Author Topic: C14 Parts Directory, paint codes, fluids and filters.  (Read 794935 times)
« on: July 02, 2011, 01:31:35 pm »
I started this C14 parts directory. It will be an on going work in progress. If there is a part that you would like to include in this directory, or if you want to add or make changes, please PM an existing moderator with the particulars. But please give all the information as to what directory and what you're looking to do, since there are multiple directories. There is also a Farkle/Vendor thread in the C14 Accessories section as well!
Thanks,
Bob
These C14 part numbers are the OEM Kawasaki part numbers unless otherwise stated.
AIR FILTERS
Air Filter Element - 11013-0014
BMC Air Filter - 466/04
K&N Air Filter - KA-1406
Battery
Battery for KIPASS FOB - CR2025 3v
Battery box metal cover bolt - #92153E  BOLT,SOCKET,8X15    Mfg. Part Number: 92153-1810
Battery box plastic cover bolt -  #92151B    BOLT,SOCKET,6X14   Mfg. Part Number: 92151-1654
Grommet for plastic battery/frame cover: Damper, Rear Fender - 9205-101
Body Parts
Battery cover stud rubber grommet - Frame fittings, p/n 92075-1011 (damper)
Brakes
Front brake hose clamp (Fender)  92037
Front pad Assembly - 43082-0071 (2 EA) (08-09)
Front pad Assembly - 43082-0112 (2 EA) (2010)
Rear pad Assembly - 43082-0055 (1 EA)
Carbone Lorraine - Front brake pads -1177SBK5
Carbone Lorraine - Rear brake pads - 2813RX
EBC- Front brake pads - EBC FA417/4HH (Sintered)
EBC- Rear brake pads - EBC FA254 (Kevlar) or FA254HH (Sintered)
Ferodo (Note: these pads may wear faster than other brands, may not grip as well either!)
- Front pads - Ferodo FDB2220ST (mcstuff.com p/n 454-1071, need two sets)
- Rear pads - Ferodo FDB2111P (p/n 454-2682)
Galfer SS - Front ABS brake line - Galfer SS FK003D625-3
BULBS
City Lights - 2825 (5w) or  2886 (6w)
City Lights (LED, inverted cone, white) - 194 or 168
Headlight Bulb 12V-60/55W - 92069-1002 (standard H4)
(Small) Headlight Bulb 12V/5W - 92069-1016
Tail License Plate Bulb - 92069-1055, 5007, R5W (5 watt)
Front/ Rear Turn Signal Bulbs - 92069-1125
Turn Signal Bulbs - 7507A bulbs (BAU15s base)
Engine Parts
Exhaust Header Nuts (Replacements) - McMaster-Carr 93795A230 M8.0 Oval Lock nut.  Use with stainless steel washers. Note:  The 2010 Service Manual shows the required torque @ 13ft/lbs.
Oil filler cap - 16115-1009 (note:  Fits the rear drive as well)
Oil pan drain bolt - 92066-0079
Oil pan drain bolt with magnet - MP-01, MP-11 for the rear drive (magnet version http://www.magneticdrainplug.com
Pulsing Cover gasket - 92055-0086
Spark Plugs - CR9EIA replaced by CR9EIA-9, gap .036
Valve cover gasket - 11061-0263
Fairing Screws & nylon washers
Cover screws (black panel top of fairing and under windshield):  Socket Bolt, 5mmx16mm - 92154-0026
5.3mm ID X 11.5mm OD X .5mm thick - 92200-0006
10.4mm ID X 19mm OD X .5mm thick - 92200-0157
Windshield mounting screw nylon washers: 10.3mm ID X 17mm OD X 1.0mm thick - 92200-0380
Final Drive
Filler cap o-ring - 92055-049 (31mm)
Keys
Key Blank - ILCO KW14R  Note: Double check your keys and this information. There seems to be two types of keys, beginning with either an "A" or "B". If you have an "A" key it should be a "KW14R" key-blank.  If you have a "B"  key, it should be an "KW14" key-blank. This was true on the 2008. But I'm not sure how they may be on newer models (so double check).
 http://www.mysecuritypro.com/index.asp?PageAction=VIEWPROD&ProdID=663
Another key blank is an ilco X254. I used this on my 08. I do not remember if I had an A or B key.
Levers
Brake - ASV BRC511
Clutch - ASV BRC511
OIL FILTERS  We suggest that you always double check all filters before using them to insure they will work properly.
OEM Oil Filter - 16097-0004
A/C Delco - PF2135
A/C Delco - PF1237
Amsoil - EAO 103
Amsoil - 24942 (this one may be a Wix filter)
Baldwin - B1400
Fram 303 is the shortest for the C14/ZX14 (wonder if the hi-Flo 303 is the same height?)
Fram - PH6017A
Hastings - LF-113 short
Hastings - LF- 240F is the longer version
Hi-Flo Filtro HF 303
Hi-Flo Filtro HF 204  (about a 1/2" shorter than the HF 303)
K&N - KN-303
K&N (automotive) is a hp -1008
Mobil 1 - M1-108
Mobil 1 - M1-110
NAPA - 1356, flows 9-11 gpm, which is the equivalant to the Purolator PL14610 flows 7-9 gpm (but if you type in "PS" before any of the NAPA numbers, you come up with the powersports series.
NAPA - 1365/PS1365, same as the PL14610 except about .825" shorter
Napa Gold - 1358
Napa - PS1358 (black and costs less)
Purolator ML16817 (made for motorcycles)
Purolator Pure One - PL14610 extended length, flows 7-9/9-11 gpm - conflicting info on flo in the posts: (Note: Purolator recommends not using automotive filters on motorcycles)
Purolator Pure One - 2.5"- PL14612: - It is shorter than PL14610 (Note: Purolator recommends not using automotive filters on motorcycles)
Walmart Super Tech - ST7317
Wix - short: 51358; long:  51356
Wix -  51365
Paint
http://www.colorrite.com/matrix-colors.cfm?CFID=2087880&CFTOKEN=46483776
Note: may require both base and top coat!
2008
Neutron Silver (US), (factory OEM code 17N), Color Rite - (3895), Base (1895)
Metallic Diablo Black (Non US), (factory OEM code 17K), Color Rite 3606
Flat Super Black, (factory OEM code 18R), Color Rite (3370)
Metallic Phantom Silver for the trim and wheels (OEM 458), Color Rite (3803)
2009
Metallic Diablo Black , (factory OEM code 17K), Color Rite 3606
Candy Diamond Red, (factory OEM code 25T), Color Rite - (3785), Base (1785)
2010
Candy Neptune Blue (factory OEM code 27Z), Color Rite - (3402), Base (1102)
Flat Super Black (factory OEM code 18R), Color Rite (3370)
2011
Ebony Black  (factory OEM code 602), Color Rite (3005)
Atomic Silver (factory OEM code 17M), Color Rite (3915)
2012
Candy Arabian Red  (factory OEM code 33M), Color Rite (9912), Base (1912)
2013
Metallic Black Spark (factory OEM code 660/15Z ), Color Rite (3927)
Metallic Nocturne Blue (factory OEM code 684), Color Rite (3929)
Push Rivets
Push Rivet (Nylon) (2 different sizes) - 92039-0051 & 99039-0051
Windshield Push rivet - 92039-0048
Balkamp (NAPA) part number 665-1446 (rivet 92039-0051) (pkg of 9)
Hillman push-in Nylon Rivet (available @ Lowe's) - 1/4 inch H#881216 (Lowe's bar-code) 0823671607 (Windshield)
Upper cowling "push in rivet"  -  92039-0084   http://forum.cog-online.org/index.php/topic,44401.0.html
https://boltmotorcyclehardware.com/collections/nylon-rivets-for-atv-utv-sportbike-scooter/products/m6-push-rivet
Service & Owners Manuals
2008 C14 Service Manual - 99924-1379-01   http://www.kawasaki.com/DefaultFrame.aspx?strContentURL=/Site/VIVehicleInformation/VItechpubs.asp?intCatalogID%3d2%26CatalogTypeID%3d4%26ProductTypeID%3d8%26ModelMarketingId%3d453%26ModelYear%3d2008%26SHOWVEHTABS%3d1
