Author Topic: Change Radiator Hoses?  (Read 1567 times)
Offline touring03
    • ADVENTURES ON 2 WHEELS - motorcycle touring & travel
  • COG#: 10797
« on: January 27, 2018, 10:28:38 pm »
From a preventative maintenance point of view, at what mileage would you replace all your radiator hoses?
PG.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
Re: Change Radiator Hoses?
« Reply #1 on: January 27, 2018, 10:31:25 pm »
PG.
I've kept hoses on bikes for 15+ years. I think it has a lot to do with your individual use.
Offline jwh20
« Reply #2 on: January 27, 2018, 10:35:09 pm »
I just keep an eye on mine.  If they start to show any cracks or start to feel stiff when you squeeze them, it's time to replace.  But generally they last much longer than the recommended service interval which I believe is 4 years.  I have a 2002 ZRX1200R with the original radiator hoses and they are still like new.  A new set is fairly expensive so I'm not replacing them unless needed.
2012 Concours 14 Arabian Red
Offline Just Cliff
  • COG#: 9547
« Reply #3 on: January 27, 2018, 10:58:06 pm »
I replaced mine at 6 years & 118,000 miles, just seemed like cheap insurance. Most of my riding is long distance. If I was always within in my home state I wouldn't worry about it. They appeared to be fine at that point.
Cliff   :beerchug:
Cliff
2014 1000 V Strom
Offline touring03
  • COG#: 10797
« Reply #4 on: January 28, 2018, 12:47:10 pm »
Thanks for the info, I have about 60,000 miles on my 2009, maybe I'll just give everything a good inspection, check the tension on the clamps and call it good.
PG.
Offline jwh20
« Reply #5 on: January 28, 2018, 05:19:53 pm »
Another thing to look for is "crusty" deposits around the connections.  If coolant is seeping out it often evaporates and leaves deposits behind.  Usually indicates the hoses losing their ability to seal.  Tightening the clamps can help for a time but eventually there is nothing left to compress.
Offline touring03
  • COG#: 10797
« Reply #6 on: January 28, 2018, 05:51:12 pm »
 :great:
Offline cuda
  • Ignorance Is Bliss.
  • COG#: 11405
« Reply #7 on: January 28, 2018, 07:47:45 pm »
What ever happen to the aftermarket hoses that were being made.
There was a thread about them.
Offline Deepsea
« Reply #8 on: January 29, 2018, 03:54:40 pm »
http://samcosport.com/bike/
They are in the UK but if you do some research you'll find a U.S.A. vendor.
Retired Navy Saturation Diver
« Reply #9 on: January 29, 2018, 06:17:34 pm »
2000 Red C10 1052 kit
Offline jwh20
« Reply #10 on: January 29, 2018, 10:07:54 pm »
The Samco hoses are nice, and can be really cool if you want to color match your bodywork (on a bike that allows you to see the engine) but at almost US$300 for a set, wow, that's a lot of money.  I think the OEM hoses are quite a bit less than that.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #11 on: January 31, 2018, 11:50:21 pm »
Cliff   :beerchug:
I would have replaced them before 118K but Its probably a good idea on this bike around 50K.
Offline Jorge
  • COG#: 9297
« Reply #12 on: February 01, 2018, 02:14:38 am »
I'd say it depends on the type of driving.
Enemy of hoses (and other rubber items in the engine area) are heat, and time at high temperature.
Long jaunts on roads clear of traffic are probably going to keep the hoses cooler: Coolant is at lower temperature, and the outside of the hose are getting cooled by the air. Stop & go driving in traffic will keep the hoses at higher temperature for longer periods, and age them more.
The high temperature "bakes" them, and makes them hard and brittle.
When I replace mine, I will probably go with the silicone (thanks Mike for posting the URL), as silicone is much less affected by high temperatures.
My 2001 Suburban (216,000 miles) still has the original hoses, and they look good. Most driving has been highway driving, so little "baking time".
Offline Just Cliff
  • COG#: 9547
« Reply #13 on: February 01, 2018, 06:58:57 pm »
PG.
Cliff   :beerchug:
Straighten me out here. 6 years was to long but you've run them for 15+ years? I think age has much much to do with it than miles, but that's just my humble little opinion.
Using your 50,000 mile figure I would be installing my 4th set of hoses!
Would you run a 15 year old tire just because it was new?
Cliff   :beerchug:
Cliff
2014 1000 V Strom
Offline Deepsea
« Reply #14 on: February 01, 2018, 07:37:47 pm »
Racebikebitz - Samco Sport Distribution <sales@racebikebitzusa.com>
Here is a US Distributor.
« Last Edit: February 06, 2018, 06:52:08 am by Deepsea »
Offline Jorge
  • COG#: 9297
« Reply #15 on: February 05, 2018, 10:41:55 pm »
Sure Cliff... I'd rather have the 15 year old hoses from the Arkansas widow than the three year old hoses from the Houston cabbie  :)
Offline Texas Concours14
  • COG#: 9760
« Reply #16 on: February 06, 2018, 02:34:17 pm »
To add to the community database, my 2010 with 48k miles just recently started to leak of coolant (couple of drops a day). Will be changing all the hoses soon.
2010 Concours 14
Offline Roger B
« Reply #17 on: February 06, 2018, 03:55:34 pm »
When it becomes more than a couple of drops replace your water pump.   :)     I had a 2010 zx14 that started to lose coolant and I tightened all my hose connections, then it started to lose more and I figured out it was my water pump.
« Reply #18 on: February 06, 2018, 07:56:04 pm »
I looked close at the replacement cost from Samco and OEM and was surprised that if you buy OEM hose for every one that comes with the aftermarket kit it really was not that much more.   If you buy the hoses that are not custom bent from bulk then you can save more.  OEM cost for the small drain hoses is redic.
  • COG#: 9760
« Reply #19 on: February 06, 2018, 09:22:34 pm »
Oy!
2010 Concours 14
