Author Topic: Axle won't go into fork  (Read 730 times)
Offline Doc
  • COG#: 12697
« on: February 24, 2018, 02:23:26 pm »
Help!  I got my forks back from Traxxion and I can't get the axle into the lower forks.  I've loosened the pinch bolts as far as they can go.  Any suggestions?   :-[
Offline ZXtasy
  • COG#: 12569
Re: Axle won't go into fork
« Reply #1 on: February 24, 2018, 03:00:09 pm »
Go in from the other side?
Offline Deepsea
« Reply #2 on: February 24, 2018, 03:05:11 pm »
Twist the lower legs out of alignment then try inserting it into just one side. Then try the other side. Does the nut fit? Does the nut fit in both sides?  Are you sure they sent back the same forks?
Retired Navy Saturation Diver
Offline Doc
  • COG#: 12697
« Reply #3 on: February 24, 2018, 03:17:34 pm »
they are my forks but neither the axle nor the nut will go in
Offline gpd323
« Reply #4 on: February 24, 2018, 03:55:43 pm »
Try prying them apart from below with a large flat screwdriver or a small crow bar. You could use 2 screwdrivers coming in from the bottom and prying that way. Pry one driver up and the other down at the same time in the slots.
I bet they cinched down the pinch bolts during the process and squeezed them together when they are supposed to be spread out. Sounds drastic, but worth a shot?
Offline gpd323
« Reply #5 on: February 24, 2018, 04:41:28 pm »
I guess removing the pinch bolts prior to sending them out would be a good idea, I bet they tightened them down because they were afraid they might get lost somehow? Seems odd though because thats what they do, suspensions and should have known better. thats is if that was the case and not you who tightened them down before shipping?
Offline AmphibSailor
  • Hooligan
  • COG#: 12210
« Reply #6 on: February 24, 2018, 04:48:20 pm »
Doc,
Lots of good ideas covered, here in a previous thread..
Offline Deepsea
« Reply #7 on: February 24, 2018, 07:05:29 pm »
Sounds like the only option you have is to spread the axle opening. Be gentle but firm. I've done this lots of times but never on a C14. Remove the bolts and gently tap a flat head screwdriver in from the bottom. It shouldn't take much but will feel like you're going to break something. Be gentle and it should be fine. If you have a short wide screwdriver that would be best. Start with the nut (L/H) side and leave it in then go for the axle side. When you get the axle to fit leave the screwdriver in until the wheel is installed and the axle is all the way in. Snug tighten the axle into the nut then pull the screwdriver and torque the nut. Don't forget to apply a thin coat of axle grease on the nut and axle. Bounce the bike up and down a few times before evenly and in steps tightening and torquing the pinch bolts.
Offline gpd323
« Reply #8 on: February 24, 2018, 07:29:09 pm »
I like your idea for sure. That will widen the gap.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #9 on: February 24, 2018, 08:10:36 pm »
Yeah from the photos, theres not nearly enough of a gap at the bottom.
Soft metal.  Be careful.
Offline Doc
  • COG#: 12697
« Reply #10 on: February 24, 2018, 08:23:41 pm »
Success!  A few bad words and patience got it to go.  Thanks so much to everyone for the quick replies!
Offline Deepsea
« Reply #11 on: February 24, 2018, 08:37:22 pm »
Glad it worked out. Ride hard, ride safe.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #12 on: February 24, 2018, 11:26:50 pm »
 :beerchug: :beerchug: :beerchug:
