Author Topic: Proposal for a new and improved way of de linking the rear to front brake link  (Read 1572 times)
Offline Freddy
Hey Fred, do you have an update on how you went with this?   :beerchug:
Offline Illo
I now have all the parts, including the correct plug, to de-link the rear to front brake.  I need somebody in SW Ontario who can do the installation and bleed the air properly.  I have a bad back and don't have proper tools to do any work on the bike myself.  Of course I will happily pay for the work.  I live in Festival City, Ontario.
2012 Concours
Offline Freddy
Offline The Pope
  • North Carolina AAD
  • COG#: 9994
What are the Part Numbers and other details about these two items and where can someone get these?
The Pope
Offline Illo
I found these at a local auto parts store.  I also found them on-line at other major industrial distributors.  Pl's see the picture and the links below:
https://www.motioncanada.ca/productDetail.jsp?sku=00304943
https://www.motioncanada.ca/productDetail.jsp?sku=00333499
https://www.napaonline.com/en/p/WH_1443
https://www.applied.com/c-brands/c-eaton-corp/c-weatherhead/1443/Hydraulic-Brake-Fitting/p/101746589
« Last Edit: May 31, 2019, 02:47:52 pm by Illo »
2012 Concours
Offline The Pope
  • COG#: 9994
Thanks!!!!!
The Pope
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
Ive been so busy as of lately i have missed post.
I have been researching this for a year now,,,, i hate the linked brakes and will be doing my bike this weekend finally!
I will add to this post as well as start my own.
Look for up dates,,, i may make extra parts to help others.
Off to the shop to make some $$$$ to pay for Bike parts!  :motonoises: :) :motonoises: ;)
Offline Illo
I'm happy to report that my delinking mod was done today.  I bought the parts and had Platinum Powersports in Blue Water (Clinton), Ontario, Canada.  I'm very, very happy I did it.
2012 Concours
Offline Staylo
  • COG#: 12548
I don’t see why there would be any issues, but update us after you’ve put some miles on and let us know how it’s working.
Lancaster County, PA
'11 C14
Offline Tundra
  • 2012 Candy Arabian Red
  • "SPORT" tourer
  • COG#: 12916
Please keep us updated....I absolutely hate my linked brakes although love the motorcycle. I would consider this if there no ill side effects. Congratulations on your determination to fix it.
Offline Freddy
Offline Illo
The only side effect is that the rear brake becomes a little weaker.  Major benefit is that I can now gently and confidently touch the read brake pedal while in the middle of a turn.  Prior to delinking, if I used the rear pedal in a turn, the rear disk would want to help leaning more and the front disk wanted to straighten the bike.  That was a conflict.  Now the rear brake can be used in a turn without fear and it would help to lean the bike more to get out of danger if going too fast in a turn.
2012 Concours
Offline cuda
  • Ignorance Is Bliss.
  • COG#: 11405
WHY would anyone want to touch the rear brake in the middle of a turn, I guess that's why I have NO PROBLEM with these brakes, I only use the front unless coming to the end of a stop, fantastic brakes.
Now back to screwing your bike up.
Offline Freddy
Ignorance is bliss.   :motonoises:
You might not have a good understanding of trail braking.  HTH :)
https://www.youtube.com/watch?v=hl2hRMpWEz8
https://www.youtube.com/watch?v=G1rlQ0NmbWs
Offline Egodriver71
  • I'm in here somewhere
  • COG#: 8321
Um, trail braking...
Thomas Mann
Jacksonville, FL
COG #8321
Offline Gixerhp
  • The Lighting Guy!
  • COG#: 12189
It's the standard line on '08-'09 bikes..., you bleed the furthest point (left caliper) first... pushing the air to and out of it.... then bleed the right one...
Or, with the left caliper disconnected from the mounts, and a wood block in place between the pads, and the caliper raised higher than the right side caliper mounted on the bike, pick which you want to bleed first... and do them both... bubbles rise...hydraulic pressure pushes them...to the bleeder.
That's an excellent trick, to raise the calipers.  That should definitely do it.  Now can you please tell me if having a vacuum pump is necessary for getting the air out?  I've never seen it done.  But in the earlier Randy N posts, he always referred to a vacuum pump and a hose that sucked oil from a can of oil.  I didn't quite understand what he was doing.
if you are well versed in bleeding brakes, (i.e., done them a zillion times, and have the routine down pat), you don't need a vac to accomplish it... just time, fluid, and care.
that said, everyone likes the "shortcut", as many do not know the difference between "gently breaking the bleeder open" and "opening it up", so it become an exercise to "pressurize/crack/close/repeat" bleeders correctly...
Randy N was having "issues" after disconnecting, and plugging a line, that had air in it, and thus why he was getting "error code" readings... like I kinda mentioned about how this system is a bit "more than a block"... the electronics sensed, and attempted to actuate pumping to accommodate the differential pressure being sensed in the internal valving... on the ABS unit.  All this "stuff" actively feed back into the ECU's, and when it does... well... you get what you get.
I'll also caution you on "following Randy N" without using discretion, he had "an agenda" he wanted to accomplish, and his "experiment", was not perfect...
If you go to his profile, and read ALL of the posts he made, and specifically those about this brake mod thing.. you will find it was not the "perfect" solution, as he preferred to be able to "lock up" his rear brakes when so desired... thus, his mods de-link the front to back "true ABS", and result in ABS on front ONLY...
I've had the rear's kick in on my '08, and it WAS beneficial, I've also had the fronts kick in, again, fine, and I've had BOTH kick in, mind you I do not have linked brakes, just ABS, and I find that any loss of any separate function, is a loss that could have severe outcome when called upon...
I also have a C10, normal brakes, and a '78 Kz1000, again, old style brakes... all are different, but I know what each one will do, when I call upon them in a panic stop.
Well hello there im am now in the process of doing this a bit different than Randy as well. I am using a Galfer Braided line kit as well as making a a few hard lines. As far as i can tell now, in theory, and ill know by this weekend, the rear ABS will still work, the Rear line to the front on the ABS pump will be blocked off. The 2 front line will be linked to together wit a T fitting. I have been reading Randys post for months now, as well as doing vast research on this. and i think i have it figured out. Vast pics will be coming this week, as well as details
Offline Ranger Jim
  • COG#: 6720
When "trail braking" you are on your brake from the entry of the turn until somewhere near (or past) the apex. It's called "trail braking" because you are slowly releasing the brake pressure, i.e. "trailing off" the brakes.
JIM CULP
Offline Freddy
You're probably right but there are many who have complained long and hard about the over-active link to the front.  That's why Kaw 'recalibrated' the link about 4 years ago - no complaints from owners of the newer bikes.  Doing the de-link makes the brakes behave like the earlier non-linked model thereby enabling riders to use the rear brake in a bend and not put the bike off line.  Sure, we may be second-rate riders, but it works vey much better for us.    :)
« Last Edit: August 15, 2019, 11:24:45 am by Freddy »
Offline Sailor Rich
  • COG#: 9318
By times there are a few times when I have trailed off the front brakes in a turn that a decreasing radius sneaks up on me. Lean angle, speed, surface conditions are allready asking that front tire to do lots. It is nice to be able to drag the rear brake just a bit not asking the front to do more. Easy to do on the 09 but the 18 is not as smooth a transition, too little or too much.
When I reach this point it's time to dial it back and reassess my riding.
