Author Topic: Brake rotor opinions  (Read 4548 times)
Offline Hayabusa3
Re: Brake rotor opinions
« Reply #75 on: September 12, 2018, 12:03:23 am »
Ted it's a 2012. There's a magnetic run out gauge at work somewhere that I'll try and get my hands on tomorrow and attach it, but I wasn't sure how accurate a reading would be on semi floating disks...
Update: I took the bike to work this morning - 45 mile commute. At freeway speeds the pulsation is severe. Absolutely not rideable. I took it very easy for the commute in both directions and it's parked up. For the immediate future I'm going to take a sanding disk to the old rotors and gently clean them and reinstall them with the now new EBC pads.
Online connie_rider
« Reply #76 on: September 12, 2018, 12:18:38 am »
Ok, not sure what to say here.
Suggest doing the readings and let us know what you find out.
Think I would check runout on the rim while your doing them.
Hopefully others have some idea where to go next??
PS: You can buy a inexpensive travel dial and magnet at HF.
      Should be relatively simple to build a mount to attach it to your forks.
« Last Edit: September 12, 2018, 01:27:43 pm by connie_rider »
Offline Hayabusa3
« Reply #77 on: September 12, 2018, 12:46:06 am »
Will do.
Offline NYbiomed
  • COG#: 11887
« Reply #78 on: September 13, 2018, 09:57:54 pm »
If you running the Chinese rotors, did you shim the ABS sensor?  Many of us have had to do this, probably 2 washers- depending on the thickness. When I first installed the rotors, the brake pulsation was downright dangerous!
2002 Honda VTR1000F SuperHawk
2009 Kawasaki Concours 14 ABS
Offline Hayabusa3
« Reply #79 on: September 14, 2018, 01:59:08 am »
I had read on here that that might be an issue and my sensor was also going to rub, so it got a shim before riding. Good looking out.
Offline Hayabusa3
« Reply #80 on: September 16, 2018, 10:39:09 pm »
Update:
I wasn't able to get a runout gauge from work but I contacted the company from eBay and explained the situation and they easily agreed to send me out a new set of rotors which suggests that this isn' the first complaint about their rotors being warped form new....anyway, there's a storm in the asian pacific thats holding them up so I decided to take a buffing disk to my original rotors and put put them back on with the new EBC pads.
       And now there's no pulsation - surprise surprise I hear you say. Stops very smoothly. I just didn't want to b dealing with a routine disk sanding but because it was factory pads that were supposedly leaving deposits on the rotors that shouldn't be an issue with new pads.
 Long story short, I should have saved myself $150 and removed the rotors, give them a good blast with the sanding disk and replaced the factory pads. I figured I didn't want to be sanding regularly, and I wasn't convinced the pads were leaving deposits.
Anyway, I'm off to put some salt on my hat and eat it. Appreciate all the good info on here.
Online connie_rider
« Reply #81 on: September 17, 2018, 03:13:31 am »
Glad it worked out for you.
Takes a big man to admit he was in error.
Saaaalute!!
Offline Phil
« Reply #82 on: September 18, 2018, 04:06:12 pm »
Update:
No harm, no foul. Glad you got it all working well. Sorry to hear the new rotors didn't work out.
Offline Doc
  • COG#: 12697
« Reply #83 on: October 19, 2018, 07:49:20 pm »
+1 on the EBC's. I got mine from Murph as well. I was not impressed with the OEM's. I looked at the Brake Tech's but decided to save a few bucks with the EBC's. They've been rock solid.
EBC rotors rock - big improvement from stock
