Author Topic: Engine not starting  (Read 862 times)
Offline arieux
Engine not starting
« on: January 12, 2018, 08:58:50 pm »
I tried to start my c14 2012 this morning and it would not and sounded like it was out of gas but the tank is almost full.
This afternoon, i tried again:  the engine does not even try to start this time and i hear knocking in the head.
I am not getting any error message.
The engine was working fine after i changed the oil in December and i have not used it since because it is winter with a lot of snow and very cold.
If someone has an idea  i would appreciate.
Regards.
« Last Edit: January 12, 2018, 10:21:29 pm by ron203, Reason: typo in title when moved -rs »
Offline gPink
  • MMVIII C XIV
Re: Engine not starting
« Reply #1 on: January 12, 2018, 09:14:30 pm »
Did you ever replace the battery and abrasively clean all the ground connections?
« Last Edit: January 12, 2018, 10:22:11 pm by ron203, Reason: typo in title when moved - rs »
Offline Diz
  • COG#: 12056
« Reply #2 on: January 13, 2018, 10:00:11 am »
A bit more info might be helpful. Is the starter running when you hit ignition button? You say it sounded as if it were out of gas; does this mean the engine was turning over, but no sounds of ignition?
Offline seagiant1
  • COG#: 11323
« Reply #3 on: January 13, 2018, 11:25:00 am »
Hi,
      Check the "KILL" switch!
Don't ask me how I know this!
Kids love to play with things! ;D
Offline gpd323
« Reply #4 on: January 13, 2018, 12:46:03 pm »
I call dead battery lacking any additional info.
Offline jwh20
« Reply #5 on: January 13, 2018, 05:41:33 pm »
The most common problem with the C14 not starting is with the electrical system, specifically the battery (-) to frame connection and the battery itself.  Start, as already noted, with the frame connection.  This is the #1 trouble spot.  You get corrosion built up and it prevents a good electrical connection.  The corrosion is Aluminum Oxide which looks exactly like Aluminum so you cannot see it but it is a good INSULATOR.  Remove the connection, clean the frame connection point with abrasive, put a tiny bit of dielectric grease (or just plain axle grease if that's all you have), and re-install the connection.  If that doesn't solve the problem, then pull the battery and take it to a shop and have it load tested.  A voltmeter check WILL NOT suffice here.  Many bad batteries show good voltage but will not produce enough power to start the bike.  Only a load test will show.
If both of these look good, then it's more complicated.  Report back and I'm sure there will be more advice...
2012 Concours 14 Arabian Red
Online TimR
« Reply #6 on: January 13, 2018, 07:06:40 pm »
When you tried to start, did the motor turn over sluggishly or with vigor?
During the non riding season, I put a Battery tender on about every week and a half to keep the battery healthy. I also put a tender on the 900 to top off it's battery. When the tender goes to the float mode I pull it off and move on. During the riding weather I don't worry about it because the bikes get ridden often enough to keep the batteries up.
I have the ability to heat the garage but only heat it when necessary so the bikes have been sitting in a very cold garage. It cost a lot to just heat the house.
I lost the battery on the 09 in 2010 because I went too long without giving it a charge during the winter. Kawasaki replaced the battery under warranty.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #7 on: January 13, 2018, 08:21:30 pm »
Theres not enough info known to make a suggestion...
Offline walter
« Reply #8 on: January 13, 2018, 08:24:35 pm »
Hi,
 :iagree:
