Author Topic: Bleeding Brakes on an ABS model  (Read 1257 times)
Offline nando
  • Transport C-14
  • COG#: 10454
« on: October 13, 2013, 03:44:36 pm »
Does one has to use the Kawi computer to bleed the brakes on an ABS?
Is there a particular order in which you have to bleed the valves?
Offline mattchewn
  • COG#: 10993
Re: Bleeding Brakes on an ABS model
« Reply #1 on: October 13, 2013, 04:27:29 pm »
Nando,
No on the KDS part. Make sure to protect all your plastic and paint. Start with the calipers and don't allow the reservoirs to become empty. As long as you do not let air in you will have no trouble flushing out the old fluid. While you will not get 100% of the old fluid out,( there will be a very small amount in the ABS accumulator that will be mixed with the fresh stuff next time the ABS pump runs), you will get more than enough to preserve your brake system parts. If you want to be incredibly anal you can flush the system, run the bike around a bit and then flush it again! If you already have air in the system then start at the master cylinder(s) and then work down from there.
Good luck,
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Online TimR
« Reply #2 on: October 13, 2013, 05:34:48 pm »
I agree with Matt. No problem bleeding brakes and clutch on my 09 ABS.
