Author Topic: clutch issues...  (Read 956 times)
Offline DUMB A$$
clutch issues...
« on: February 01, 2020, 06:19:31 pm »
when engine cold my clutch engages as soon as the lever comes off the grip and difficult to down shift. after I drive around 17 miles to work, engine warm, the clutch is back to normal. I have gravity bleed the line, I have manually bleed the line and bleed with a vacume pump with new fluid and no change.      suggestions....
Dumba$$
Offline gpd323
Re: clutch issues...
« Reply #1 on: February 01, 2020, 07:57:01 pm »
Did you burp the master cylinder? There is a bleed port on the MC that you crack open just a wee bit, pull the clutch lever just slightly and then close the bleed port. That removes any lingering air in the MC.  :beerchug:
Offline gpd323
« Reply #2 on: February 01, 2020, 07:58:41 pm »
Make sure to have a rag around the MC bleed port, brake fluid is very hard on paint and other bits.
Offline DUMB A$$
« Reply #3 on: February 01, 2020, 08:29:22 pm »
yup, I did all that.
Offline gpd323
« Reply #4 on: February 01, 2020, 08:45:38 pm »
OK.
Is the fluid level in the reservoir dropping a little bit over time? It would be difficult to notice now that you bled the system, but some of the early ZX14's slave went. Only way to find out was unbolt the slave cover and discover fluid in that cover.
Stock lever? You play with the lever adjustment ring?
Offline DUMB A$$
« Reply #5 on: February 01, 2020, 08:51:42 pm »
Fluid was not low, at upper line. played with knob setting a little and left it on 3. I changed engine oil today and did not notice any signs of a fluid leak.
Offline gpd323
« Reply #6 on: February 01, 2020, 08:53:20 pm »
Don't know then. Hope you find the issue.  :beerchug:
Offline DUMB A$$
« Reply #7 on: February 01, 2020, 09:02:40 pm »
me too, thanks
Offline strum
  • COG#: 12307
« Reply #8 on: February 01, 2020, 09:30:14 pm »
What year ,how many miles, how has it been maintained?
2016 C-14
Offline DUMB A$$
« Reply #9 on: February 01, 2020, 10:13:36 pm »
2008
38210 miles
no major services that I know of.
I bought from original owner November 2018 with 33k miles.
Offline strum
  • COG#: 12307
« Reply #10 on: February 02, 2020, 02:23:00 am »
I had something like this with mine. its tuff to get all the air out. most likely your issue.
2016 C-14
Offline C. Moore
  • COG#: 6662
« Reply #11 on: February 02, 2020, 10:42:51 am »
It is hard to get all the air out of the clutch line. Same issue on the C10. Seems like I always have some tiny bubbles when I finally call it good and tighten the bleeder but I've never had any clutch issues. Does the clutch lever have any slop in it?  I'm wondering about the slave cylinder. Been in there yet?
'10 C14  Dallas, Texas
CDA #523
COG# 6662
Offline gpd323
« Reply #12 on: February 03, 2020, 10:39:35 pm »
Its got to be air still in the system.  :beerchug:
Online Cali Cruiser
  • COG#: 12770
« Reply #13 on: February 04, 2020, 12:03:52 am »
Mine has the exact same issue and it seems like the more days it sits the more likely it will act poorly when it’s cold and I go to ride it. When the weather is cold and it has been sitting for days it’s pretty much creeping away with the clutch lever pulled all the way in and then totally fine after several miles/shifts. I suspect bleeding would be the cure but if not I’m interested in knowing what turns out to be the remedy for yours.
Offline DUMB A$$
« Reply #14 on: February 04, 2020, 03:42:06 pm »
2/3/20 ice on windshield this morning and cant engage clutch. Stalled at first stop, clutch knob at positionm 3, moved to position 5 and good to go.
2/4/20 no ice but still cold and knob still on position 5, clutch engages right off the grip. I will pull slave apart and see if I can find something there. I just cant believe it needs more bleeding.
Offline dirt_biker
  • Craige Scott North West Area Director
  • The only way to ride and I Love it! (C14)
  • COG#: 9307
« Reply #15 on: February 04, 2020, 09:50:11 pm »
I had the same problem and if I opened up the top of the master cylinder and taped on the lever I could see
Small bubbles coming up out of the whole I bled the clutch and it was perfect until the next day then it did it again( the 2015 C14 only had 12,000 miles on it ) so I took it to the Kawasaki shop and the had to replace the master cylinder, I have not had any more problems  :motonoises:
The shop told me they see this Every once in a while the seals inside get damaged and then they leak air. :-\
Craige Scott Northwest area director
2015 C14,  Full AreaP, and 2" Risers, Garmin GPS, Rosta CC, PR3's, These are the other rides I have now. 76 KZ900, 75 CR250M, 04 Vforce 700, 09 KFX450r
Offline DUMB A$$
« Reply #16 on: February 12, 2020, 10:52:53 pm »
If anyone is interested, I ordered a new clutch master piston assy. from partzilla and installed today and clutch is back to normal. good resistance on the lever. I feel good about it working correctly in the morning.
DUMB A$$
Online FTB530
  • COG#: 12127
« Reply #17 on: February 12, 2020, 11:10:18 pm »
DUMB A$$
Good job, was that you I saw last Friday?
Good to know I have a mechanic close by 😂
Offline gpd323
« Reply #18 on: February 13, 2020, 11:18:08 pm »
DUMB A$$
Glad to hear!
Offline TireguyfromMA
  • COG#: 12669
« Reply #19 on: February 14, 2020, 02:51:46 am »
Good to hear you got it fixed!  Did you notice anything unusual, signs of wear, or damage on the old MC piston assy you took out?  Were the seals worn or broken?
2002 Honda ST1100
Offline DUMB A$$
« Reply #20 on: February 16, 2020, 07:04:00 pm »
The cup seal appeared to be a little flat looking. no wear in the bore.
Online antibus
  • COG#: 11339
« Reply #21 on: February 17, 2020, 03:35:28 pm »
Glad it's working now. Strange issue though...
CDA #0542
Offline DUMB A$$
« Reply #22 on: February 29, 2020, 03:54:59 pm »
Im thinking that the bike sat for years and the cup seal just went flat, just a guess though.
