Author Topic: Battery in 2014 C-14  (Read 2841 times)
Re: Battery in 2014 C-14
« Reply #25 on: December 19, 2017, 03:48:46 pm »
Earlier in this discussion, TicTac sed he planned to install a GYZ16H in his bike.
The C-14 (according to the manual) uses a FTZ-14-BS.
From there we've started to discuss specific batteries and CCA's, but no one talked about this....
Will a 16 series battery fit in the C-14?
Gone but not forgotten; 00 and 86 Connie's
To contribute to "OtP", DO IT NOW!!
It's EZ: Go to the top of the Forum and follow the steps.
Offline TicTac
  • COG#: 11256
« Reply #26 on: December 20, 2017, 04:10:19 am »
Yes Ted. It will be a perfect fit. :great:
Two more Amps and a little more C.C.A. (240)
From YUASA web site.
http://www.yuasabatteries.com/battery_search.php?action=showListing#formanchor
Battery Search
GYZ16H
Search Result
 Kawasaki -  ZG1400 Concours, ABS   2008 - 2017   1400cc
Battery Family: GYZ High Performance, Maintenance Free
Battery Type: GYZ16H
Voltage: 12
Capacity: 16
Dimensions: 6" x 3.4375" x 5.75"
Weight: 12.4 lbs.
Metric Dimensions: 150mm x 87mm x 145mm
Metric Weight: 5.6 kg
Polarity:
Acid Volume: N/A
Amps: 1.6
C.C.A.: 240
« Last Edit: December 20, 2017, 04:16:41 am by TicTac »
Online ghostrider990
  • COG#: 12649
« Reply #27 on: December 20, 2017, 10:40:28 am »
Boom!
I love it.  :great:
TicTac: assume you have this in your bike, and working - all fittings attached and such??
« Reply #28 on: December 20, 2017, 02:33:51 pm »
Battery Search
GYZ16H
Search Result
Voltage: 12
Capacity: 16
Weight: 12.4 lbs.
Polarity:
Acid Volume: N/A
Amps: 1.6
C.C.A.: 240
Thank you TicTac!
       For comparison; Dimensions for the 14 series is the same...
     From Yuasa Barrery site: Dimensions: 6" x 3.4375" x 5.75"