2009 C14 Service Manual - 99924-1379-02   http://www.kawasaki.com/DefaultFrame.aspx?strContentURL=/Site/VIVehicleInformation/VItechpubs.asp?intCatalogID%3d2%26CatalogTypeID%3d4%26ProductTypeID%3d8%26ModelMarketingId%3d453%26ModelYear%3d2009%26SHOWVEHTABS%3d1
2010 C14 Service manual - 99924-1431-01   http://www.kawasaki.com/DefaultFrame.aspx?strContentURL=/Site/VIVehicleInformation/VItechpubs.asp?intCatalogID%3d2%26CatalogTypeID%3d4%26ProductTypeID%3d8%26ModelMarketingId%3d453%26ModelYear%3d2010%26SHOWVEHTABS%3d1
2011 C14 Service manual - 99924-1431-02  http://www.kawasaki.com/DefaultFrame.aspx?strContentURL=/Site/VIVehicleInformation/VItechpubs.asp?intCatalogID%3d2%26CatalogTypeID%3d4%26ProductTypeID%3d8%26ModelMarketingId%3d453%26ModelYear%3d2011%26SHOWVEHTABS%3d1
2012 C14 Service manual - 99924-1431-03   http://www.kawasaki.com/DefaultFrame.aspx?strContentURL=/Site/VIVehicleInformation/VItechpubs.asp?intCatalogID%3d2%26CatalogTypeID%3d4%26ProductTypeID%3d8%26ModelMarketingId%3d453%26ModelYear%3d2012%26SHOWVEHTABS%3d1
2013 C14 Service Manual - 99924-1431-04    http://www.kawasaki.com/DefaultFrame.aspx?strContentURL=/Site/VIVehicleInformation/VItechpubs.asp?intCatalogID%3d2%26CatalogTypeID%3d4%26ProductTypeID%3d8%26ModelMarketingId%3d453%26ModelYear%3d2013%26SHOWVEHTABS%3d1
Steering
Steering Stem Bearings - All Balls Racing -tapered roller bearing and seal kit for C14 Steering stem (steering head) Part No. 22-1039
Switches
SPST Waterproof Miniature Rocker Switch (On-Off) 16A Green 12V (also available in red) .921" Long x .685" Wide x .551" Deep  Part Number: NTE-54-204W  https://shop.vetcosurplus.com/
Tire Sizes
Front Tire Size - 120/70ZR17
Rear Tire Size - 190/50ZR17
Engine oil type
API   SE, SF or SG
API   SH, SJ, or SL with JASO MA
Viscosity
SAE 10W40
AMSOIL
10W-40 Advanced Synthetic Motorcycle Oil  -   http://www.amsoil.com/a/synthetic-motorcycle-oil?zo=1627549
Castrol
Castrol Actevo X-TRA 4T - http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9040438&contentId=7040549
Castrol Motorcycle Oil  -  http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=82915504&contentId=7040371
Castrol Power RS Racing 4T Full Synthetic Motorcycle Oil - SAE 10W-40 (1 qt.)  -    http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Power-RS-Racing-4T-Full-Synthetic-Motorcycle-Oil---SAE-10W-40-(1-qt-)-Castrol_99997734-P_N4019C_T%7CGRP2046_____
Castrol 4T Motorcycle Oil - http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9040439&contentId=7040925
Kawasaki
Kawasaki Performance Oils (all weights Motorcycle, ATV & Water Craft)
