Newer models have two, SWITCHED 12v accessory leads, installed in the wiring harness
1 is in left fairing under the black panel and uses bullet connectors
It's very easy to run a lead from the left to the right-side fairing without removing a lot of plastic
1 is under the seat, right side behind the ECU and uses bullet connectors
These two leads are, 5amp fused (up to 10amp max), very handy if one is looking for additional accessory hook-ups
