Author Topic: breath better  (Read 1736 times)
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
Re: breath better
« Reply #25 on: April 30, 2018, 01:26:50 am »
Holy air filters, Batman!
Connie air filter IS puny.
Offline Lee Ving
Re: breath better
« Reply #26 on: May 02, 2018, 11:06:43 pm »
Good to see the woke on the K&N here. The amount of grit they pass IME is unbelievable.
Re: breath better
« Reply #27 on: May 03, 2018, 06:23:12 pm »
While I use the OEM filter, and have no real opinion on the K&N, other than the oil thing, I find it a bit twisted, and even misleading to have so much dissertation about "how bad" the K&N performs, when someone tosses out a bar graph gleaned by a snip from a website dedicated to Nisson Infiniti owners, showing data, which was gleaned from tests done on a Duramax Diesel engine, another totally different engine and system... so now, thru 3 permutations, this data is supposed to be a defiding factor here on a C14...………??????
Apples to apples comparisons work, or apples to bowling balls to double edged razorblade comparo's simply are worthless in my book..
Just keepin it real, peace y'alll... :great: :great:
If its on the internet, it must be true.
 :rotflmao: :rotflmao: :rotflmao: :motonoises:
Re: breath better
« Reply #28 on: May 03, 2018, 09:17:38 pm »
The E series Ford vans with diesel use dual air filters (panel type).
Every time intake runners were taken apart, the amount of accumulated dirt/oil mixture was impressive, required thorough cleaning.
Then a coworker decided to upgrade turbo charger in his F350. He'd been using K&N filters religiously.
Upon  disassembly, the amount of dirt accumulated inside intake runners (y-pipe) was, let's say the effective diameter of y-pipe was reduced. The discovery was hastily compared with panel filter equipped air intake and shown to the owner. The  contrast was more than obvious.
The difference in dirt/oil accumulation alone had changed his mind. Since switching to AEM with pre-filter sock, his K&N religion seized to exist.
P.S Different strokes for different folks in regards of automotive consumables.
However, like George Orville wrote in his novel, "Ignorance is strength," -misinformation is the major factor in making wrong choices.
If it is on the internet, it must be true.
Don't forget, it always works both ways.
« Last Edit: May 03, 2018, 09:26:20 pm by RoadKillHeaven »
Re: breath better
« Reply #29 on: May 03, 2018, 09:50:10 pm »
Offline Grant
  • HOTROD TRUCKS & BIKES
  • COG#: 12666
Re: breath better
« Reply #30 on: May 04, 2018, 01:18:35 am »
In most all the diesels out there today unless you delete the PCV or at least add good oil catch can to the system you will always find a large amount of  crap in the Y- bridge and intake piping.
Re: breath better
« Reply #31 on: May 04, 2018, 02:14:54 am »
Given, 7.3 is well known to have above average oil blow-by, the accumulations were not only found in Y-pip but in compressor inlet with inducer portion of compressor vanes looking like it had been sandblasted.
6.0L had different breather system, eliminating most of blow-by in second gen. First gen, with throttle servo, was even forse than 7.3
Besides, his words not mine, he mentioned oiling the filter at shorter intervals.
Offline Deepsea
Re: breath better
« Reply #32 on: May 04, 2018, 02:59:29 am »
More is better???
The K&N type filter is a viable option if the associated limitations are understood and it's "Properly" maintained. The two biggest problems are over oiling and over oiling. The oil migrates when still wet and especially when over applied. As I stated earlier the K&N filter is a quality product when used correctly. However, OEM filters have mostly reached the point where using aftermarket filters is no longer Necessary from a performance standpoint. From the mid 60's to the late 70's they were just about the only functional option. Oiling the filter at shorter intervals is a clear indication of why the intake tract was such a mess.
Retired Navy Saturation Diver
Offline Colt45
  • COGnito Ergo Zoom
  • COG#: 7914
Re: BREATHE better
« Reply #33 on: May 06, 2018, 06:23:06 pm »
I have been a fan of K&Ns for a long time.  But, since my '85 Thunderbird Turbo Coupe a K&N has made no detectable improvement in performance.  I've never had oiling or MAF issues from them either.
How hard is it for an engine engineer to upsize a paper filter to equal the flow or pressure drop of a K&N?  Do you really think he would leave power on the table that is that easy to get?  I have seen pics on the interwebs purporting to show wear/damage from use of a K&N, but none that were really verifiable.  So, I just use the OEM filters anymore.
If I had a truck or dozer that was supposed to make money for me, I would not consider a K&N for the maintenance downtime.  Nor would I pay for 2 so I could swap them and go back to work or risk the warranty on my $80k engine.  I believe that is the reason K&N no longer has a presence in the industrial/construction sector.
'00 748/853 "Rosetta"