http://www.kawasaki.com/kawasakinew/Accessories2/PCItemsList.aspx?intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki 10W-40 Quart Motorcycle Oil - Item # :K61021-202A   -  Quart       http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021202A&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki Performance 10W-40 Motorcycle Oil - Item # :K61021-302  -  Gallon      http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021302&Reason=6&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki Performance 10W-40 Semi-Synthetic Oil  - Item # :K61021-206  -  Quart      http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021206&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki 10W-40 Quart Semi-Synthetic  -  Item # :K61021-206A  -  Quart     http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021206A&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki 10W-40 Quart Synthetic Oil  -  Item # :K61021-207A  -  Quart    http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021207A&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Mobil
Mobil 1 Racing 4T 10W40 -  http://www.mobiloil.com/usa-english/motoroil/oils/mobil1_racing_4t_10w-40.aspx
Mobil1 Racing 4T 10W-40 4-Cycle Motorcycle Oil (1 qt.)  -  (Also known as Mobil 1 MX4T) http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Racing-4T-10W-40-4-Cycle-Motorcycle-Oil-(1-qt-)-Mobil1_8026541-P_N4019C_T%7CGRP2046_____
Mobil 1 MX4T 10W-40  (Racing 4T is still sold in Canada as MX4T, and sold at Walmart)
Motul
Motul 5100 4T 10W40    http://www.motul.com/us/en-US/products/31?f%5Bengine_type%5D=26&f%5Brange%5D=21
Motul 7100 4T full synthetic 10W40    http://www.motul.com/us/en-US/products/39
Rotella - Shell
Rotella -T6 synthetic 5w40  - (Note: Folks like this, but this weight is just outside the parameters, but just barely)
http://www.shell.com/home/content/rotella/products/t6/
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_rotella&174;-t6-5w-40-shell_8120031-p?cm_mmc=ACQ-_-Google-_-National-_-Keywordless--StoreKeywordless--Ad#utm_source=acq&utm_medium=google&utm_campaign=national&utm_content=keywordless--storekeywordless--ad
Royal Purple
Max-Cycle┬« Motorcycle Engine Oil  -  http://www.royalpurple.com/product-categories/motorcycle/#!max-cycle-motorcycle-engine-oil
Royal Purple Max Cycle SAE 10W40 full-synthetic  -  Quart   -  http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Max-Cycle-SAE-10W40-Royal-Purple_99983726-P_N4019C_T%7CGRP2046_____
Spectro
Platinum SX4  full synthetic -  http://www.spectro-oils.com/platinum-sx4/
Spectro 4  -   http://www.spectro-oils.com/spectro-4/
TexasTea
http://www.texastealubes.com/
Product Code #773  10W-40 Synthetic Motorcycle Oil  - 6/1 quart     http://www.sears.com/shc/s/p_10153_12605_SPM6594295402P?prdNo=25
Valvoline
Valvoline Motorcycle Oil 10W-40 Quart  -  http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Motorcycle-Oil-10W-40-Quart-Valvoline_8080023-P_N3254_T%7CGRP2046_____#fragment-1
A/C Delco - PF2135
A/C Delco - PF1237
Amsoil - EAO 103
Baldwin - B1400
Fram - PH6017A
K&N - KN-303
Mobil 1 - M1-108
Mobil 1 - M1-110
Napa Gold - 1358
Wix -  51365
Reusable oil filters
FLO  -  https://www.denniskirk.com/flo-oil-filters/stainless-steel-reusable-spin-on-oil-filter.p305881.prd/305881.sku
K & P Engineering (Listed for non racing use) -  http://www.kandpengineering.com/S1.shtml
PC Racing PCS1 (Listed as being for either Racing or non Racing use) -   http://www.pcracingusa.com/Kawasaki-Street-PCS1_p_19.html
« Last Edit: June 04, 2018, 10:29:11 pm by TimR »
