI4BA?psc=1&ref=yo_pop_mb_pd_title
'11 C14
Offline IBAJIM
  • COG#: 12891
« Reply #19 on: October 02, 2018, 11:23:53 am »
But it says "Motion Pro" on it.  Expect to pay x10 for anything that has to do with a motorcycle, boat, or medical.
IBA # 35372  BBG (5-2014)
Great Lakes 100  (2011)
BB1500's x3
Other SS1K's x8  (2009-2017)
Offline NYbiomed
  • COG#: 11887
« Reply #20 on: October 02, 2018, 11:43:22 am »
Yes, $30 bones for the right tool for the job. I have no problem spending money on anything that gets the job done right the first time, quicker and likely lasts forever...now if it breaks after a year or two (I've already had it about that long), I will have been proven in error.  I will only add that I am a technician by trade and my tool budget is pretty much limitless, as its how I make a living.
« Reply #21 on: October 02, 2018, 08:31:11 pm »
I have that clip on version also, and use it for seating the bead on new tire installs, with the stem valve removed, and the inner actuator plunger removed from the filler fitting...when used in combination with a ball valve shutoff, with short hoses and Q/D couplers on both ends, it really works well to "blast inflate" the tire to seat a bead...
also for general use, I use the same 'type' inflator end, without the clip on feature, and as I never have to add more than a couple psi on a top up... it's a pop-on-pop-off done thing...
both fittings together were less than $10
Offline AwesomeDad
« Reply #22 on: October 02, 2018, 09:26:57 pm »
Haven’t had to try it on my Connie, however it’s a PITA to use on my ultra...
JJ
