Author Topic: Clutch Lever Tension adjustment  (Read 1375 times)
Offline richagpalmer
« on: April 25, 2018, 03:22:50 pm »
Is there a way to adjust the tension of my clutch lever ?
I have a 2012
Not looking for distance to my handlebar...
My wrists get tired from using the clutch and would like it to be easier to pull in.
Thank
Offline JaL3
Re: Clutch Lever Tension adjustment
« Reply #1 on: April 25, 2018, 03:49:58 pm »
Since it's hydraulic (like both front and rear brakes), the short answer is no.
Longer "answer" would include changing master or slave cylinder, getting longer lever or weaker clutch springs. Those would of course increase the risk of clutch slippage.
Regards, Jay with 2016 ZG1400, Ivan's flash, seat modded by Spencer, Puig spoiler, Canyon Cages, Bar Risers, Rigid Industries aux LEDs, Switchback LEDs front and rear, Two Brothers Black Series Slip-On.
A skeptic that believes anything when provided with evidence.
Offline Deepsea
« Reply #2 on: April 25, 2018, 06:27:30 pm »
Changing the master cylinder isn't hard. There are several aftermarket units available. Just be sure to get one that has a larger volume output than OEM. You can even get rotatory ones that are adjustable but they cost $$$.
Retired Navy Saturation Diver
Offline JaL3
« Reply #3 on: April 25, 2018, 07:03:06 pm »
If you want to lessen the force on the lever side, shouldn't the master cylinder actually be smaller than OEM? Like on a floor jack, small cylinder pumps fluid to a larger one and the smaller the master (or larger the slave), the less force is needed. Travel would be then less too, of course. Or am I missing something here? (would not be the first time  ::) ..)
Offline Turtle
« Reply #4 on: April 25, 2018, 10:38:07 pm »
Is the lever at the proper angle? Try loosening the bar clamp and rotate a bit to change the lever position.
Offline Deepsea
« Reply #5 on: April 26, 2018, 04:17:00 am »
Jal3, you are correct. I meant to say variable volume but my stupid fingers(controlled by my lax brain) said larger. As you pointed out it's the ratio that determines force required but if the volume is incorrect the clutch will either drag or you'll potentially blow the seals on the slave.
  I've changed both the clutch and brake levers on my 09 with "Short" ones and have them adjusted to the closest position (shortest pull) possible. This does three things, 1st the "Perceived" force is lessened, 2nd the clutch engages sooner and 3rd it's easier to place just two fingers on the brake lever while using the remaining three fingers to work the throttle.
Good catch by the way, thanks for the correction. :beerchug:
Offline sam_uk
Offline oldnslo_MO
  • COG#: 9924
« Reply #7 on: April 26, 2018, 06:16:55 pm »
i went with a set of pazzo levers. the so called longer ones, although they are really shorter than  stock with ,to me, a much more comfy angle. with quick lever adjustments. not cheap but with my arthritic digits much easier on the hands,, ;)
Offline Syxxphive
  • COG#: 12672
« Reply #8 on: April 26, 2018, 06:59:20 pm »
I got a set of the shortys from Pazzo. Awesome levers.
« Reply #9 on: April 26, 2018, 07:34:39 pm »
Try http://www.oberon-performance.co.uk/acatalog/Kawasaki_Clutch_Slave_Cylinders.html
Interesting.... thank you greatly.... :great: :great:
I can see this being a very nice item to put on our replacement part section, as rebuilding the OEM costs about half the price of that nice unit...clean looking, and at $128.73 U.S.D., not a bad price...
Only question I would have, is what replacement seals do they have in stock, for future repairs of that unit when it comes time...
I do like that gear tho... I have to download the install pdf to see what internal spring is required also, whether the OEM kaw part works or not, as those do tend to become a bit "relaxed" over time.
I do see they have a "lifetime warranty", if needed, but I can't imagine how long it would take to get a replacement back.
« Last Edit: April 26, 2018, 07:43:06 pm by MAN OF BLUES »
Offline Steiny
« Reply #10 on: April 26, 2018, 08:44:45 pm »
 Get some of these and use when driving the car ,  it works
Offline Phil
« Reply #11 on: April 26, 2018, 09:01:18 pm »
I would say, keep the stock master cylinder for just such an occasion.
« Reply #12 on: April 26, 2018, 09:17:16 pm »
 :)) :)) :)) :)) :rotflmao: :rotflmao:
If u saw my garage, and my "parts collections", you would understand that point is a no brainer.... :beerchug:
Hell, I cut the power cables off of every electrical device I toss out... just for spares... :rotflmao: :rotflmao:
My dad was a "hoarder", and tought me well... I've refined this into a finer art of "selective hoarding"... ;)
Offline Phil
« Reply #13 on: April 26, 2018, 09:29:07 pm »
Ah yes, you know my garage well. Mine is the same. "I may use that sometime..."  I still have a carburetor I bought for a 1984 Dodge truck I built up sitting in its box under my workbench. It was only on the truck for about a month before I swapped it out for a different one. That was back in 1987 or so...  I also have various brake parts for various cars, mass airflow sensors, old spark plugs, the watts linkage from my old PT Cruiser, and on and on...
« Reply #14 on: April 26, 2018, 10:59:43 pm »
Heading to the Grand Canyon from Mississippi in May hoping to make the ride a little more enjoyable.
