Author Topic: Brake fluid on the plastic  (Read 1360 times)
Offline Bowyerv
« on: August 24, 2017, 02:07:01 am »
I know.  I know. DON'T SPILL THE BRAKE FLUID!  >:(
Can I fix this, or is she marked forever?' :-[
Offline Deepsea
  • COG#: 10376
Re: Brake fluid on the plastic
« Reply #1 on: August 24, 2017, 03:50:34 am »
Maybe???? Some buffing compound? Good luck, let us know how it goes.
Retired Navy Saturation Diver
Offline Bowyerv
« Reply #2 on: August 24, 2017, 03:52:52 am »
Was worried that a buffing compound might buff the relief of the plastic away as its not smooth
« Reply #3 on: August 24, 2017, 04:02:42 am »
Strong dishwashing liquid/hot water solution, scrub with an old ttothbrush,.rinse, repeat, towel dry...
Offline Kman
  • COG#: 10569
« Reply #4 on: August 24, 2017, 08:35:35 am »
A good quality plastic dressing/restorer will work wonders....
2012 Black, PR4GTs, Guhl Flash, CS1 Slip-on, Blaster X Brake Flasher, Cree 10W Lights, H4 Extreme Bulbs, Baldwin Heated Seat, Screaming Banshee Horn, MRA VarioTouring Screen, Throttlemeister, Crampbuster, ProjectD Radiator Guard, Front & Rear Fender Extenders, Techspec Snakeskin Saddlebag Protectors, Techmount GPS Bracket, OEM Tank Guard, 47L Top Bag, Helmet Locks, ProjectD Kickstand Bigfoot
Offline Bowyerv
« Reply #5 on: August 25, 2017, 12:28:53 am »
My wife reckons my teeth have never looked so bright ...
                                   (but it has reduced the mark by about 20% Thank you)
That has done the trick ... almost perfect. Thanks  :beerchug:
Offline Bruiser
  • Bruiser
  • COG#: 10410
« Reply #6 on: August 25, 2017, 05:50:11 pm »
What MOB said
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Jerdurr
« Reply #7 on: August 25, 2017, 06:04:14 pm »
Can you show us pics of the results? I had the same issue with a stupid drop coming out of the reservoir after I had closed it and removed the rags, basically leaving a streak in the plastic fairing from top to bottom >:(
Best,
JD
Offline Texas Concours14
  • COG#: 9760
« Reply #8 on: August 25, 2017, 07:24:19 pm »
I did the same thing in spite of having garbage bags and shop towels covering the paint and black plastic; got drips on the black plastic. I tried Mothers Back-to-Black Plastic and Trim Restorer, but it didn't do any good. I am curious - which restorer did the trick for you?
http://mycarneedsthis.com/todays-best-plastic-restorers-for-automotive-detailing/
2010 Concours 14
Offline Bowyerv
« Reply #9 on: August 31, 2017, 01:19:18 am »
Can you show us pics of the result? ...
...Plastic and Trim Restorer, but it didn't do any good. I am curious - which restorer did the trick for you?
Pics forthcoming. Bike is in the shop at the mo being repaired after a bingle with a wallaby.  :-[
When I get her back I'll take a pic. Product I used that worked best was Turtle Wax Trim restorer. I applied this generously several times over 24hrs. gave it plenty of time to soak in between applications. Can only just detect the mark ... but I have to look for it. Apparently over time it should fade out entirely
« Last Edit: August 31, 2017, 01:35:48 am by Bowyerv »
Offline Bowyerv
« Reply #10 on: September 06, 2017, 07:18:19 am »
Here's the result of that Turtle wax plastics product. I can still see the mark but it's now not obvious. Looks like light reflecting off something.
  • COG#: 9760
« Reply #11 on: September 06, 2017, 12:43:56 pm »
Thanks for the info and pic. That approach helped hide the brake fluid scarring of the plastic on my bike, but not completely.
2010 Concours 14
Offline Jerdurr
« Reply #12 on: September 06, 2017, 12:59:02 pm »
Man, those are amazing results! Thank you!
Best,
JD
Offline Jorge
  • COG#: 9297
« Reply #13 on: September 07, 2017, 10:44:53 pm »
Wow... quite a difference. Well done, and thanks for sharing.
Offline barberman
« Reply #14 on: September 21, 2017, 06:14:28 pm »
So,  How tough is it to get a lid for the box? Anyone tried? I actually used a small sharp tipped paint brush w/ gloss black and carefully dabbed at the discolored area and blended out well..
