Author Topic: ABS Brake Fluid Change & Bleed  (Read 1299 times)
Offline David_Clancy_ON
  • COG#: 5452
« on: February 25, 2009, 12:40:00 pm »
Is there anything special compared to the C10 that you need to do to change brake fluid in ABS and linked systems? If you just put a vacuum on the bleeder at the caliper and add fluid at the resevoir will it change the fluid and not damage anything?    Dave  A ship in the harbor is safe, but that is not what it was built for.
Dave Clancy #5452  Hamilton ON    A ship in the harbor is safe, but that is not what it was built for.
Offline norm-9688
  • COG#: 7011
« Reply #1 on: February 25, 2009, 10:00:00 pm »
Dave, I would think bleeding the system would be the same unless it has a separate tank for the ABS unit but it's unlikely. Bleed and flush with a vac bleeder should be fine but I would check the service manual before you dive in.   CT AAD  COG #7011-A  2003 Concours-Mary Ann  1995 Honda Nighthawk 750 wifes
Offline bob14
  • COG#: 8211
« Reply #2 on: March 04, 2009, 08:17:00 pm »
Dave  Fred H's video has a good section on the bleed and other C14 tasks.But   you described it about right
Bob Mason  Albuquerque New Mexico  08 Concours 14  05 Triumph Tiger  84 GPZ1100  74  750 Kawa MachIV  71  500 Kawa MachIII
Some people try to turn back their odometers. Not me, I want people to know "why" I look this way. I've traveled a long way and some of the roads weren't paved.
